Walking axle atv trailer build (with pics)
Discussion in 'Everything Else (off topic)' started by TurboDiesel, Dec 30, 2019.
  1. unclefess
    unclefess Guest
    amazing, cant wait to see it finished :thumbs:
    leoht, Jack Straw, Chaz and 13 others like this.
  2. M2theB
    M2theB
    Central Massachusetts
    My Yutrax has expanded metal but not XXH.
    So I’ve got a lose sheet of plywood over it.
    I like your idea. You can alway toss something over it if it’s not holding up.
    leoht, Jack Straw, Chaz and 11 others like this.
  3. TurboDiesel
    Thanks, Brad.
    I've been thinking about an expanded metal that i saw on an equipment trailer that was REALLY heavy, Not the typical 9 gauge you usually see on landscape trailers...:yes:
  4. TurboDiesel
    Not to worry, JW. I appreciate the comments and suggestions.:handshake:
  5. Barcroftb
    Barcroftb
    The Mitten
    That would probably do it Tim. I've seen the same stuff it's pretty tough.
    leoht, Jack Straw, Chaz and 9 others like this.
  6. TurboDiesel
    I wanted to keep the wheel base the same as the quad...I actually got a little wider than I wanted. I didn't want the tub as wide as the the tires. Mostly for center of gravity and maneuverability in the woods.:handshake:
    Maina, leoht, Jack Straw and 13 others like this.
  7. imwiley1
    imwiley1
    Wisconsin
    I too, really enjoy these build threads. Envious of your skills and shop. I eagerly await for progress reports from the shop.
  8. eatonpcat
    Tim, once you get it finished we/I can draw up a set of detailed plans...but I will need all your input on dimensions, steel sizes and you on call when I draw it up!
    leoht, Jack Straw, Chaz and 10 others like this.
  9. TurboDiesel
    I went back and reread your post from monday.:yes: All solid ideas indeed.:handshake:
    I consider any comments on design one at a time and think them through.
    Do I need that ?
    Do I have it now? Would I use it if I had it?
    And yes. Some of the ideas made the cut:binoculars:
    :handshake:
  10. TurboDiesel
    I've even thought about making two floors that I could switch back and forth. Or putting expanded metal pieces in the front and rear as "drains" for the chaff (bark and chips)
    I haven't decided on the floor yet...:emb:
    It will most likely be a sheet of metal so it sweeps out easy.
  11. TurboDiesel
    Great idea! I should stop over. :whistle:
    'course, we probably wouldn't get much work done then...;)
  12. eatonpcat
    Look forward to the visit!
  13. Eric VW
    ...especially if Brian is wearing his FT.... :eek:
    :faint:
  14. T.Jeff Veal
  15. TurboDiesel
    Wasn't just me. I had our welder mechanic truck driver operator plumber electrician farmer helping me. He likes to fab and play in the shop too. He's 67 and can outwork anyone on the site. We really have a great time working. I don't think he'll ever retire.
    BrianK, Maina, leoht and 16 others like this.
  16. lukem
    That's what I want to be when I grow up.
  17. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    You have my wheels turning and was thinking about different types of grates. I watch those gold mining shows and see they use some kind of plastic/poly/fiberglass grates in their wash plants so started browsing the interwebs for ideas. Check this stuff out. If you stayed with the 56 "x 32" floor 3 pieces might work with one end and the outside edges cut off. It looks like they interlock at the edges. The bad expensive. $50x3 + ship. I just thought it was cool.
    Plastic Grate 12 inch x 60 inch - PlasTEAK Inc.
  18. Horkn
    That's what the flooring is on our roll in boat dock up north.
    leoht, Chazsbetterhalf, Chaz and 8 others like this.
  19. TurboDiesel
    I finished making the 10 side posts today but didn't get them tacked on the frame. The neighbor called looking for some help so i quit and went to help him. I'll definitely have them on tomorrow.
    Lots of angles and welding and grinding today
    I have a piece of angle iron clamped to the edge of the welding bench as a jig to clamp the box tube in and get the angles right for tacking
    Marvin, leoht, M2theB and 17 others like this.
  20. ironpony
    ironpony
    Mid Ohio
    when notching tubing to make an angle if you do not cut the back edge it will act like a hinge and you can bend it closed then weld 3 sides instead of 4. also it will keep things lined up.
    BrianK, Maina, Jack Straw and 13 others like this.
