We are a sick bunch…
Discussion in 'The Wood Pile' started by FarmerJ, Dec 28, 2022.
  1. T.Jeff Veal
    metalcuttr, eatonpcat and brenndatomu like this.
  2. T.Jeff Veal
  3. FarmerJ
    FarmerJ
    Minnesota
    That’s two measured and stacked cords in the back. 4X4X8.
    even if I were to scoot everything together and put a fourth tote in there, I’m adding 8’ to the foot print for 2 cord put into IBC totes.
    That extra 8’ would let me stack a 3rd cord.
    another strike against totes.
  4. FarmerJ
    FarmerJ
    Minnesota
    Thoughts? Suggestion?
    opened up the cylinder tonight to find..
    while the working ports are 1/2” NPT.
    the holes in the actual cylinder are only 5/16” at best.
    metalcuttr and brenndatomu like this.
  5. brenndatomu
    Yup, looks like the exact same setup I have on mine...actually looks like about same cylinder, only painted silver instead of red...I used a drill bit to check port size...a 3/8" fit in easily...next size up (don't recall the size) not quite.
    You could have a hydraulic shop upsize the holes and the hose connection to accommodate larger lines and pump...but when I called about that the other day they quoted me a price $1-200 more than just buying a new cylinder (even after shipping) with 3/4" fittings and a 2.25" rod (for faster returns)
    https://ruggedmade.com/welded-log-s...d-od-1-5-rod-end-5-rod-bolt-clevis-mount.html
    You can still get some gains without enlarging the holes using a larger pump and lines, but it will still not be as fast as it could be, and it'll make the oil hotter, and faster too.
    They hot rodded one here, went from a 13 to 28 gallon pump, speeded 'er right up, but I bet she'd sure get hot on a warm day! What works to prove a point on 1 video is not the same as what works long term in the real world
    metalcuttr, T.Jeff Veal and FarmerJ like this.
  6. FarmerJ
    FarmerJ
    Minnesota
    I’m leaning towards tearing it down and boring out the ports.
    they want $400+ to change the bungs.
    for that price, toss this cylinder to the side and get the rugged made 4”/ 2.25” rod and that would likely still need to have the holes enlarged.
    they came back and told me a 5” cyl/ 4” rod X 18” long with 3/4” rod port and dual 1” cap ports would cost me $1900.
    wonder if I could just buy a 35SHO cylinder and what it would cost.
  7. FarmerJ
    FarmerJ
    Minnesota
    Bucking wood the easy way and running a 500i for the first time ever.
    I’d love to see a 50cc fuel injected saw.
    This should have been between the name brand vs off brand video and the first wicked wedge video.
  8. FarmerJ
    FarmerJ
    Minnesota
    Rugged made sent me a picture of their working port on a 4X24/ 2.25” rod.
    pretty sure if the rod ends match, I’ll just be replacing my cylinder and putting the Prince auto valve on it too.
  9. brenndatomu
    So it looks to be wide open?
  10. FarmerJ
    FarmerJ
    Minnesota
    Yop. That’s my take too.
  11. brenndatomu
    If you are going to order it, I have a 5% discount code...
  12. FarmerJ
    FarmerJ
    Minnesota
    My endeavors this past 45 days…
    did this prior to leaving early august.
    did this yesterday
  13. FarmerJ
    FarmerJ
    Minnesota
    I REALLY like the wolfe ridge 35SHO box wedge.
  14. brenndatomu
    Yeah that looks like it works pretty well...still makes plenty of kinlin though...I suppose there's no getting away from that when you move beyond a single stroke/single split machine
  15. buZZsaw BRAD
    Very True. While working with jo191145's multi wedge splitter on Sunday i noticed the volume of sheds, shards, and kindling bits it produced, but man with the the right type of logs it spits out splits fast.
  16. FarmerJ
    FarmerJ
    Minnesota
    All the trash from just 5 1/2 cord of hardwood and a box store splitter.
  17. jo191145
    jo191145
    Ct
    That’s not splitter waste that’s landscape material LOL
    T.Jeff Veal, metalcuttr, Chaz and 4 others like this.
  18. FarmerJ
    FarmerJ
    Minnesota
    FB MP find.
    he even delivered it to me…
    Rugged made splitter work table.
    now to mod it for my Country Pro.
  19. buZZsaw BRAD
    Nice find. I need to make a bigger table for the splitter i use.
    T.Jeff Veal, metalcuttr and FarmerJ like this.
  20. Stephiedoll
    Stephiedoll
    Omaha, NE.
    You will get a lot of mileage out of those tables, or table it it's only one.
