What are y'all working on today?
Discussion in 'Chainsaws and Power Equipment' started by Mastermind, Mar 7, 2015.
  1. trktrd
    trktrd
    Arkansas
    Well, I didn't exactly install a "new" battery. I pulled the old one out to take it in for exchange and as I was milling around the barn, there it was! My 6 month old trolling motor battery sitting on a maintenance charger. Being the cheap bastard that I am, guess what went in the tractor! Better put it to use than spend money. Won't be fishing for a while anyway.
    Horkn and wildwest like this.
  2. clemsonfor
    I am tempted. I bought a starting/deep cycle battery for the boat for use late this summer that needed one. We never ended up using the boat this yr I never installed it so I have a new one sitting around.
    I still will out it in the boat though. My old k10 now will get a battery as mpg saturn is gone and I will pull that battery and put in the truck that has an old marine battery that was pulled and given to me at least three years ago by a could worker. Its about gone now
    Horkn likes this.
  3. Nixon
    Nixon
    West Sunbury,Pa .
    Converted a few round ground chains to square ,did a few chains for a neighbor ,made an appointment with mmws to massage the Dolmar ,then decide to be lazy for the rest of the day
  4. ironpony
    ironpony
    Mid Ohio
    tomorrow I am replacing a Pella window in the bedroom, broken seal. will be a challenge, stone wall and new construction replacement, so it is the same size/style that is there
    Horkn and Nixon like this.
  5. cnice_37
    cnice_37
    Sounds like a challenge! Let us know how you solve it please.
    Horkn likes this.
  6. LinkedXJ
    LinkedXJ
    Indiana
    Ultimate linings.
    94BULLITT and Horkn like this.
  7. cnice_37
    cnice_37
    Got the new lights wired up and mounted. I need a welder and some wire loom to clean it up, but it will work for now.
  8. Nixon
    Nixon
    West Sunbury,Pa .
    Got roped into changing a starter on a fiends box truck . It's in his driveway ,and it's not exactly summer . On the brighter side ,it's not raining ,or snowing ! ☔️❄️
    mdavlee, Horkn, Chvymn99 and 3 others like this.
  9. Oldman47
    Oldman47
    Illinois
    You could come here and do the starter on my S-10 when you are done with that one if you want.
    Horkn, Nixon and Chvymn99 like this.
  10. clemsonfor
    S10 probably easy. My ranger was easy. Old tempo I had was easy. The saturn was more of a pain that I did last year.
    Horkn likes this.
  11. Cut4fun
    Cut4fun
    OHIO Redneck
    Opening chains for the chain build off. Some boxes have 2-3 chains in them. o_O
  12. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Working on a rack for my bars and chains, pictures when I am done.
    Horkn and clemsonfor like this.
  13. concretegrazer
    concretegrazer
    Southwest MO
    That'll brighten the night.
    cnice_37, Horkn and Chvymn99 like this.
  14. MasterMech
    I just gave a non-AV WildThing "the treatment". New fuel lines throughout and a quick carb cleaning. Man these things run so good for being such a POS. :rofl: :lol:
  15. clemsonfor
    Too bad any work required to them almost totals them out from a shop bill!
  16. Horkn
    Can they really be made to run well?
  17. MasterMech
    Just under $50 and its outta here. I've spent not even an hour with it including test cuts. Not a thing wrong with it other than the fuel lines and some fine dust clogging the inlet screen in the carb because the fuel filter was rolling around the bottom of the tank.
    Chvymn99 and concretegrazer like this.
  18. MasterMech
    Yes! Especially the old non-AV versions. Fuel lines are crappy clear vinyl, that's their biggest weakness. A lot of guys plumb the primers in wrong too. They should pull fuel through the carb, not push it through.
    Re-tune from the factory's rediculous lean settings and they're off!
    clemsonfor likes this.
  19. clemsonfor
    I had one just like that. Filter rolling around and screen clogged. New carb rebuild. Air filter, and fuel cap fixed it. Not even an hour here either.
  20. clemsonfor
    Yea they run very well when you tune them right. A muffler modd helps as well. There a good cheap 40cc saw. But its still a slow 40cc saw with NO av!
    Watch the one that mastermind did on youtube. I think bit was titled like wilder thing!! Maybe it was brad??? Anyway that saw sounds bad and screams!
