well pump/bladder tank question.
Discussion in 'The DIY Room' started by jetjr, Apr 7, 2015.
  1. jetjr
    jetjr
    Pa/Md line
    I remember reading that now after the last time I added air.
    the Joker, wildwest and fox9988 like this.
  2. jetjr
    jetjr
    Pa/Md line
    Well guys definitely the tank. Drained it and checked the air. Had about a whole 2 pounds in it. Got a new bigger tank but after going to 3 stores had to order the fittings. I want to make it so you don't have to disconnect everything if I need to change it again. Pumped the old tank up and hope it holds for a little while.
    Horkn, wildwest, the Joker and 5 others like this.
  3. papadave
    I had to pump up ours last year, but did it wrong and the pump ran way too often. I finally figured out how to do it the right way, and haven't had a problem with it since.
    I plan to check it again soon, just to see if it's holding.
    Horkn, basod and Stinny like this.
  4. milleo
    milleo
    Maine
    How do you pump it up the right way?
    TurboDiesel likes this.
  5. jetjr
    jetjr
    Pa/Md line
    Drain all the water out and than add about 2 lbs less than your kick on pressure.
  6. milleo
    milleo
    Maine
    Thank you...:thumbs:
    Horkn and wildwest like this.
  7. coal reaper
    coal reaper
    Nj
    hey guys, check out supplyhouse.com to order plumbing stuff like this. FREE RECIEVE TOMORROW SHIPPING on orders over $150. in stock items and it might be just the northeast for next day shipping. idk how they do it. i order all my plumbing and heating stuff from them. cheap too but expect some china items. they got well pumps and expansion tanks. i have been researching so i have an idea of what i need to get for when my system kicks it.
    they also have this, all in one package: http://www.supplyhouse.com/Boshart-TFP-2TK252UCV02NL-Union-Bronze-Tank-Tee-Package-Lead-Free
    Horkn, wildwest and TurboDiesel like this.
  8. TurboDiesel
    Never saw the union in the tee. Very nice!
    Horkn likes this.
  9. jetjr
    jetjr
    Pa/Md line
    Wish I would have seen that package. Basically what I'm doing with mine, just had to piece it out.
  10. the Joker
    the Joker
    Tn
    i just had to replace my pump , and i fixed some plumbing issues from the previous owners , i drained and pumped the pressure tank to 28 psi for a 30/50 setting and bam it worked perfect , i can run about 8 gallons before the pump kicks on .
    Horkn, wildwest and fox9988 like this.
  11. jetjr
    jetjr
    Pa/Md line
    I replaced the pump not that long ago. Pumped the tank up a while back and just had to do it again. Got all the stuff just need to find thetime.
    Horkn, the Joker and wildwest like this.
  12. jetjr
    jetjr
    Pa/Md line
    Out of curiosity when I replace the tank should I clean the system? If so how, or can I just let it run a while? Planning on doing it this weekend.
    Horkn likes this.
  13. Horkn
    I think outside of just letting it run. There's not a lot to do to clean it. My warer system gets black sediment crap only on the galvanized pipe sections. My dad said it's from a galvanic process. Whatever it's gross. I removed as much of that old pipe and replaced it with copper when I put a shut off ball valve after the tank when I bought the house on 08.
  14. coal reaper
    coal reaper
    Nj
    Yup. I helped a buddy with his. Just kick the well pump on and off a few times. Not much else you can do i dont think. We used a wet/dry vac to catch everything.
    Horkn likes this.
  15. jetjr
    jetjr
    Pa/Md line
    That's what I was thinking just let it run a while. I wasn't sure if it was recommended to do anything to clean the tank. Guess it's like replacing a piece of pipe you don't clean everything after that.
    Horkn likes this.
  16. TurboDiesel
    you can sanitize your well and the complete plumbing system pretty easy with bleach
    I use to do it every year
    Horkn likes this.
  17. jetjr
    jetjr
    Pa/Md line
    I just did it when i replaced the pump. Is it worth doing again with a new tank.
    Horkn and Stinny like this.
  18. TurboDiesel
    There's probably no need if you just did it
    just flush the lines like others have mentioned, should be good
    I usually just pour some in the well and run the water till I can smell it. let it sit a short while then run water till the smell goes away.
    I will hook a hose at the tank and throw it outside to run. don't want the bleach in the septic tank
    Horkn and jetjr like this.
  19. jetjr
    jetjr
    Pa/Md line
    TurboDiesel or anyone else that knows. Here's my new problem. Once every so often I have to go down and click the pump on with the silver handle. The pressure gauge shows 0 but as soon as I hit the switch it jumps up to operating pressure. What would cause this? Contacts sticking maybe?
    Horkn likes this.
  20. Horkn
    Yep, your switch is probably needing a cleaning, or maybe just needing replacement.
    They are under $40. IIRC, they were right around $20.
    fox9988 and 343amc like this.
