Wanna Talk About Port Shapes?
Discussion in 'Chainsaws and Power Equipment' started by Mastermind, Jul 30, 2014.
  1. cnice_37
    cnice_37
    How is the modification to the transfers determined? The intake and exhaust seem logical but the transfers have me confused. Like on the 064 why does the finger port start offset and jog across, as opposed to say centered between upper & lower?
    Thanks for taking the time to do this.
  2. Cut4fun
    Cut4fun
    OHIO Redneck
    If you want to see it? I have pics of a 166 ported work saw exhaust to compare to squared exhaust for race 166. It's amazing the difference.
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    Great thread Randy.. As noted before, porting was just brought up and these pics speak volumes.
    On the 460, do you make them all like your pic? To be honest, I have never even looked in any saw you have done for me? I have always been interested, but never cared to know. They run like wild animals and that's all that matters..
    The 362 will be home tomorrow. Thank you.. Again :)
  4. Mastermind
    Mastermind
    Tennessee
    Finger ports and bridge ports just add transfer area. No real rhyme or reason to their shape. The idea is to just add a bit more.
    Dex.......not many of the saws I do get finger ports......but I put the bridge ports in a lot of two port engines.
  5. Jon1270
    Jon1270
    Pittsburgh, PA
    On that 460 cylinder it looks like the finger ports might compete with the intake for space, so you have to decide whether a finger port or an enlarged intake is more valuable. How do you balance that? Is there a minimum cross-sectional size for finger ports, below which they just have too much wall surface area relative to cross sectional area to be worthwhile?
    Since the total volume of fuel mixture that makes its way through on each stroke can't be more than the displacement no matter what you do with the ports, there must be diminishing returns as you add port area. When is enough enough?
    clemsonfor likes this.
  6. nate
    nate Banned
    Palmer, AK
    Send it to someone or leave it stock!
  7. DexterDay
    Northeast Oh
    Send it to someone to mod the muffler? It's a 10 minute job.
    clemsonfor, Cut4fun and mdavlee like this.
  8. HittinSteel
    HittinSteel
    Wooster, Ohio
    Leave it stock? Hahaha come on man.
    clemsonfor, splitoak, mdavlee and 3 others like this.
  9. nate
    nate Banned
    Palmer, AK
    No, to port the jug.
  10. HittinSteel
    HittinSteel
    Wooster, Ohio
    Oh yeah, I dont mess with the jugs, just every muffler that comes in.
  11. DexterDay
    Northeast Oh
    I agree. I send mine out. :)
    One coming back hone TODAY!!! I can't wait to get home this evening! ! Yes!!!
    Randy Evans (Mastermind) is the Man!!!! :thumbs:
    clemsonfor, Chvymn99 and HoneyFuzz like this.
  12. Mastermind
    Mastermind
    Tennessee
    I'm sure you are right here.
    And we are veering off into race saw country.
    For gas powered work saw finger ports are rarely used, by me at least. I do add the bridged ports on quite a few two port engines, and I see those engines holding RPM in the cut a little better because of them.
    If we continue to add transfer area......we would soon need more carb. Then a tuned pipe.......and even more carb.......then some nitromethane. :D
  13. splitoak
    splitoak
    jefferson co wv
    You are too modest.....everyone here knows you are da man when it comes to work porting saws....:smoke:
  14. mdavlee
    mdavlee
    I've not done bridge ports like those. Just true fingers on a couple saws. I may try a set of those or fingers that connect with the uppers on one of these cylinders.
    clemsonfor and HoneyFuzz like this.
  15. Mastermind
    Mastermind
    Tennessee
    I just try hard to be consistent......no tricks or secrets.
    Mike they help the saw hold RPM in the cut a little better.....not a huge gain.....but for the small amount of time it takes to do em......they are worth it to me.
  16. Scotty Overkill
    Awesome description and pictures Randy. I am curious as to how you determine the depth of your finger ports and bridge ports in relation the the compression end of the cylinder......how far towards the spark plug hole do you make those ports, just below the rings at TDC?
  17. mdavlee
    mdavlee
    I don't mind doing them at all. I just don't want to get a knock for copyright infringement with CT13:doh:
  18. mdavlee
    mdavlee
    You set them close to the transfer timing is depending on what you're trying to accomplish.
  19. Mastermind
    Mastermind
    Tennessee
    Like Mike said.......the height of the finger ports, like all transfer ports, is measured and set carefully. On this 064 the transfer ports open at 118 degree ATDC.
  20. Cut4fun
    Cut4fun
    OHIO Redneck
    For the couple guys wanting to see work v/s race porting in a 166. The race 166 was ported by top name way ahead of his time in his late 80's now and still copied today. Marcel Vincent.
    mdavlee, DexterDay, HoneyFuzz and 2 others like this.
