What bar and ripping chain do I need for a G660 for milling?
Discussion in 'Chainsaws and Power Equipment' started by cezar, Dec 5, 2024.
  1. John D
    John D
    Syracuse ny
    If you are not brand specific the the Best saw to get is the one that has the best dealer support stihl,Husqvarna or echo if you want to save some money buy used if you are looking at a clone then you take your chances they are not cheap because they are built as good as the 3 main manufacturer
  2. cezar
    cezar
    KY
    More like "Yeah we ordered it"
    "Hasn't come in yet"
    "Yeah we're giving up, sorry"
    eatonpcat, John D and brenndatomu like this.
  3. brenndatomu
    That.
    Is.
    Weird!
    eatonpcat and John D like this.
  4. cezar
    cezar
    KY
    Yeah it's super annoying. Like, I can't even get chains for my MS251 from there. AND THEY SOLD ME THE SAW. Files? Yeah right.
    Trying to decide what my next move is. Returning the saw, and the bar I bought, and the four chains is gonna be an ordeal. But I don't see a way forward with this thing. I haven't even been able to run it once and I've had it 2+ weeks.
  5. Eggshooterist
    Eggshooterist
    Erff
    I don't know your situation but, is it really a big deal to drive an hour to get the parts you need? Its not like its a weekly ordeal. Or shouldn't be anyway. Can you call the dealer that's an hour away and order the parts, chains ect, make one trip and be done with it for awhile? Like I said, I don't know your situation but I personally have no problem driving an hour for good service if nothing closer exists or what does is sub par.
  6. John D
    John D
    Syracuse ny
    When I am looking for a deal I have drove over an hr to pickup a saw or piece of equipment
  7. Eggshooterist
    Eggshooterist
    Erff
    Same here.
    eatonpcat, brenndatomu and John D like this.
  8. cezar
    cezar
    KY
    Yeah that would be no big deal.
    My understanding is with these clone saws you are replacing parts pretty often until they arrive at a reliable state. If that's the case then multiple hour drives is not worth it.
    Here's a question; all the trees I'd be milling are under 24" (hardwood). If I end up buying another, smaller saw than 90cc, what displacement do I actually need?
    John D, brenndatomu and buzz-saw like this.
  9. Eggshooterist
    Eggshooterist
    Erff
    I cannot answer that as I've never milled before. Hopefully someone can guide you in the right direction.
    You could research what the problem areas of that clone saw are and get all those parts up front in one trip. Replace as needed.
  10. Lehman
    Lehman
    Minnesota
    Bigger is usually better but if you take your time and give the saw a break now and then a 70 cc saw will do what you want to do. So 372, 460/461/462, 7310 echo, 572, 575,576,044 since you already have a Stihl bar I’m assuming
  11. buzz-saw
    buzz-saw
    Ct.
    24 inch hardwood is some tough stuff.
    Again, milling is hard on equipment (not so easy on the operator either) so go as big as you can go saw wise, you won't regret it. And remember extra oil in the mix and oiler for chain wide open.
    John D, brenndatomu and Eggshooterist like this.
  12. cezar
    cezar
    KY
    Not a terrible idea.
    Though at this point I'm leaning towards returning it. I feel like it's going to be more trouble than its worth long term.
    I'm debating getting a Echo timberwolf and putting my Stihl MS251 on milling duty until it blows up and then I can wash my hands of the Stihl brand. It's 45cc though so it's probably slightly undersized. Then again my average log will only be like 16" probably.
  13. buzz-saw
    buzz-saw
    Ct.
    A 45cc saw is " small" for milling and for most probably cuts best with a .325 chain over a 3/8. If you are milling 16 inch logs then the bar should probably be around 20 inches minimum. That is a " LOT " for a 45cc saw. Even bucking a 16 inch log with 45cc is probably close to the max for it.
    I don't see it lasting all that long milling with it.
    Could be wrong and this is only my 2 cents on this ; it is tough work especially for the saw.
    You're s going to have any saws tongue hanging out milling with it.
  14. Lehman
    Lehman
    Minnesota
    You’ll kill it pretty quick and hate every minute of milling, if you buy a real Stihl, echo or husky pro saw you more than likely won’t need to worry how crappy the close shop is because you won’t need him. Just the one an hour away when you go to load up on chains ect because any of the 3 main saw brands won’t probably need to be touched for a long time.
  15. Eric Wanderweg
    You're right on point with milling with a 45cc saw. I tried it on my 029 super when it was stock (56cc) and there simply wasn't enough grunt there.
  16. cezar
    cezar
    KY
    Alright. Still marinating on what to do. I have till the end of the month to return the clone saw.
    Assuming I decide to keep it and shotgun parts at it, what all should I get? I'm thinking carb for sure.
  17. buzz-saw
    buzz-saw
    Ct.
    I used my 362 for my first attempt, that is 59cc. It was on 12-14 oak and that is about all it would handle.
    Also keep in mind the oiling on a smaller bar is not enough to support a long bar for milling. It’s not gonna last.
    Think about it and don’t rush into it. It’s a fun hobby but you don’t wanna get off to a bad start.
    Husky Man, eatonpcat, John D and 3 others like this.
  18. brenndatomu
    On my farmertec 660 the only thing that is not farmertec parts is the wrist pin bearing (had a bad reputation back then) and then the chain tensioner, which like I mentioned earlier, did NOT fix my adjustment issue, until I shimmed the tensioner in the case...but at that point I just decided to keep it.
    That's all I recall replacing on mine, but I assembled it myself from a box of parts, and inspected everything before installing...I did have to clearance the inside bottom of the piston skirts as they actually had light contact with the crank at BDC. Cleaned up the ports a bit, did a gasket delete, and she runs pretty good for a stock saw! But I only use it a time or two per year, so that's why I cheaped out n went clone.
    I agree, the 251 will only pizz you off trying to mill with that...plus probably ruin it...may as well give it away while it's still worth something rather than just blow it up for spite.
    When milling, use an auxiliary bar oiler, and run top quality oil in the mix gas, like the ones someone mentioned earlier here (I think it was here) and mix it rich, like 32:1...might adjust the carb a lil on the rich side too...like to the point it 4 strokes until you really lean into the mill.
  19. cezar
    cezar
    KY
    Update.
    Saw is non-returnable (doh!) so I guess that is out.
    Anyway, I got a replacement (knockoff) tensioner in and this one seems to work. I still suspect it will fail eventually but it gave me a chance to fire up the saw and cut some wood.
    Holy hell the saw is absolutely terrifying.
    And it starts in one pull. My STIHL doesn't even do that. Literally after sitting for 3 weeks it started on the first pull. Actually the first part of the first pull. The pull starter is like an on switch. I've never seen anything like it.
    Anyway, new issue; the chain brake doesn't work properly. I took a video if anyone wants to see it, but the issue is simple enough. Basically it only engages the brake if you push on the far right side of the chain brake handle. If you push on the left side or center, nothing.
    Any ideas on causes or a fix?
  20. John D
    John D
    Syracuse ny
    Thinking without seeing it might be the brake handle isn’t rigid enough on the left or center to pull the brake on
    Now in reality if you are truly using this saw in a chainsaw mill once the saw is secured in the mill the brake will never be able to activate
