Walking the line b/w Absolute & Ideal Steel
Discussion in 'Modern EPA Stoves and Fireplaces' started by Pants on fire, Nov 23, 2019.
  1. Backwoods Savage
    Doesn't really matter what the problems was because they have been taken care of.
  2. Pants on fire
    Pants on fire
    SW Montana
    If I'm reading you correctly Backwoods Savage , on one hand I shouldn't be concerned as Woodstock customer service would have my back. On the other hand they have built at least two stove models with early problems -- including mystery problems. Of course I would prefer to buy a stove that functions as designed to heat space and not so I can talk with nice strangers on the phone and (worst case) send back a 600 lb object while running a boiler.
  3. Canadian border VT
    Pants on fire All new models of any product, run into a couple flaws down the road, it’s why they have recalls on vehicles. It’s why I normally don’t buy the first model of any new product. I did with Woodstock as I needed a woodstove. I also have the crack in my stove, I’ve called Woodstock,I have the problem patched for now. I will bring the stove back in the spring and from what I’ve heard on this forum be given basically a New stove body.
    On a $2200 product I have used for 8 months a year, over 3 years! You can look at it anyway you want I just wish they also made phones and vehicles and other stuff I need
  4. Backwoods Savage
    This is why Woodstock went to putting out stoves (beta) to people to test in real life long before the stove hits the market. As for sending stoves back, that is a rare thing. There has been a couple instances where Woodstock has sent people to fix something on a new stove but again, that is rare.
    I think the biggest problem with the Progress was in the door and also the frame around the cat. Nothing very serious for sure.
    One more thing about Woodstock is that they do not stop. Case in point is the Fireview, which is what we have. This is an old stove that has been around for many, many years but they are still improving it. After we purchased we did have one problem and that is the frame that the cat sets in slightly warped. But that meant there was leakage so that the smoke all did not get through the cat. A new frame was sent to us and was easy to install. It cost us nothing even though the factory could have easily claimed we overheated the stove which would void the warranty. They also came out with a stainless steel scoop (under the cat). Easy fix.
    We also know of one person who seriously overheated his Progress. I won't get into specifics except to say he really beat on that stove and even had it overfired by 150 degrees over the recommended high temperature. Woodstock still took the stove back and in the end found that even though it was overfired, all was well.
    Not sure what else I could tell you except to say there are many, many satisfied customers; myself included.
    papadave, T.Jeff Veal, Maina and 3 others like this.
  5. billb3
    My boiler broke down the first year I owned it and had to survive for almost two whole days with just a small old ancient wood stove for a back up. I'd still recommend this boiler to anyone who needed one this size and could afford the premium.
    I was quite surprised at the tiny propane boiler they put in the brandy new house next door, and the single tiny tank outside. They sure are (capable of) building them tight these days. I'd go by BTU estimated heating requirements rather than size of house with a new build.
  6. Pants on fire
    Pants on fire
    SW Montana
    Good idea, I should figure out the house's estimated requirements.
    Thanks for the warm welcomes and feedback on Woodstock's style of doing business. From what I've learned in the past few days, if I lived closer to Woodstock this would be a slam dunk decision. The only other stoves I'm considering now are in the Blaze King 30 line, produced closer to my home I believe.
  7. wildwest
    Yes, Washington, we inherited one here and used for a year or so, I called customer service and they were TOP NOTCH! Both times the different person I talked to knew every model inside and out. Highly recommended.
  8. Marshel54
    Marshel54
    If it was me I would go with the IS. A little overkill is better than not enough heat.
    I have an AS and am loving it this year. Before someone calls me out, I found a problem with the chimney. It didn't work worth a crap last year, but working great now.
    All though customer service was great and helpful I missed the service I got from the local stove store.
    Someone mentioned the wings. The wings on mine seem to direct more heat forward.
    T.Jeff Veal, Chaz, OhioStihl and 4 others like this.
  9. billb3
    Kuma Stoves are in Rathdrum Idaho
    (not 2B confused with Laampa's Kuuma furnace)
    Their big stove, Sequoia may not make it to EPA2020, but their new 2.5 cubic foot stove might be big enough if you're considering an AS.
    I'm not exactly a fan of the wings on the As either but you can get one without wings.
    I like the tall one actually.
    T.Jeff Veal, Chaz, OhioStihl and 3 others like this.
  10. Highbeam
    Highbeam
    Montana is pretty much next door to Washington. I can drive from the ocean to bk headquarters and to anywhere in Montana all in one day.
  11. Flamestead
    Flamestead
    Windsor County, VT
    There have been several improvements. The original had a top made out of a single piece of soapstone. There were reports of cracks developing so they designed a 3-piece top. Then they decided to improve that and make a third design that has the cast iron cooktop covered three pieces of stone. Then there was an issue with some cast iron tops developing cracks so they added heat shielding. I have all three soapstone tops (had no issue with mine) at no additional cost to me, and they replaced my cracked cast top for free, too.
  12. Oldhippie
    Oldhippie
    Ashby Ma
    I've had a Fireview since 2012, and an AS since 2016 when they first shipped. So in this case you are asking As vs IS. There really isn't much difference in price and I think they are both capable of heating your home. It's mega insulated and I'm sure it will heat nicely. But the IS may be more convenient for those very cold spells where capacity for burn length even at relatively high burns is important. The IS may just give you an hour or two more on the back end of as burn cycle, given it's slightly larger box. So for slightly more money, you'll get a bit more potential burn time.
    But I will say, side entry door is nice, I really like it. The Ash pans kick-abs on both the AS and IS, and regardless of what that coot Backwoods Savage says, (grinning from ear to ear) the AS Wings are sexy! and can't be beat. As for the current problems that some of the IS stoves are having, you're not hearing folks taking that into consideration simply because they're quite confident of WS ability to have solved the problem and make it right for the customers.
    Also, one thing you can do, is buy the AS and if inside the first season it doesn't work out for you, they'll take it back for a full value and sell you the IS.
    Having said all that, your home sounds lovely, we want pics!!!
  13. Backwoods Savage
    Hey Steve, I do like the wings and have never said anything against them.
    Hope you have a Happy Thanksgiving.
    T.Jeff Veal, Chaz and brenndatomu like this.
  14. Oldhippie
    Oldhippie
    Ashby Ma
    I thought you said you didn't like them.. must have been someone else. Sorry Dennis. Have a great Thanksgiving.
  15. Oldhippie
    Oldhippie
    Ashby Ma
    So sorry Dennis, got you and Highbeam mixed up. I don't know how I did that... getting too old for all these windows and tabs and stuff. If I don't watch out they'll take away my drivers license and stick me in the old folks home! Like I said the AS Wings are sexy. (proof I'm getting old!)
    LOL!! Have a great Turkey Day!
  16. BKVP
    BKVP
    Walla Walla WA
    Hello there. I am very good friends with the owner of Woodstock. He has surrounded himself with an excellent team. They are exceptional at what they do and you do not have to hesitate investing in one of their products. Of course, I would prefer you invest in one of ours, but do not let a few glitches run you off their line. All manufacturers have issues and we and WS do not see consumers as guinea pigs. I participate in other forums and want to make a important point.
    These forums are an excellent place to get input, suggestions and recommendations. However, the scope (and I mean this respectfully) of the forums is very tiny and not 100% representative of the bigger picture. The participants in these forums have saved many, many consumers from cataclysmic mistakes....and possibly saved homes and lives...having reviewed images of installs. Their experience is invaluable, but it is precisely that, their own experience.
    Go with your heart on this one. Either company would be proud to bring you into their family.
    And have a great Thanksgiving!!!
    DNH, T.Jeff Veal, Oldhippie and 9 others like this.
  17. wildwest
    Nice to meet you!
    Pants on fire , pm him or call the company in WA!
  18. Marvin
    Marvin
    Huntingdon, Pa
    Well said BKVP! Companies such as Blaze King and Woodstock is exactly what American manufacturing is missing today. If there were more such as these we could take pride in our products. Top notch!
    papadave, T.Jeff Veal, Chaz and 3 others like this.
  19. Pants on fire
    Pants on fire
    SW Montana
    Thank you BKVP and everybody else who has chimed in. I’m grateful to experience the class and integrity expressed on this forum and in this thread. I’m convinced that with BK & WS, I have several excellent, reliable choices for a wood stove that will suit my needs and desires.
  20. bushpilot
    bushpilot
    Eastern Washington
    I noticed the OP was in Montana, and was going to post this very thing. From what I have seem (I don't own one), the Kuma stoves are great stoves as well, in the same class as the Woodstock stoves.
    I like that Sequoia.
    Edit: They have discontinued the Sequoia, but it might be available at local dealers yet. Their "big" stoves now are about 2.5 cu.ft., claimed heating capacity 2800 sqft.
