We are a sick bunch…
Discussion in 'The Wood Pile' started by FarmerJ, Dec 28, 2022.
  1. Biddleman
    Biddleman
    River Hills of Pennsylvania
    Township wants to raise property taxes but does nothing to protect the value. Punish those trying to improve their homes and property. Its enough to make one spit nails.
  2. FarmerJ
    FarmerJ
    Minnesota
    Weekend we had back in late October ‘22.
    I was able to unload Saturday around noon. So instead of going to a hot, no shade parking lot. We sat about 300 yards from the north end of the Pensacola airport runway.
  3. FarmerJ
    FarmerJ
    Minnesota
    I about doubled the pile test. Saved out some 24” 4’ logs to make Timbers with. Started laying out some splayed for that first cut on the chainsaw mill. 416AAD77-4E0C-43E2-AE71-24EC8089DCA2.jpeg 29FA8F0F-5C0C-4E15-9C5E-B80B91550E77.jpeg C53314BE-91F4-415E-B6F2-5C70DB480754.jpeg
    even started playing with YouTube for yet another firewood channel. It’s a work in progress. The phone shutoff in 8 minutes. Seems I need to replace the battery. And the drone only lasted 9 minutes in the January cold of 25*F.
    called the local hydraulic shop. Asked them about the dump valve on dude ranch DIY splitter. Ended up ordering a prince auto-cycle valve before even ordering the splitter.
    taking a road trip today to go look at the wood project with the drone and see my oldest for a bit before heading out on Monday. Sounds like I’m pre-loaded already for the entire trip for 18 days and I haven’t even started packing the truck.
    Monday I load for Victoria TX and then make my way to Chicagoland…. Guess I get a little bit of thawing out anyway.
    T.Jeff Veal, Horkn, jo191145 and 4 others like this.
  4. FarmerJ
    FarmerJ
    Minnesota
    There’s some beeeg treees in that stand.
    14CA29F2-ADC7-4DF2-95A3-21196B919491.jpeg 3AC67DAD-E0C4-4897-ABC2-C509C740F004.jpeg
    bunch of wood is under a lot of snow…
  5. buzz-saw
    buzz-saw
    Ct.
    Looks cold in those pictures.
  6. FarmerJ
    FarmerJ
    Minnesota
    There’s about 3’ on the ground and the drifts are double that. By our place they came in with a 5 yard pay loader and pushed the snow back from the road because it was drifting about 4’ deep across the road.
    never took pictures but where I want to stack and store split wood is an 8’ deep drift. Kinda wishing I had now.
  7. buzz-saw
    buzz-saw
    Ct.
    Minnesota correct?
    I was out there in January a few years back for work. Froze my azz off. And I was working inside. Just walking from the building to the truck gave you a shrinky - dink”
  8. FarmerJ
    FarmerJ
    Minnesota
    Correct. The fact I’ve got 6-7 cord in my back yard I’m plugging away at gives pause to how nuts we are up here.
    I waited until we got a 2” snow fall to cover the ice for traction from that spit of rain/ drizzle/ winter mix we had.
    T.Jeff Veal, Horkn, GMB77 and 2 others like this.
  9. FarmerJ
    FarmerJ
    Minnesota
    Left Monday and got home about 1 pm today. 3000 miles. I was supposed to be gone until around 2/9. But when a round takes me right back to the house for the weekend, I’ll take it.
    Last weekend I put a 100W solar panel on the dump trailer to see how it would do for charging the battery. Even at -6*F, the box went up faster than last weekend at 30*F.
    Panel and charger are from harbor freight. This panel actually took the week to see how it would work.
    Got the 100W solar panel from HF for the camper last fall. Haven’t set it up yet, so I’ll have to get a replacement panel for that panel now. Likely get a couple more too so I can hook up to the semi and charge with 10 amps too.
    this will likely turn into a 4-panel array though for the camper.
    Just hanging it with a couple small hooks. Take it off when actually using it. 9C393EE8-AE2C-42E6-B016-AA8A1F858AAC.jpeg
    T.Jeff Veal, Skier76, Horkn and 3 others like this.
  10. Softwood
    Softwood
    Central WI
    Sure, blame it on the cold..:rofl: :lol:
    T.Jeff Veal, Biddleman, Horkn and 4 others like this.
  11. jo191145
    jo191145
    Ct
    Ain’t that the luck? I bought a cheap helmet cam for my snowmobile. It couldn’t handle the speed, bumps or rapidly changing scenery. Movie looked like crap even after I washed it through correction software numerous times.
    So I spent a little more on a go pro. Battery died in the cold so fast it wasn’t worth it. Just can’t win sometimes.
  12. FarmerJ
    FarmerJ
    Minnesota
    It’s a DJI Mavic Pro. Summer I can get about 30-35 minutes of flight time.
  13. Haftacut
    Haftacut
    Rives Junction, MI
    I hope to be that “bad” one day too amateur cutter ! Sounds like a terrible problem
  14. FarmerJ
    FarmerJ
    Minnesota
    This is what the panel is putting out for amperage after running the box up and then down. It stopped charging entirely in about 2 minutes.
    so it would have been interesting to see the day after I hooked it up what the charge rate was.
  15. FarmerJ
    FarmerJ
    Minnesota
    Huh, we need to build a solar system for the property/ camper. REC is making it really easy to want to go solar by saying it’ll be $6000 by the time we hook up the house.
  16. Horkn
    Chitty wall
  17. FarmerJ
    FarmerJ
    Minnesota
    How Can a guy do this without buying a $1500 grinder?
  18. FarmerJ
    FarmerJ
    Minnesota
    Bought a quad axle of cherry/hickory today. Be delivered on Monday.
    another 6-7 cord load. This should be all I need for a wood stand for the summer.
    now to find 60 pallets for 10-11 cord of split wood.
  19. Horkn
    If you come to SE Wisconsin, I'll hook you up. We've got plastic pallets and probably some IBC totes.
  20. FarmerJ
    FarmerJ
    Minnesota
    I do have a buddy in lacrosse I need to go harass.
