Weather Geeks Unite!
Discussion in 'Everything Else (off topic)' started by SKEETER McCLUSKEY, Oct 2, 2015.
  1. Grizzly Adam
    Grizzly Adam Guest
    Much of your problem is that the full code isn't there. It cuts out just as its getting to the img data.
    Chazsbetterhalf, wildwest and Eric VW like this.
  2. raybonz
    raybonz Moderator
    Carver, Mass.
    Will turn on laptop and get code for you Adam.
    Chazsbetterhalf and wildwest like this.
  3. ChuckinMichigan
    ChuckinMichigan Banned
    Southeastern Michigan
    I'm one of them too. (Weather Geek) :yes:
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    39° partly cloudy
  5. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  7. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    43° heavy fog
  8. savemoney
    I've used a weather stick for many years. Very accurate. No batteries. Not imported, Not plastic. Not techy enough for some.
    it is sunny out now, but the stick is pointing down, Looked up the forcast, yup. sure enough, rain is predicted for tomorrow.
    raybonz and wildwest like this.
  9. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    44° for a low last night,56° right now with a strong SE breeze
  10. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    severe t-storms in eastern pa right now
  11. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  12. raybonz
    raybonz Moderator
    Carver, Mass.
    Skeeter add a weather sticker and we will always know your weather..
  13. raybonz
    raybonz Moderator
    Carver, Mass.
    Are you in Texas or Pa? I am confused..
  14. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    the weather stickers are only a generalization......if i type in my zipcode to noaa it pulls current conditions from the airport which is 22 miles from here and a different elevation:loco: :crazy: i can link to other closer stations but still miles away and different elevation/conditions,thats why i have my own station;) i will check into linking my own info but i dont think i can being on satellite i cant stream live info,it uses up all my stuff.
  15. raybonz
    raybonz Moderator
    Carver, Mass.
    The info is only updated occasionally not real time.. Are you in Tx or Pa?
  16. GranpaJohn
    GranpaJohn
    Central Maryland
    For those thinking of a Davis system...
    I've been running a Vantage Vue since they first offered them about 5 years ago. A couple months ago I mailed it back to them for refurbishment. This is where they charge $100+$20 shipping and replace parts that would cost more that. My unit's dew point sensor had failed badly, and DP is our favorite use for the Vue. So, anyway, it seems to have worked out, and Davis has a reputation for good customer service.
    I consider it impossible to get accurate high temperatures in sunshine with most modern Stevenson screens (radiation shields), and the Vue is worse than most, so siting is very important.
    The console and everything is a really cool gadget that is worth the (high) price.
    raybonz likes this.
  17. raybonz
    raybonz Moderator
    Carver, Mass.
  18. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    32° this am with frost
  19. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    i bought a second console for my vantage pro2,its in my office in the celler of the house,the main station out in the shop transmits wireless to it works great!
    raybonz likes this.
  20. GranpaJohn
    GranpaJohn
    Central Maryland
    not sure I followed that, but...
    ...I had so much endless rambling in my original post that I shortened it. So, might not have made much sense or been much use.
    raybonz likes this.
