We are a sick bunch…
Discussion in 'The Wood Pile' started by FarmerJ, Dec 28, 2022.
  1. FarmerJ
    FarmerJ
    Minnesota
    Went out and did some more splitting this morning. I want to say this stuff is red oak and it has a LOT of moisture in it. That’s what’s getting my gloves all wet.
    I need to turn the fill cap on the hydraulic tank. It’s aimed right at the engine at the moment.
    mom likely going to order a wedge and a log lift from rugged made and convert this to a push through machine with a log lift. I’ve already got the 6-way wedge, having the 4-way will be a major improvement.
    it’s taking 11-15 cycles to split some of the larger rounds at 8-10 seconds a cycle, the output leaves a lot to be desired.
    the splitter is doing for me what I want though. Letting me get this first 11-12 cord of ash and cherry split and sellable in bundles and a roadside stand. Should let me fund a more capable splitter.
    ETA-
    the logs that are single layers next to the trailer are frozen to the ground in ice. I’ll let Mother Nature release them and then get them split.
  2. Warner
    Warner
    I have the same splitter can’t say I have ever had hydraulic fluid spray out the vent.
  3. FarmerJ
    FarmerJ
    Minnesota
    I filled mine Friday when I got it home from the store. It wouldn’t surprise me to know I over filled it but still. I need to rotate it so it’s not going to vent oil towards a hot engine.
  4. FarmerJ
    FarmerJ
    Minnesota
    High output oiler and Big Bore cylinder for the G660.
    came in just in time for my going back out for another 3 week.:confused::headbang:
    not like I don’t have more than one project that all need to be done in that time period.
    this will have to be cleaned up and polished a bit. There’s some pretty decent joint lines and flashing I want to clean up.
    flashing on the piston windows
    Joint line on the intake to remove.
    T.Jeff Veal and brenndatomu like this.
  5. FarmerJ
    FarmerJ
    Minnesota
    Here’s the dirt bucket and the snow bucket nested together.
    this is why I got it for loading and cleaning up around the woodyard. Much much more capacity for all that “light materials” vs dirt.
    9148EB30-14D3-4F72-B171-52A88459DCF9.jpeg 611B6D10-AAD2-4D33-9841-832C3F7C4A24.jpeg
    Dok440, Skier76, T.Jeff Veal and 2 others like this.
  6. FarmerJ
    FarmerJ
    Minnesota
    Can’t forget the safety gear…
    wow is this comfortable….
    got some hi-vis colors so someone in the excavator can see me.
    Chvymn99, ole, Chud and 4 others like this.
  7. FarmerJ
    FarmerJ
    Minnesota
    Incorrigible group I tell you…
    1200 miles from home and I’m shopping for firewood stuff because it’s easier than driving 70 miles at home…
  8. brenndatomu
    You sir will now advance to firewood hoarder 1st degree, congratulations! :handshake: :rofl: :lol:
    theburtman, T.Jeff Veal and FarmerJ like this.
  9. FarmerJ
    FarmerJ
    Minnesota
    Oh…. Bonus.
    TSC has the county line 25-T 4-way wedge on clearance. $24.99 vs $69.99
  10. T.Jeff Veal
    Even better...congratulations. Nothing wrong with checking out stores in the areas you travel.
  11. FarmerJ
    FarmerJ
    Minnesota
    Ok, that was a good investment for $25.
    I have a country pro which is a runnings store splitter instead of the county line which is Tractor supply. Both are YTL international splitters.
    Bought it mainly for smaller wood instead of using a straight wedge.
    Split three rounds of cherry for the weekend to cook on.
    All it took was 5 cycles each round to get some nice cooking splits out of it. It would have been 11-14 cycles with a single wedge.
    Softwood, Chud, theburtman and 4 others like this.
  12. FarmerJ
    FarmerJ
    Minnesota
    Decided to bag the wood as much to see how much it would be. As well as keep from just falling all over and make a mess. IMG_9621.jpeg
    Got some 1 Cu Ft bags. Using the 10 gal trash bin trick for the short term.
    JD Guy, Chud, T.Jeff Veal and 2 others like this.
  13. T.Jeff Veal
    Looks good. Where did you order your bags?
  14. FarmerJ
    FarmerJ
    Minnesota
    you may want to consider the 0.75 Cu Ft bags. These are pretty big. Especially if the idea is for selling to people who want smaller wood.
    1.0 CF 21x25 Mesh Bag - RED
    T.Jeff Veal and JD Guy like this.
  15. T.Jeff Veal
    Smaller bags will be fine, thinking of bagging some splitter scraps for kindling
    buZZsaw BRAD and FarmerJ like this.
  16. buZZsaw BRAD
    Feed, birdseed, and cat litter bags work great for it. When splitting BL ill have an open bag next to the splitter and toss shards in as im working! :loco: :crazy:
    JD Guy, Stephiedoll, Chud and 2 others like this.
  17. T.Jeff Veal
    We save cat food bags. Was going to give some to customers, didn't bwant a bag that big.
    buZZsaw BRAD and theburtman like this.
  18. FarmerJ
    FarmerJ
    Minnesota
    While splitting tonight, decided I want to get a gauge installed and see what I can do about adjusting the pressure up to around 2700-2800 psi.
    the pump and everything is rated to 3000 psi. I may get the larger pump and a 15 hp / 420 cc predator engine too instead.
    my plan is to make a bucking table like this…
    for this splitter and then use it in a vertical position at waist height to break down/ quarter large rounds IMG_9216.jpeg
    I want to make a bucking table to use like this. On one side I’ll have the country pro setup to quarter big rounds like an Easton made axis.
    then those smaller pieces will be pushed onward to a rugged made 728 splitter that drops onto a conveyor to load the dump trailer.
  19. brenndatomu
    How large?
    420cc will pull a low to mid 20s gpm pump ...but at that point the fittings and line size are the restriction...it'll make lots of heat!
    eatonpcat and T.Jeff Veal like this.
  20. FarmerJ
    FarmerJ
    Minnesota
    I’d be basically building it from scratch with the beam probably being the only thing original.
    the fittings on the cylinder are only 1/2”. (Since the hoses are metric, probably 13mm).
    probably a rabbit hole that would turn into Alice’s wonderland
