Two more 064's for the hoard....I got it bad!
Discussion in 'Chainsaws and Power Equipment' started by Scotty Overkill, Oct 21, 2018.
  1. AlfA01
    AlfA01
    Evia Greece
  2. J. Dirt
    J. Dirt
    Looking good man!! You got to post some videos of the first fire and tuning!
  3. J. Dirt
    J. Dirt
  4. Scotty Overkill
    Only ran her for around 20 minutes this evening, break-in has commenced. It's running a richer mix, as well as tuned fat on the top end...
    Made a few cookies out of some big spruce rounds I have in my woodpile, but the phone died before I could video it. I'll try to get a video in the am of some cuts...
    It's gonna be a fun saw!
  5. J. Dirt
    J. Dirt
    Sounds good!!
  6. huskihl
    huskihl
    Scotty, is this the one we talked about? Cross 064 big bore?
  7. Scotty Overkill
    No Kevin, this is a saw I bought cheap as a basket case and I used an OEM cylinder that Redfin had and did some work on for me. The saw we were talking about was a MS660, I finished that one up a few weeks back. I did what we talked about with the exhaust, as well as worked the intake side over, here is that saw....
    It pulls with authority too, I'm going to check all the screws over and let the owner pick it up this weekend. I tried to talk him out of it, but he wants it.....lmao
  8. huskihl
    huskihl
    Get it hot and re-tighten the inner muffler screws. Somehow they like to loosen up
  9. Scotty Overkill
    Indeed, also gonna check the jug base screws. When i bought this 064 a few weeks back, the jug was loose.....I think that's what killed the piston and rings. The rings were worn halfway down on the exhaust side and the piston was toast.
    That being said, do you ever use blue loctite (removable) on jug screws? I didn't use any, but was wondering if anyone does that.
  10. huskihl
    huskihl
    I don't normally. Usually i use motoseal and intentionally smear some down in the holes. But yeah, blue loctite will work fine
  11. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    I usually don’t use anything on pro-style saws at that location. I will take the extra few minutes and spray the screws and holes with a good cleaner. I install them dry and check torque after a few heat cycles. If I’m going gasketless or have a suspect mating surface, I’ll let some 518 get in the holes like mentioned above.
    I purposely let some Dirko get on clamshell screws , though.
    blacksmith, Chaz, AlfA01 and 2 others like this.
  12. Redfin
    Redfin
    central Pa
    Well? Is it a turd or what Scotty?:)
  13. Scotty Overkill
    I only ran it that first evening, I've been too busy since. Was gonna use it some today, then this chit weather moved in....lol
    I'll keep ya posted, it seems like it has some decent torque, sounds pretty mean, and I did rip it through some spruce rounds, but I've got it running fat.
  14. Marvin
    Marvin
    Huntingdon, Pa
    Boy you aren't kidding. Just the kind of weather we needed here in central PA. Might as well just keep making mud :picard:
  15. Scotty Overkill
    Nothing better to do today.....so, I tore down the other 064!!
  16. Redfin
    Redfin
    central Pa
  17. Scotty Overkill
    Redfin here's a video of a couple cuts. Saw has some good torque, cuts with authority. Once I do a base gasket/squish band on it it'll really pull.
    Someday.
    Good enough for what I do with it....
  18. Redfin
    Redfin
    central Pa
    May as well machine and full port at that point Man.
  19. Scotty Overkill
    Thats when it'll end up on your bench....lol
    amateur cutter likes this.
