No Longer Available Vac and pressure testers
Discussion in 'Closed Ads' started by Jon1270, Jan 10, 2016.
  1. Jon1270
    Jon1270
    Pittsburgh, PA
    I've been using these for a couple of years, but I just bought a fancy combination tester so I don't need them anymore. Both are older tools that I got secondhand.
    The Mityvac pump is a basic pressure tester with a gauge, plastic-bodied and non-rebuildable but works perfectly.
    The pressure tester is just a squeeze bulb pump like you might find on a portable fuel tank for a 2-stroke boat motor, with a gauge and hose nipple. It would be nice to add a hose clamp around the intake end of the pump, because otherwise the bulb sometimes distorts enough when squeezed that the check valve falls loose inside the bulb, and getting it back into place is kind of a pain.
    $20+shipping.
    Barcroftb, MasterMech and HoneyFuzz like this.
  2. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Sounds like a good deal !
  3. Jon1270
    Jon1270
    Pittsburgh, PA
