Unintended Consequences.
Discussion in 'Chainsaws and Power Equipment' started by amateur cutter, Dec 17, 2021.
  1. brenndatomu
    Nah...not AC! He's got to many cool toys to be too naughty! Er...well...wait a minute...hmmm... :sherlock:
  2. huskihl
    huskihl
    The one with 25 in front of him. Kinda like living in FL when Santa starts in Canada
  3. System
    System
    Western MA
    So, back to filling that hole under the bench... What are you thinking? I'd say put the 500i on your short list. Maybe a 400 as well. Get rid of that lone jack stand and you'll def have room for 4 more...
  4. farmer steve
    farmer steve
    top of the hill york co. PA.
    :thumbs:
  5. amateur cutter
    500i is tops on the list. After running a ported one at huskihl 's last year I don’t think I'd even use it. Just ship it to him for porting. A tweaked 7910 Dolly is another one.
  6. MikeInMa
    I don't see why having room for 2 saws is a problem.
    Now, if 3 saws dropped into your lap, with room for only 2, that's a problem. Albeit, a good problem to have.
  7. buZZsaw BRAD
    There's a couple empty spots for "new" saws??? This said without viewing other replies.
    I like the grinding set up. Well done and thought out. :thumbs:
    EDIT: after reading entire thread id say 400 & 500i. Has Kevin ported a 400 yet?
  8. huskihl
    huskihl
    I haven’t. But it’s basically a 362 with a bigger cylinder, so it shouldn’t be difficult to figure out
  9. huskihl
    huskihl
    Just think buZZsaw BRAD, you could have the world’s first fully ported XS400.
    …inside “other forum” joke. That probably isn’t nearly as funny here as it is on OPE
  10. T.Jeff Veal
    Nice setup and saws. Yep, a XS500i would look good under there. Get ya a XS 2511T Echo as well...
  11. buZZsaw BRAD
    How does the porting and MM affect the Mtronics Kevin? Do you have to do anything to that or does it self adjust?
  12. Redfin
    Redfin
    central Pa
    I raffed.
  13. huskihl
    huskihl
    On most models, nothing needs done. The M Tronic compensates without any hitches or resets. Only the MS 261 was borderline on having the ability to put out enough extra fuel. I actually found a jet inside the carburetor that needed to be drilled larger. Within a year, stihl was on to the version 3 mtronic and they had done the same thing with the carburetor So I believe that all models are fine now
  14. huskihl
    huskihl
    Butchered that chite.
    And fixed :headbang:
  15. amateur cutter
    Good plan Jeff, hey Kevin go buy a 500i and port it for me, I'll pick it up in 2027 when you're a bit more caught up.:rofl: :lol:
  16. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I have both the 400 c and 500i….. stock though. They both run great so I can’t see modding them. I have an 880 if I need to shred big logs.
