" Uglies "
Discussion in 'The Wood Pile' started by bogydave, Nov 5, 2016.
  1. HDRock
    Here's an ugly :bug:
    Mitch Newton, unclefess, Thor and 8 others like this.
  2. bogydave
    That's art
    some clear varnish, on a shelf by the stove
    unclefess, Thor, Horkn and 1 other person like this.
  3. bogydave
    P
    I have some like that
    They don't split, they tear apart
    Thor, Horkn and GrJfer like this.
  4. Erik B
    Erik B
    Western Wisconsin
    Looks like you have been filching those uglies from my wood stacks:sherlock::sherlock:. I have a lot of those
    Thor and Horkn like this.
  5. MightyWhitey
    MightyWhitey
    Dave................your "uglies" look like most of my "beauties"!!!!
    unclefess, Thor and Horkn like this.
  6. Horkn
    Exactly, those are not so ugly uglies.
    Gooder stuff, definitely.
    Thor likes this.
  7. Horkn
    Dave, according to the Alaskan btu chart you have, all of those btu ratings are higher by a minimum of 2000 btu's for each of those species than our comparable wood of those species here in the lower 48 States. I don't know if that's right or wrong, but it's interesting to say the least. I know the soil and climate of each tree alters how they grow, so it could make then have more btu's.
    Maybe the extra cold in AK has each species holding onto more btu's as a way of survival of the extreme cold?
    Backwoods Savage and Thor like this.
  8. Horkn
    Then straight in the fire, extra btu's from the varnish. ;)
    Thor and HDRock like this.
  9. WeldrDave
    Thor, Horkn and HDRock like this.
  10. WeldrDave
    Some good ol'e NJ Gum tree! :whistle: Try that one for ugly o_O
    Backwoods Savage, Thor, Horkn and 4 others like this.
  11. bogydave
    My ugliest not that bad
    A few crowns that split funky
    & some with a twist & bow that
    Would cause a stack to fall over
    Few rotten centers,( compost )
  12. bogydave
    Cut gum small,so it don't need to be split :zip:
    Thor, Horkn and WeldrDave like this.
  13. yooperdave
    That's what I'm talking about! If I can lift it, it goes in the OWB!
  14. Sean
    Sean
    I remember having a conversation about this with Dave and others but cant recall where it is. If you look at his chart it shows Tamarack as 16,000 mbtus but on chimney sweep it shows larch being 19.5, although they are very similar trees the tamarack is quite a bit smaller than the larch. Also his birch has higher btus than what my impression is of the birch around her that is (supposedly) 20 mbtus. The shorter length of growing season likely makes the trees denser but what do I know? Fun stuff
    Backwoods Savage, Thor and Horkn like this.
  15. bogydave
    Yea
    I see different Ratingof the same species on different charts,
    I just "assume" the test is done to the same standard & it's variances in the makeup of the wood fibers for multiple reasons
    Nature throws in so many variables,
    I believe there's different BTUs for the same species , even grown a few miles apart.
    Not that it matters to me, I burn birch, it's the best BTU wood in my area.
    bear_hunter, Thor, Sean and 2 others like this.
  16. Brett
    Brett
    Northwest Illinois
    Impressed with the BTU value of Alaska birch.
    Thor, Sean, HDRock and 1 other person like this.
  17. billb3
    That's what I'm talkin about. Uglies that test the mettle of a splitter. They don't stack well in the rack or the stove. A little extra pleasure burning the ones that fought ya . Winning !
    I burnt you, you bastard !!!!!!
    HDRock, Sean, GrJfer and 1 other person like this.
  18. bogydave
    They seem to dry faster too, more surface splintery area to wick away moisture
    Sure burns good in the fire pie :)
    Thor likes this.
