What’s everyone’s ideal house temp?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Perry long jr, Jan 21, 2022.
  1. Camber
    Camber
    Montana
    90 by my chair from end of September until the end of May. Give or take a week or so anyway. I'm always outside working or whatnot and when I'm inside during those months it has to be hot. No slippers, or and throw blankets needed. We leave the bedroom window open and it'll stay around 60 in there. My shop, I like about 50 if I'm working, the garage about 70.
  2. Horkn
    Same here.
  3. Dave_in_abq
    Dave_in_abq
    New Mexico
    Ideal is about 74*F. That is not where the house is at.
  4. Backwoods Savage
    Around 80 most of the time. It is 79 now but was 77 when I got up a couple hours ago.
  5. TurboDiesel
    The stove room was 92 when i came up, after miss july reloaded the stove.
    i was melting...
  6. TurboDiesel
    Sounds like you need another woodstove in the main room.:yes:
  7. Warner
    Warner
    We just moved into a brand new shop with natural gas heat. If it gets over 65 I’m overheating. The old shop had a waste oil burner that would run pretty much constantly during the winter with the tstat set at 58 it was always cold! I’m gonna get used to working in a t shirt!
    brenndatomu, MikeInMa and Chvymn99 like this.
  8. Chvymn99
    Between 75 and 80 depending on how my days are. :D... but the bedrooms are always cooler, since they are on the back end of the "H" shape floor plan. So it all works out.
    brenndatomu and theburtman like this.
  9. Eckie
    Eckie
    Omg. Do you actually sit in "your chair"? You must have a fair amount of lizard blood in you....
  10. Todd
    Todd
    NW WIS
    Mid 70’s in the stove room, upper 60’s in the bedroom and 150-160 in the sauna.
    Chvymn99, brenndatomu and yooperdave like this.
  11. oldspark
    oldspark
    NW Iowa
    Yep same boat here.
    Chvymn99 likes this.
  12. billb3
    I prefer 68-70ºF
    although I won't set that temp on the A/C in the Summer.
    The stove room can get really warm but the front porch is unheated and I can open the front door and spill out some of the heat when it gets above 72ºF.
    The back porch/laundry room is insulated but the radiator is kinda small for the room size so I can open/close that door, too.
    brenndatomu likes this.
  13. Locust Post
    70-72 in the living room above the stove room, 68 in the bedroom. Not sure what temp it is in the stove room as I have never bothered with a thermometer. I know when I have been out in the cold a good bit I like it in the stove room.
    Chvymn99, Husky Man and brenndatomu like this.
  14. iowahiker
    iowahiker
    NE Iowa
    70 deg F. Add wood at 68 and reduce draft at 72. Burn down the coals to be at 67 at bed time. 60 deg F in the early morning is ideal and time to start another day of firewood...
    MikeInMa and brenndatomu like this.
  15. oldspark
    oldspark
    NW Iowa
    Sounds a lot like my day except when it's around zero with a south wind, then all bets are off, take what I can get.
    brenndatomu and Eckie like this.
  16. jrider
    jrider
    Thermostat is set to 74 during the day and 62 at night. All rooms the same temps with the outdoor wood boiler
    stuckinthemuck likes this.
  17. ironpony
    ironpony
    Mid Ohio
    66 degrees any warmer wifey starts stripping off clothes
  18. yooperdave
    Poor guy
  19. fire_man
    fire_man
    North East MA
    68 in the stove/family room is perfect.
    55 in the bedroom for good sleeping.
    When I buy a window air conditioner for the bedroom I have a hard time finding one that can be set low enough :loco: :crazy:
    jrider likes this.
  20. brenndatomu
    So does it ever get below 70 there? ;) :D :thumbs:
