Unpleasant phone call from the Electric Company :D
Discussion in 'Chainsaws and Power Equipment' started by Carbine, Dec 29, 2016.
  1. Well Seasoned
    You can certainly wrap around the meter that has the signal, mesh screen, held on by a large hose clamp, even aluminum foil around the perimeter. A note should be added explaining what you did to protect your family from radiation, so they don't hold any type of tampering of their property against you. This is really serious, and unfortunately not many know about this (by design again)
  2. MasterMech
    From the American Cancer Society site:
    Smart Meters
    Can smart meters cause cancer?
    Smart meters give off RF radiation. RF radiation is low-energy radiation. RF radiation doesn’t have enough energy to remove charged particles such as electrons (ionize), and so is called non-ionizing radiation. Non-ionizing radiation has enough energy to move atoms in a molecule around or cause them to vibrate, which can lead to heat but it can’t damage DNA directly.
    RF radiation is classified by the International Agency for Research on Cancer (IARC), as “possibly carcinogenic to humans.” This is based on the finding of a possible link in at least one study between cell phone use and a specific type of brain tumor. Because RF radiation is a possible carcinogen, and smart meters give off RF radiation, it is possible that smart meters could increase cancer risk. Still, it isn’t clear what risk, if any there might be from living in a home with a smart meter.
    It would be nearly impossible to conduct a study to prove or disprove a link between living in a house with smart meters and cancer because people have so many sources of exposure to RF and the level of exposure from this source is so small. Because, the amount of RF radiation you could be exposed to from a smart meter is much less than what you could be exposed to from a cell phone, it is very unlikely that living in a house with a smart meter increases risk of cancer. The World Health Organization has promised to conduct a formal assessment of the risks from RF exposure but this report is not yet available.
    Viking80, papadave, savemoney and 6 others like this.
  3. HDRock
    I have to tell you, I did not like this in the first place and the information that I obtain on the power company website is pretty lame.
    Anything that invades my privacy even a little disturbs me a lot
  4. 94BULLITT
    94BULLITT
    Frederick County, VA
    I just saw a video on youtube where a guy was accused of tampering his meter. He claimed it was because he uses LEDs.
  5. Well Seasoned
  6. Star Gazer
    Star Gazer
    Right behind you
    The electric company changed my meter twice, both times while I was away from home, due to my reduced usage. I'm guessing they determined the meters weren't faulty, and I wasn't tampering with them. The meter is one of those Smart Meters. :startled: :loco: :crazy:
    When I first moved here, my monthly bill was at least 4 times what it is now, but since the installation of LED's and the wood stoves, my average bill is about $40 a month (average KWH usage is 9 KWH per day) That's running the well pump, lights and whatever (electric tools) in the garage, my security cameras w/DVR and monitor, 2 computers and printer, embroidery machine, sewing machine, iron on transfer machine, iron for cloths, electric washer and drier, 1100 watt microwave, electric stove, toaster, refrigerator, 12 cup coffee maker, crock pot and so on. 2 stereo's and my HAM Radio equipment. Then add to it I leave I leave 4 lights burning 24/7 and a 36" television on 24/7.
    My propane bill dropped to zero, and my fuel oil bill did the same. I've never run the blower on the wood stove and I don't use A/C during the heat of the summer.
    I'm planning to cut my bill in half yet again over the next year by eliminating the well pump, and electric drier from the equation. Heck, I might even remove 2 of the lights I leave on 24/7 as well as the television (since I don't watch the dammed thing anyway, but it does make it appear as though I'm awake.) In the works is to better insulate and seal my home making it more energy efficient resulting in using much less firewood.
    Yeah, I know, I'm such an energy waster! :rofl: :lol:
  7. MightyWhitey
    MightyWhitey
    Eliminate your well pump!!! Please explain that one.
  8. Star Gazer
    Star Gazer
    Right behind you
    To paint the whole picture, I also have a spring that feeds into my property. A dual chamber Spring box is already in place that is approximately 4' x 4' x 8' about 800 feet up the mountain or about 50 to 75 feet above my current elevation with a water line coming down to within about 10 feet of the pump house. After I make the necessary repairs and some modifications, I will remove a component from the water feed line (gravity type fed pump) which is about 10 feet behind the pump house, and run the water line to the pump house where I can in turn put in place a 3 way Tee valve. That valve will allow me to feed the water line to the house with either the well pump or the water from the spring with additions of filters and check valves before the Tee. I'll also be adding a small tap into the line from the spring in order to keep the line from freezing during the winter. That little line will run into a drain I put in place back towards the end of October. I'm currently trying to decide the size of that line so it doesn't have an effect on the water pressure.
    I currently run the house water at 60# pressure, and a guesstimate of the water coming down from the spring to that pump behind the pump house is probably between 40 and 60# without using a booster of any kind. So instead of relying on the well pump to supply my water, I will essentially be using it as a backup if necessary and the water from the spring head will be my main source.
    Another project kind of attached to this one is building a new pump house to replace the current one.
    Here is a thread I did where I was asking about Hydraulic Cement to repair the spring box and some pictures:
    Hydraulic Cement for Spring Box repair?
    And this one for the cover with better pictures:
    Spring Box/Settling Tank Cover
    This is the type of gravity feed pump I was referencing that's behind the pump house:
    papadave, Hammy, savemoney and 4 others like this.
  9. Carbine
    Carbine
    This is after 2 full weeks of use. Think they'll be amused? :D
    reelcrzy, Hammy, Chvymn99 and 5 others like this.
  10. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Another thing you can do is call them and tell them you think somebody is stealing your electricity because your electric bill is way to high!:rofl: :lol:
    Gary
    papadave, gregbesia, Hammy and 6 others like this.
  11. MightyWhitey
    MightyWhitey
    This is mine after...............I'm guessing here................about 6 months since they installed it. Funny that my stacks start about 10-12ft. from my meter........................they're clueless!!!
    gregbesia, Hammy, Chvymn99 and 6 others like this.
  12. Carbine
    Carbine
    That is actually a good idea lol. I have an ash tree that is too close to my line also, I was going to take care of it... But they may as well come out and do it. Hope they bring the chipper too :D
  13. Carbine
    Carbine
    Does that reset every month? Most of my usage is pretty much my blower (on the wood furnace) and the dryer. The small appliances don't seem to use much. I couldn't see using much less electricity than we do.
  14. chris
    chris
    SE WI
    Every time they change one of my meters it seems to get a bit more pricy- about now is when they change the gas unit seems like every year , they did the electric one late summer.
  15. wildwest
    Thanks for the info, totally makes sense, we do not have natural gas here so it was our electricity meter that was upgraded LOL.
    Well Seasoned likes this.
  16. lukem
    I got a call from the propane company the January after we moved in here. We got the wood stove going and only used a tiny bit of propane whereas the previous owner would get a fill every 3 weeks.
    They called to remind me that I didn't own the tank and I needed to stop having it filled by another supplier. I told them the wood stove story and they believed me...Then proceeded to remind me that there was a minimum qty or I would be charged $40 a month for rent. I told them to come and get it....Better bring a hoe because if you remember it is a burried tank. Crickets. Bu-bye.
  17. brenndatomu
    What is the elevation difference between the house and the spring?
    Water pressure builds at a rate of .43 PSI per foot of water column height. In other words, if your house is 100' below the spring, then you would have 43 PSI pressure (approximately, I didn't figure in the small amount of pipe friction loss) at the house.
    Feel free to respond in one of your "spring" threads so as not to "leak" on Carbines thread...water and electricity don't mix ya know... ;)
  18. MasterMech
    Have you considered doing a backflow preventer or double block and bleed setup on the supply line from your well? Just in case the surface water becomes contaminated, I'd hate to have it contaminate the well supply too.
  19. OhioStihl
    OhioStihl
    Southern Ohio
    My propane company sent a bill for tank rental. I called and talked with a nice lady. She said if I had the tank filled then she could credit the tank rental to the propane cost. She asked me to check my propane level, it is at 60%. She told me the last time my tank was filled was May 10th 2015.
    I think I will be on the 3-4 year propane plan. We burn it on vacation or the occasional chill in the house in the shoulder season.
    Star Gazer, Hammy, Chvymn99 and 2 others like this.
  20. clemsonfor
    My company installed all NE digital meters like 7 years ago. my usage went up as did many folks in town. they said the internals were worn on the old one when I called and complained and asked how I kew their meter was calibrated correctly.
    our meter is on the side of house outside bathroom. bedroom beside that and room beside kitchen with a tv tat we spend a good bit in, not our main tv room though.
    Hammy likes this.
