What are y'all working on today?
Discussion in 'Chainsaws and Power Equipment' started by Mastermind, Mar 7, 2015.
  1. cory@owen
    cory@owen
    Converted a 61 to a 272xp today. Needs a longer plug wire and a little clearance for the spark plug boot. It's running an hs 254 carb right now. I have an hs260 that will go on when I get a rebuild kit.
  2. EvilRoySlade
    EvilRoySlade
    Trying to get a 346 case welded. Turning a bunch of parts into a 359 and 2156. Putting together a 353 to sell after thurough clean and repair job. If I included my labor it would go for around $900. Hell I've got $100 my labor removing the cat, last time doing that. I'm glad I don't do this to make money.
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    Amen brother. . I have done many saws for no profit or a slight loss.
    Good on you for helping helping others and keeping yourself busy! :)
  4. Moparmyway
    Moparmyway
    New York
    Aluminum I run an 11 ............... I am also working in a dimly lit barn, but when I am outside, I go up on number.
    I haven't tried the cheater lenses yet ................ have to grab one sometime soon.
    Does it give you a headache after a few flips up and down ?
  5. Moparmyway
    Moparmyway
    New York
    Spray transfer is very tricky, and for me is impossible if inverted.
    For MIG; 100 % CO2 will cause more splatter, penetrate much deeper, and run REAL hot, I run C25 exclusively with ER70S-6 wire (lots of dirt bike repairs)
    For TIG, I have a few bottles with different mixes and Pure Argon, and have been liking the Tri-mix on stainless
  6. Moparmyway
    Moparmyway
    New York
    If its an alcohol motor, its easily obtainable
    concretegrazer likes this.
  7. Kg461
    Kg461
    Provencal, La.
    390xp handle got painted yesterday
  8. Stihl bro
    Stihl bro
    Hmmm????? What's going on here????
  9. clemsonfor
    Blow by!!
    Ring seized? What's the compression?
    pantelis and Kg461 like this.
  10. Moparmyway
    Moparmyway
    New York
    Worn ring ........... did you wipe off any oil, it looks dry ?
  11. Stihl bro
    Stihl bro
    Between 100 and 110 lbs. Hard to do with the 10mm threads. Did not have to wipe piston. Oil looks cooked on below the ring land.
  12. clemsonfor
    At 110 you have a problem!! I bet it runs kind of rough? Low on power?
  13. redneckdan
    redneckdan
    Northern Minnesota
    Hopefully stuffing the Myraid into the garage and getting it hooked up today! Get it all nice and broke in with the tail end of this season and move it into the living room next fall when we install the wood boiler.
    foragefarmer and concretegrazer like this.
  14. DexterDay
    Northeast Oh
    What does that piston go to?
    I have seen new saws, weed eaters, leaf blowers, etc with black like that below the ring. The type of oil, amount of oil, and also the temp at which that piece of equipment is ran at. My Poulan Weed wacker has looked like that from its first year. But I ran 50:1, chitty oil, and it's wide open for over an hour straight when I weed wack around my pond.
    It could very well be a worn ring, but other OPE doesn't always have the really high compression that a saw does.
    MasterMech and clemsonfor like this.
  15. clemsonfor
    Looks like a piston out of a baby saw or similar sized weedwacker. Good call dex
  16. DexterDay
    Northeast Oh
    It's a little piston, or he has a GIANT thumb :yes:
    MasterMech, Chvymn99, Kg461 and 3 others like this.
  17. Cut4fun
    Cut4fun
    OHIO Redneck
    Mag Craft and mdavlee like this.
  18. Moparmyway
    Moparmyway
    New York
    Hmm..........
    That ring looks real shiney, what does the under-side of the piston look like ?
    Looks like the piston and wrist pin area are real dry ........... maybe something like Amsoil @ 80:1 to 100:1
  19. clemsonfor
    Yea that thing is all dried up and burt out?
    There should be some oil or finger prints somewhere?
    Running lean as well?
  20. Stihl bro
    Stihl bro
    It's a 550 piston. Compression was low. Cannot comment on what type/mix of oil used. Cylinder is flawless. I'm thinking heat!
    concretegrazer, DexterDay and Cut4fun like this.
