Well this sucks
Discussion in 'Everything Else (off topic)' started by Screwloose, Jul 19, 2021.
  1. Eric VW
    Somewhere... in a GTG thread maybe.
    At least the aftermath.
  2. Horkn
  3. Eric VW
    I’m certainly glad you were there to witness that!
    :handshake:
    Now 2017 at walt ‘s.... that’s another story. :whistle::D
  4. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
  5. Eric VW
    Bring your helmet and leave your liver at home.
    :wacky:
  6. eatonpcat
    Let's do it Brother...I will blame 2017 on Barcroftb! But I will say I walked into a party where I knew no one and walked out with a bunch of folks that I will consider friends for the rest of my life!
  7. Eric VW
    It was epic, and you still walked out with brother status. :salute:
    :handshake:
    :D
  8. buzz-saw
    buzz-saw
    Ct.
    Good old Welch Pump.
    We have a trailer full of those at work that are no longer used. Anything we use now is direct drive or oil free.
    Those things will run forever and just keep on sucking.
  9. Screwloose
    Screwloose
    I have a 2 stage Edward's and a bunch of Gasts (can drive a deaf person nuts) also. I bought the Welch new a couple of years ago (still hard to sit down) because if you want to run one 24/7 they are so cool running and quiet. Like blowing bubbles with a straw.
    Why did you guys pull the Welch's in favor of the direct drives ?
  10. buzz-saw
    buzz-saw
    Ct.
    Most of the Welch pumps were older and had countless hours.
    When the lab I work in closed down the particle accelerator end of things there was not the need for as many pumps as there once was , most of the beam-lines and a lot of the experiments that were under vacuum no longer exist so with that most of the Welch pumps went into storage.
    Most of the experiments we have going on now are new so with that they opted for new pumps as well. Also many are concerned about oil so those have dry scroll pumps. Almost everything has a rough pump and a turbo pump in the system
  11. Screwloose
    Screwloose
    Ah I see. Turbo's..... thats a elegant precision machine for sure.
  12. buzz-saw
    buzz-saw
    Ct.
    Yes sir , not a cheap piece of equipment.
    Latest thing is mag-lev pumps , the rotor floats in a magnetic field to eliminate bearings and the drag from them. They do actually have a bearing but it is only used when starting up and shutting down but when running it's just floating in thin air.
  13. brenndatomu
    Price one out once...:bug:
    I just got a rude awakening from the Hoffman & Lamson blower rep (GardnerDenver) here recently...he thought he could save us some money by upgrading, but put pencil to paper, the ROI just wasn't there (in our case) so buh bye. Was interesting convo though...he said the same thing about things going to the mag bearings...he said similar/same as commercial jet engines...cool.
    Chvymn99 and PA Mountain Man like this.
