Weight of a Cord of Rounds
Discussion in 'The Wood Pile' started by iowahiker, Mar 28, 2020.
  1. campinspecter
    campinspecter
    This Hemlock log !
    Fit in here ! No unhappy springs or bulging tires .
    MikeInMa, MAF143, brenndatomu and 6 others like this.
  2. Mwalsh9152
    Mwalsh9152
    Pelham NH
    No, it just naturally sheds whenever you load it, as Midwinter pointed out to me. Every time I loaded in her driveway, I left a calling card apparently.
  3. billb3
    Like automotive epithelials for an automotive forensic detective show .
    eatonpcat and Mwalsh9152 like this.
  4. buZZsaw BRAD
    you made it fit and very nicely may i add! Nice job campinspecter :thumbs:
    Very picturesque with the view and frosty cover!
    campinspecter likes this.
  5. buZZsaw BRAD
    your new FHC nickname will be "Rusty"! :rofl: :lol:
  6. buzz-saw
    buzz-saw
    Ct.
    LOL = nope ; not even close to overloaded . Tires aren't inside out in that picture , toss on a few more next time. Don't be scared :eek:
  7. buzz-saw
    buzz-saw
    Ct.
  8. fezdawg12
    fezdawg12
    Elko, Nevada
    Above the lumber/ladder racks IS overloading.:rofl: :lol:
  9. moresnow
    moresnow
    How far are you travelling? Y.R. Forrest to north of Waukon by chance? I used a Astro and then a Venture for a couple years. I'd load them N.S. even up to the windows (all seats but the fronts removed) and taper my rounds up towards the center after that. Guess I should have taken more pics:whistle: Tires were always my concern. I just took back roads ultra slow! Wish I still had a van for hauling stuff around. Easy to load. Good mileage. Cheap maintenance etc.
    We will certainly need pics here.....
  10. Pricey106
    Pricey106
    Northeast PA
    Tire bulge is my main concern...but I usually just watch how far she drops...maybe overloaded a few times....lol. 20190327_121849.jpg 20180915_163909.jpg First pic is all green silver maple and ash. Stacked to the gills, close to home. Second pic is green sugar maple, heavy stuff, farther from home, and 2 miles down a rough dirt road.
  11. stuckinthemuck
    stuckinthemuck
    iowahiker could you just bring along a bathroom scale and get a weight before you load each round? Seems you could set the scale so the tare weight is a round number and then calculate from there. For me, I’d adjust the scale so when I step on it, it says 200 lbs. Then if I step on with a round and it says 260 lbs, I know that the weight of the wood is 60. Could keep a running total of the wood weight in your head. Once you get a good true 1000 lbs load, measure the height of the bumper off the ground and make future loads match that height.
  12. buzz-saw
    buzz-saw
    Ct.
    I did a google search the other day and found a calculator for weight of rounds , You enter diameter , length and wood type.
    Granted you can't do this for every round as you load but can get the general idea for an average log prior to loading.
    It adds up faster than I would have imagined.
  13. moresnow
    moresnow
    That's the spirit. Load er up good! If your ball hitch aint dragging your good!
    Pricey106 and campinspecter like this.
  14. iowahiker
    iowahiker
    NE Iowa
    I am good with numbers and carry a tape measure to measure my stack of wood in the Astro, did LxWxH, and calculated the share of a cord weight very quickly for each wood specie. The cord weights I was using are wrong for stacks of rounds since they use 80-85 cubic feet of wood in a cord. Doing the same LxWxH times 0.8 (0.78 rounded) times 60 pounds per cubic feet for bitternut (55 for sugar maple, 45 for white ash) is actually easier math. Oddly, I can remember numbers but not peoples names.
    stuckinthemuck and campinspecter like this.
  15. Casper
    Casper
    Not sure what all the calculations total but it sounds like the solution is a dump trailer.
    x=dump trailer
    y~2=diesel truck
  16. Mwalsh9152
    Mwalsh9152
    Pelham NH
    This is how you load an SUV! It goes to the front seats like that too. About a half cord.
  17. brenndatomu
    Ford tough baby! :thumbs:
    Not only are the springs frowning, the bump stops are too! :startled:
  18. Meche_03
    Meche_03
    Missouri
    This is why I'm looking for a 1 ton or larger truck. I drive a 99 F150 with a 6.5 ft. I have hauled wood a foot over the bed rails several times and level with the bed rails so the wood fits under a bed cover.
    To compensate for the potential weight I have 8 ply LT tires on it. I wore out the factory rear springs and replaced them with the highest weight capacity springs offered from the factory. Spring rate was 1180# per spring set and now its 2200# per spring set.
  19. brenndatomu
    No idea what the weight is (heavy!) but this is (4) ~30"-ish Red Oak rounds cut to 20" long and then quartered, plus some chunks from cutting the stump flush (the chunks on top at the back) made my '03 F250 8' sit about level...as opposed to its normal nose down attitude
  20. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Not from where I'm standing.
    Haftacut, buzz-saw and buZZsaw BRAD like this.
