Welding Chainsaws.
Discussion in 'Chainsaws and Power Equipment' started by Mag Craft, May 24, 2017.
  1. drf255
    drf255
    Strong Island, NY
    Those welds look great MagCraft.
    I'm a hobby guy to, have a good inverter tig.
    Mag is the most difficult to weld by far for me. I learned to Tig on aluminum, which is supposed to be a no-no.
    Here's an AV mount repair I did.
  2. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Is this your MO?
    The Doc is in
  3. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    You're probably super talented, but jumping into other welder's threads... well... I've seen this before:
    Eric VW likes this.
  4. Boomstick
    Boomstick Banned
    Saratoga county ny
    Looks to be a bunch of undercut on that top weld.
    There are many many production roles where that would not be acceptable.
    Looks like it's pretty thick aluminum.
    Also all that granular weld on the end of the bead is preventable if you don't leave craters at the end.
    BuckthornBonnie likes this.
  5. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Boomstick= Will
    drf255 likes this.
  6. Mag Craft
    Mag Craft
    South East Wyoming
    This thread is not about welding, it is about the restorations of old saws where parts are no longer available and to show what the possibilities are when it comes to repairing some of the old magnesium.
    I want people to see that if a piece of mag is broken that it can be repaired and made to look original again.
    I would also like to say if you have never welded on the cast magnesium that is used in chainsaws well you should try it.
  7. Mag Craft
    Mag Craft
    South East Wyoming
    drf255 looks like a pretty good job. Nice.
  8. scotts_4x
    scotts_4x
    paso robles, ca
    undercut? there is white discoloration at the toe of the weld, that's oxidation. and it's 1/8x3 inch flat bar.
    scott
  9. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Exactly. Let's go further--- it's about fixing something that is trashed. Something that you can now use to cut wood and heat your house.
  10. Scotty Overkill
    I was ready to certify for TIG in aluminum and stainless many moons ago, but my employer at the time didn't want me certified as it would've bumped me to a higher paygrade....I ended up quitting that chitty job and got a good job....
    I know full well what it takes to TIG weld different ferrous and non-ferrous metals, the non-ferrous stuff can be tricky. I have never welded cast magnesium, I know what cast aluminum welds like and you guys are right, contamination (dirt or even casting flaws) can make it tricky to weld. Throw in the flammability factor of mag and you've got a tricky project. Kudos to you, Mag Craft. Your work has my full respect. Enough so that I trust you 100% to fix my coveted BP-1.....
  11. scotts_4x
    scotts_4x
    paso robles, ca
    some sand cast aluminum transmission housing repair I did today. just in case my FHC post count wasn't enough credibility. :yes:
    -scott
  12. Eric VW
    :handshake:
    Well said, Mag:yes:
    brenndatomu and Mag Craft like this.
  13. drf255
    drf255
    Strong Island, NY
    How bout Aluminum Repairs?
    This is a 2100 jug. Marshy IIRC.
    I had to free form the lost part of the second fin.
    This was prior to getting a small blast cabinet, which makes the finished product look much better.
  14. Marshy
    Marshy
    CNY
    That was actually a 285 cylinder, moot point I suppose. Saw runs great and I'm thankful for your talent and generosity. Were you at the NY GTG?
    BuckthornBonnie and Eric VW like this.
  15. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    eatonpcat and Eric VW like this.
  16. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    I'm thinking it doesn't need it, but that's a big area without fins so who knows.
    drf255, eatonpcat and Eric VW like this.
  17. Eric VW
    :eek:
    West System epoxy.....:rofl: :lol:
  18. drf255
    drf255
    Strong Island, NY
    I personally would run that as is. Likely not worth the work.
    If your concerned about the cooling, an easy thing to do would be to add some metal to #3 and #5 fin. That would be counting downwards and calling the intact top fine #1.
