what bar and chain oil ??
Discussion in 'Chainsaws and Power Equipment' started by PlumbSplitter, Apr 30, 2020.
  1. Cheepbeer
    Cheepbeer
    NW Ohio
    All I've used in the last 30yrs has been from tsc or rural king. Before that I used straight 30w with stp in it for a tackifier.
    WeldrDave, mat60, Fifelaker and 2 others like this.
  2. jrider
    jrider
    I probably go through at least 20 gallons of bar oil a year. If I saved only $5 a gallon, that’s $100. The last time I bought a 24” bar for my echo 8000, it was $80 something. I’m not buying a bar every year. I used to buy Stihl oil for $14 a gallon from my local shop. I now but TSC oil for either $7 or $8 a gallon. At those price points, I am saving more money by buying cheap oil and it’s not even close.
  3. Highbeam
    Highbeam
    Does oil pump life change with expensive oil? I but gallons at Walmart. When I was a kid, dad had us use engine oil.
    WeldrDave likes this.
  4. Dumf
    Dumf Banned
    Maine
    Summer 30 W cheapest bar oil on sale.
    Winter mix the 30W with diesel.
    No canola or extra virgin.
  5. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Canola oil works fine. I've used it for years. If you cut in an area that is an environmental zone, you often are not allowed to use regular bar oil. Canola is fine. If you are hesitant, you can use it to cut your regular bar oil 50/50. The only thing I've heard is that the canola oil will get rancid after a while in your saw. I typically run my saw until the tank is empty which means there is little if any bar oil left. I've never had it smell so either it doesn't get rancid or I use the saw enough for it not to matter.
  6. JackHammer
    JackHammer
    I know chain bar oil isn't that expensive but I have a few quarts of used oil from the last time I changed the oil on my mower. Is that ok to use in the saw?
    farmer steve and campinspecter like this.
  7. fox9988
    fox9988
    NW Arkansas 72717
    The cheapest I can find. I've never burnt up a bar or chain, they wear as they should. Anything else is waisted $$
  8. Dumf
    Dumf Banned
    Maine
    NO.
    farmer steve and Fifelaker like this.
  9. fox9988
    fox9988
    NW Arkansas 72717
    I did it for a decade. No problems. Was finally shamed into buying cheap bar oil. Saw stays cleaner. No noticeable difference in wear.
  10. buZZsaw BRAD
    Years back my late father used drain oil in his old McCollough saw. I personally wouldnt do it today but if it works for you, great!
    farmer steve, WeldrDave and fox9988 like this.
  11. fox9988
    fox9988
    NW Arkansas 72717
    I always figured it was good enough for my engine until the moment I drained it out.
    And I learned it from my father too.
  12. mat60
    mat60
    ME
    Cooking oil it will be. :tears:
  13. campinspecter
    campinspecter
    I only use Stihl winter grad oil , I use it over Husqvarna oil because the stihl container pours better . Used a gallon of Wallmart brand once it destroyed a new bar after one chain !
  14. campinspecter
    campinspecter
    The bar oil that I had problems with came form Lordco not Walmart .
    farmer steve and Woodwidow like this.
  15. Dumf
    Dumf Banned
    Maine
    VIRGIN olive oil.
    farmer steve likes this.
  16. MikeInMa
    I picked up a gallon at HD, this morning.
    They had a shelf full.
    farmer steve and WeldrDave like this.
  17. JackHammer
    JackHammer
    It dawns on me that if I had a decent saw, with a long bar, and used it frequently - the sticky oil would likely do better than used motor oil.
    With my current saw... I would feel fine putting glue in oil tank. The worst thing that could happen is that I would get a new saw! :rofl: :lol:
  18. JackHammer
    JackHammer
    I was at HD also today and I saw a ton of splitters out front. I hope those customers aren't starting to split their pile for this winter, they missed the boat.
  19. NYH1
    NYH1
    Central New York
    I usually use Husky or house brand from TSC, Runnings, Lowe's ect. The snowplow shop I go to is also a Stihl, Redmax (Jonsered :() dealer. I'll grab oil from them if I'm there and need it.
    NYH1.
  20. WeldrDave
    First, welcome to FHC!!! You and JackHammer :handshake: If all you can get is the summer or heavy bar oil, "cut it" with a small amount of Diesel or Kerosene. About a 1/8 to
    1/4 cup to a gallon works well. Any of the "box store" bar oils are fine but I have noticed TSC's oil can be thick. I do like the Husqavrna oil but found it $$$, sometimes.
