Upgrade my CS-670
Discussion in 'Chainsaws and Power Equipment' started by bobdog2o02, Feb 13, 2018.
  1. Redfin
    Redfin
    central Pa
    And this is what you are paying for. Knowledge. Its very easy to give someone "numbers". Two saws built to the same "numbers" will never run the same.
    Yes there are other variables involved between saws but one has to have a working knowledge of how all the aspects coordinate together.
    I will not let a saw leave my bench after porting it if I would not keep it for myself. That includes paying up to swap parts so the saw is right.
  2. Red97
    Red97
    Mi
    This is my home for the next few months, then a bunch of other stuff to finish up.
    Probably be 2019 before I touch a saw :([​IMG]
  3. Mag Craft
    Mag Craft
    South East Wyoming
    Yes that is true if you are going to cut the squish band and cut the base of the cylinder then it is going to require some machinist skills and a lathe. Not something everyone has. The 250.00 does not look to bad then. But if you going to just work the ports that is a different story.
    Screwloose and Eric VW like this.
  4. Eric VW
    Excellent points, but highlighted text is why I even shy away from adjusting a carb...it’s not in my dusty wheelhouse...:confused:
    :handshake:
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I spoke with Red97 and he said he is not taking work for 1year or more. Do any of you guys have experience with these things or may want to give it a try?
  6. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Termitebuffett and Huskihl both build a strong saw, both are good guys and honest.
  7. huskihl
    huskihl
    Muh ears is ringin'.
    Thanks Bud.
    I've got time to play around with it. Never been inside an Echo before. They're probably a lot like a chainsaw :yes:
  8. Armbru84
    Armbru84
    Sparta, Michigan
    One vote for Kevin. Great guy to work with and does good work.
    Horkn, Fifelaker, Barcroftb and 4 others like this.
  9. huskihl
    huskihl
    Thanks Cole
    Horkn, Fifelaker, Barcroftb and 2 others like this.
  10. Red97
    Red97
    Mi
    This guy a good egg^^^
    Termitebuffet, Redfin too
    I'd send to any of them
  11. huskihl
    huskihl
    Text me when yer done catching steel on fire for the day
  12. Screwloose
    Screwloose
    I've got a 680 that I believe is just a new version of the 670. It's just barely broken in. It's already a fun little s@#$ but I would be interested in having it's guts tweaked.
  13. Red97
    Red97
    Mi
    The 670's have some hidden potential. Same wif the 680
  14. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Did you cut your hand when you set that down Joe?
  15. Red97
    Red97
    Mi
    These were before the bad plastic. Iirc the only plastic is clutch cover and top cover.
    Lots o metal on these saws. Especially the older ones
  16. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Still sharp, I read it on the internet, so it must be true.
  17. Red97
    Red97
    Mi
    Bump...
  18. huskihl
    huskihl
    Finishing a couple others first. Patience, Grasshopper
  19. huskihl
    huskihl
  20. huskihl
    huskihl
    Upgraded
    Redfin, bobdog2o02, Horkn and 4 others like this.
