Weapon of Mass Destruction
Discussion in 'Axes, Mauls, and Hand Saws' started by UncleJoe, Feb 28, 2015.
  1. Horkn
    Not unless you like rotator cuff damage.
  2. Jon_E
    Jon_E
    Southwestern Vermont
    My father has a Sotz Monster Maul. He's 76 now, still uses it occasionally. I asked him if he would give it up (I wanted it) he said no, so I bought a Bailey's "Mega-Maul", welded a 36" stainless steel handle on it and now I have my own.
    I like taking it on Boy Scout camping trips and having the Scouts use it to split firewood for the campfire. :eek: :rofl: :lol:
    thistle and Boog like this.
  3. jetjr
    jetjr
    Pa/Md line
    I just noticed my 80 some year old neighbor has one too. If I can get around like he does when I'm that age I'll be tickled pink.
    thistle, Stinny and Boog like this.
  4. Unicorn1
    Unicorn1
    Amarillo, TX
    I see these at flea markets, just not sure I want to swing one:bug:.
  5. UncleJoe
    UncleJoe
    SC Pa
    It's not as bad as one might think. Lift it up and let the shear mass do the work. I split that entire tree with it and while you definitely knew you were using it when you're done, it really does do most of the work for you.
  6. bryanr2
    bryanr2
  7. bocefus78
    bocefus78
    Indiana
    I use mine for beating t posts in the ground and brake rotors off the truck more than anything else.
  8. Jon_E
    Jon_E
    I used both my Sotz knockoff and my True Temper "Total Control" 6 lb maul last weekend to split some ash. The monster maul was a "one swing, one split" deal, blew the 14-16" rounds in half in one shot every time. Swung that enough times, and then switched to the 6-lb maul, and I found my swing speed with the six-pounder had increased dramatically. All of a sudden you wonder where all that weight disappeared to.
    I did try out the monster on a piece of very twisted, wet and partially frozen poplar a couple weeks back. I could not touch it. Took a wedge and a lot of smacking with an 8-lb sledge to get through that poplar. I gave up at that point.
