Welcome Pellet Burners!
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by DexterDay, Oct 3, 2013.
  1. will711
    will711
    Pocono Mts.
    Nice to have good neighbors with Beer:)
  2. jtakeman
    Yep, He knows the garden shed is open if he needs something.
  3. 343amc
    343amc
    Northeast Lower Michigan
    When I first moved into my house I was doing a lot of remodeling and removing overgrown bushes, etc, so there was always plenty to burn in the fire put. Whenever I had a fire outside my neighbor showed up with a 12 pack of beer. Worked out good if I was low on beer and in no shape to drive to get more.
    We went back and forth across the field with beer whenever we saw the other having a fire outside for a couple years until they moved.
    will711 likes this.
  4. subsailor
    subsailor
    Winthrop, Maine
    OK, that get's you through Sunday, then what??:drunk:
  5. jtakeman
    Beg the wifey for more. Err, I mean demand more! :emb:
    eatonpcat, gbreda and subsailor like this.
  6. Gasifier
    So when you guys talk about your stash. Are you generally talking about your pellets or your beer?
    Never mind. I know the answer."Yup."
    will711 and gbreda like this.
  7. gbreda
    gbreda
    NH
    I KNOW she has cast iron skillets and aint afraid to use em
  8. jtakeman
    Well Mrs Bear sent her something she likes better and can swing harder! Dang I swear that rollin pin hurts worser! o_O
    eatonpcat and gbreda like this.
  9. Gasifier
    Hey. Questions for you guys. I am going to start the install on my pellet stove tonight. England's Stove Works, Model #: 55-SHPAHL. I am deciding if I should install a thermostat to it. I read in the manual that it may shorten the life of the igniter if you use this and place it in the ON/OFF mode. So, would it be better to just set the stove on the low setting and not even bother with a thermostat, or install thermostat and set it on HIGH/LOW setting so it does not keep shutting off and turning on the stove. Did I explain that right?
    The camp is large enough and insulation factor is not that good where I could probably just leave it on low when the cooler weather gets here. If that ever happens. Plan on keeping it a hair above 40 so that the electric heat does not come on which is going to be set at 40.
  10. jtakeman
    Explained it perfect, Sure you can just use the hi/low mode. The stove will use its lowest feed rate to maintain a pilot fire for the next time it calls for heat. I can't do this in the shoulders, But it does fine for me once it gets cold enough to where the pilot fire doesn't continue to raise the house temps.
    gbreda and will711 like this.
  11. Gasifier
    So in the manual it shows where to hook up the thermostat wires if I install the thermostat. But what if I decide to go with the remote thermostat? (AC-3003) Does that still have wires you put in the same spot and then it uses something to transmit remotely to the thermostat? Says thermostat takes 6 AA batteries.
  12. DexterDay
    DexterDay Administrator
    Northeast Oh
    I wouldn't worry about the ignitor.
    I worried about the one in my Quad and it was On/Off only. No High/Low operation. Over 5 yrs it kicked on thousands of times.
    In the shoulder season, I would run On/Off on the stat, and in the dead of Winter run High/Low.
    With a good swing of around 3°, the stove won't shut in and off as much anyways. The smaller the swing, the more On/Off cycles you wilk have. When running On/Off its best to run the largest swing you can stand (4° is what I like personally).
    Then when running Hi/Low, you want the opposite, because the stove will always be running, and you will need more heat? I would run a tighter/smaller swing (1°-2°). This will help maintain a warmer and more even temp tonight.
    Either way, a stat is always better. There is nothing like waking up at 3am and the house being 82° because you just tried to set it and forget it!! :)
    I vote a good stat. Lux 500 or 1500 is a good choice. I have a touch screen Hunter that only allows 3° max on swing, but 3° isnt bad and its also connected to my Pellet furnace. The Enerzone has the Lux 1500 (still need to hook it up).
  13. Gasifier
    What about if I decide to go with the remote thermostat? This would make it simple so I would not have to run a wire. I could mount thermostat wherever I wanted. Correct? How does the stove read from the remote thermostat?
  14. DexterDay
    Northeast Oh
    There is still a reciever. It has about 1'-2' leads. It could prob be tucked away inside the back of the unit.
    I have a SkyTech (currently hooked to Enerzone) and I like it. But it has its flaws. It works best when the remote is actually hung up. Rather than laid down on a table (low lying table and cold surface, will male the stove way overshoot the actual temp).
    I made a spot to hang mine on the wall with Velcro. Then framed around it with corner round. It looked like it belinged there. Since I bought the Lux 1500, I have since fixed that spot on the wall and painted the room. Sorry. No pics..
    So when I install the Lux (hopefully soon) I will have a million questions for Jay!
    What model remote system are you looking at?
  15. Gasifier
    Don't know. I have a Lowe's, where I bought the stove. They have a Lux-7-day programmable thermostat on sale now for $59 dollars. Don't know that I need a programmable one. I just talked to a guy there and he says they do not have any wireless ones there except for the NEST. ? I have seen those before but I think they are expensive. I was hoping for something wireless so I did not have to run a hardwire from the stove to the thermostat. I suppose I could though if that meant a lot cheaper in price. Just need something that I could set it and leave it at say 45 deg. We are not there most of the time. But the wireless are probably all programmable. Eh?
    I suppose it would not be too hard to run a wire straight down through the floor behind the stove, then across the basement floor joist and up through floor to where I wanted it on the wall. But would probably end up having to run some crappy looking wire mold up to the thermostat. Don't want to get into drilling up through finished wall and fishing wire and all that. Can I just by any brand of thermostat and do they have one I can get that would be wireless? So I could put the wires into the stove where it needs them and then mount thermostat on wall that will "talk" to it?
    Should I put the thermostat in the same room as the stove? Or in the center, main room of the camp? The stove is in the front (living) room where we sit most of the time when there. The main room is actually the center of the camp where the kitchen and dining area are. This is the biggest room with cathedral ceiling.
  16. Gasifier
    I also have a Wal-Fart nearby and a hardware store.
  17. DexterDay
    Northeast Oh
    If your looking at Remote, its gonna cost more ($100 +), but they have programmable and non programmable.
    I have a Skytech 3301. Its not programmable. It has a very large swing (from 1°- 6° or maybe 8°?) But it was about $120 IIRC?
    Look up Skytech.
    Otherwise, a regular stat cant be set up for remote operation. It must be one deaign to accept the signal from the receiver.
  18. Gasifier
    If I get a remote should I put it in the room the stove is in or in the next room in the center of the camp? Just curious what you think about that. Tough to explain the layout of the camp. Front room, I think I posted pic of the stove in the room before, is about 11 feet wide and 27 feet long. Then the next room is the big room in the center of the camp. That is about oh at least 20 x 20 with cathedral ceiling.
  19. DexterDay
    Northeast Oh
    Instead of going at length here. Start an install thread of your stove and we can discuss it there.
    Otherwise this good info will be lost in the Welcoming Sticky. :)
    jtakeman likes this.
  20. jtakeman
    Pellet stoves don't heat evenly like a furnace. It will be warmer by the stove than the area's that are well away from it! If you go remote or wall mount, I'd keep the stat where you are worried about items freezing. Or at least monitor the area's that could freeze. And adjust the temps so that area doesn't get to low.
