Venting Thoughts
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by IHATEPROPANE, Jan 21, 2015.
  1. IHATEPROPANE
    IHATEPROPANE
    Option 1 is the easiest.
    ivanhoe likes this.
  2. slvrblkk
    slvrblkk
    Northampton, PA
    That damm 4" pipe is a lot more money...
    ttdberg likes this.
  3. slvrblkk
    slvrblkk
    Northampton, PA
    If you could whack a couple feet off that vertical run that might be your way to go...
    ivanhoe likes this.
  4. IHATEPROPANE
    IHATEPROPANE
    Indeed it is:(
    ivanhoe likes this.
  5. IHATEPROPANE
    IHATEPROPANE
    Don't think it is possible. But I am also just eyeballing it, so I could be way off....
    ivanhoe and slvrblkk like this.
  6. Smokinpiney
    Smokinpiney
    "South" Jersey
    I was limited on where I could go out and up (deck, windows and roofline) so I went straight up through the ceiling and roof. Me and a friend did the install and it really wasn't bad. Glad I went that route as the stove has great natural draft
    wildwest, ivanhoe, jtakeman and 2 others like this.
  7. IHATEPROPANE
    IHATEPROPANE
    This would be my first choice. But it is probably outside my skill set and I would have to pay someone.
    ivanhoe likes this.
  8. imacman
    imacman
    Denver, NC
    I agree.....borderline. You'd be right at the 15 EVL w/ that set-up. You could go either size pipe, but 4" would be the safest bet.
    IHATEPROPANE and ivanhoe like this.
  9. imacman
    imacman
    Denver, NC
    Contact Eric at Kinsman stoves or try Dynamic Buys online.....both have been the cheapest I've found. If calling Eric, don't forget to mention you're a forum member.....you get a discount. Dynamic Buys has free shipping too.
  10. ivanhoe
    ivanhoe
    Northern Ontario
    #1 eliminate smoke in case fire goes out(natural draft)
    #2 size for safety(4" versus 3")
    #3 to function properly(up & out versus out & up) (straight up been best choice)
    #4 ease of cleaning(straight out or out & up)
    #5 cost(straight out)(the cost adds as you decide which way to go)
    My vote is following the order of importance!
    wildwest, will711 and IHATEPROPANE like this.
  11. savemoney
    Think ahead. If you get limited in mobility, you will want to to have the best access to cleaning or be forced to pay to have it done at the proper time. Don't set yourself up for something you can't take care of.
    wildwest, IHATEPROPANE and ivanhoe like this.
  12. badbob
    badbob
    True,savemoney.And living in mts,where you may be using stove every month of the year,cleaning convience is important.
    wildwest, ivanhoe and IHATEPROPANE like this.
  13. IHATEPROPANE
    IHATEPROPANE
    Thanks for the replies everyone, Lots of great ideas and some things to think about. I am leaning towards the out and up for its simplicity, cleaning and cost. But I still may go up than out. Will see what the wife says for looks when i get closer.
  14. jtakeman
    Any way to use a raised hearth? The height of the hearth can also be adjusted if you change stoves down the road. Easier than changing the location of the hole in the house.
    Maybe even some cool led's that flash? :whistle:
    ttdberg, ivanhoe and smoke show like this.
  15. IHATEPROPANE
    IHATEPROPANE
    :rofl: :lol: I need some rope lights:D
    I have been going back and forth in my headfor the exact reason of a pellet stove down the line. My West Point has like a 10" vent. A lower vent my eyes have not seen so the only option at replacement is another hole in the wall :headbang::doh:.
  16. wildwest
    did you have trouble getting the proper pieces? 3", what brand? Might help him avoid the delay you had.
  17. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    Setting a roof flashing really isn't too difficult, just make sure you measure measure measure and get the hole in the right spot, then you can drill a pilot hole and trace the inside of the flashing on the roof to cut your hole. I bet money you could find a good tutorial on youtube.
    That said I and afaik, most manufacturers vote vertical install as the best option but I know that's not always possible. I did mine vertical but that's because there was a woodstove there and I had a gaping hole to deal with. Otherwise it would have gone in the opposite corner, through the wall, up 5 feet, out 12 inches and then a termination cap. As long as you stick with code they are all good options really.
    ttdberg, ivanhoe and IHATEPROPANE like this.
  18. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    If all the vent goes out its looks better in the inside, #1 gets my vote for clean install.
    IHATEPROPANE and ttdberg like this.
  19. imacman
    imacman
    Denver, NC
    No....please, NO. :picard:
    343amc, will711 and IHATEPROPANE like this.
