Weed and Feed
Discussion in 'The DIY Room' started by Grizzly Adam, Apr 21, 2017.
  1. Grizzly Adam
    Grizzly Adam Guest
    The time period on the pre-emergene will expire in three weeks, same time the weed n feed cycle is done. I am hoping to get some seed spread at that time before it gets too hot, otherwise the lack of grass will allow weeds to run wild again.
  2. billb3
    They keep the golf courses nice and green though.
    will711 and concretegrazer like this.
  3. Babaganoosh
    Babaganoosh
    Jersey Shore
    What preemergent did you use. It is supposed to leave a barrier in the soil that lasts a few months.
    If you want to reseed try bringing in some fresh topsoil. I did that in some small spots and it worked well.
    MasterMech and concretegrazer like this.
  4. Grizzly Adam
    Grizzly Adam Guest
    Surflan AS. Its been down for a while already.
  5. concretegrazer
    concretegrazer
    Southwest MO
    Wait 90-120 days from application before seeding. The longer the better.
    MasterMech likes this.
  6. Grizzly Adam
    Grizzly Adam Guest
    Thx.
  7. lukem
    If it weren't for the fill it would be impossible to broadcast. Same reason they mix in lime for the big field broadcasters. Trying running 80lbs of seed to cover 40 acres with a Teragator without filler.
  8. chris
    chris
    SE WI
    Oh I understand the need , just hate paying for 10% of useful product based on a 50# bag. I get concentrated liquid- add my own water. Sometimes I get lucky and can find stuff in crystalline form- then add water. Similar to how we use to handle manure from all winter- thin it out with water and spray it on fields- more uniform coverage don't need a lot of tilling/plowing afterwards either .
  9. brenndatomu
    Exactly.
    I want the "weed", but not the "feed". That crap grows fast enough the way it is, no sense feedin it! :hair:
    Course, my theory is if its green, mow it and call it lawn :whistle:
    Chvymn99 and eatonpcat like this.
  10. Grizzly Adam
    Grizzly Adam Guest
    My soil test kit is coming today, going to figure out all my levels and see what amendments I need. Going to do a jar test when I am at it.
    Babaganoosh and MasterMech like this.
  11. MasterMech
    At phenomenal cost. Most folks have no idea exactly how much $$ goes into a single golf green annually. And the harder your climate is, the more $$ you sink in grass farming.
  12. chris
    chris
    SE WI
    Golf course - greens are big business- Iirc there PHD's just for that.
  13. MasterMech
    Post-Hole-Diggers are ok but I prefer a more traditional cup-cutter. :D:cheers:
    concretegrazer and brenndatomu like this.
  14. Grizzly Adam
    Grizzly Adam Guest
    I've been doing some working on the mower. I had to replace a damaged axle up front and went ahead and installed a new belt and a mulching kit while I was at it. I just got done getting the aerator assembled too.
