Type of Maple?
Discussion in 'The Wood Pile' started by reckless, Oct 22, 2013.
  1. reckless
    reckless
    Is this silver? I cannot be certain that the leaf is actually from this tree..... Is it common that they grow in bunches? I have 3 or 4 groups like this one. Thanks!
    thewoodlands likes this.
  2. Scotty Overkill
    Nope...... that is a red maple. Which is better than a silver maple! But not quite as good as Norway or hard maple....
    a great wood to have in the stacks!
  3. Paul bunion
    Paul bunion
    Definite red maple leaf. The bunches that you have are probably from the trees sprouting up from a stump.
  4. billb3
    swamp/red maple
    I have bunches like that where they were the pioneer trees in an open field.
  5. Backwoods Savage
    Very common to find them growing in clumps like that. That also makes some of the best kindling you can have and it splits super easy. It also dries really quick and we've burned it in 6 months after c/s/s.
  6. dutch
    dutch
    Central NY
    Same here. They also seem to come down quite a bit on their own, and split super easy by hand. Those and cherry are my two easiest to get cut and split.
  7. WeldrDave
    Yup! as they said above, Red.... Got lot's of it down here:thumbs:, Good stuff, We also have a maple down here called a Trident maple, leaves are very similer but not quite the same. If you get it CSS now, it will be dry enough for next/2015 winter. :axe:
  8. HDRock
    Burning some red maple now unsplit dry logs actually burn quite a long time
  9. stuckinthemuck
    stuckinthemuck
    Depending on when you need the wood, you could consider cutting one or two of the trunks now and then allowing the others to grow for a couple of years.. The strong root system (due to supporting all of the trunks) will allow the remaining stems to gain diameter more quickly. Additionally the crown of the tree will spread or expand on the side that was cut due to increased sunlight.. Just a way to take advantage of growing stock if you're limited on available wood.
    The multiple stems probably grew from a tree that was cut down in the past. Deer and Moose love the stump sprouts that grow up from red maple stumps.
    Coppice is a method of woodland management when there is a desire to grow for fuel wood.
    http://en.wikipedia.org/wiki/Coppicing
