Two guesses
Discussion in 'The Wood Pile' started by jrider, Feb 16, 2019.
  1. The Wood Wolverine
    105 splits
    295 pounds
    metalcuttr, Chvymn99, Chaz and 4 others like this.
  2. brenndatomu
    Guess #2
    498 lbs
    98 splits
  3. jrider
    jrider
    Was afraid to use log lift but did use 6 way because it was all straight grained
    metalcuttr, Chvymn99, Chaz and 3 others like this.
  4. jrider
    jrider
    Gotta remember this is green oak folks
    metalcuttr, Chvymn99, Chaz and 5 others like this.
  5. Horkn
    94 splits and 512 lbs
    metalcuttr, Chvymn99, jrider and 5 others like this.
  6. jrider
    jrider
    Getting close
  7. Horkn
    I rolled a 30" ash round over to, and onto the beam of my splitter two weekends ago, and I figured that was around 400 lbs. That ash tree didn't even leaf out this summer, so it's relatively dry compared to that oak. No doubt this wet green oak is well over 500 lbs.
  8. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
  9. huskihl
    huskihl
    Seems pretty violent for a family oriented forum ;)
  10. mr.finn
    mr.finn
    Mass
    I will stick my number of splits but I'm starting to think I was way off on weight.
  11. T.Jeff Veal
    80 splits
    705 lbs
  12. jrider
    jrider
    We are getting closer
  13. Brandon Scott
    Brandon Scott
    I obviously left my glasses on and fat fingered my calculator yesterday. I come up with 674 lbs this morning. Sticking with split count.
  14. brenndatomu
    What are you using for diameter?...even using a diameter of 36" I can only get to 560# (using 61# per CF/green Red Oak)
  15. Brandon Scott
    Brandon Scott
    I went with 36 but used 18” length. I also went with 63.69 lbs per CF.
  16. Brandon Scott
    Brandon Scott
  17. Marvin
    Marvin
    Huntingdon, Pa
    What length do you cut the rounds to?
  18. billb3
    estimated weights for green oak are all over the place - just like drying time.
    5,000 pounds for a cord is common, but cubic feet estimates range from 85 to 45 pounds. WTF
    maybe some of these "wet" estimates are based on taking dry weights and "calculating" the weight of the water back in ? How much do you calculate back in ? 30%, 40%, 60% ?
    I went with a 32 inch round figuring the bar length spread across the round is actually 30-31 inches.
    My estimate is a more conservative minimum. and probably off by a bit . LOL
    Slocum, amateur cutter, Horkn and 4 others like this.
  19. brenndatomu
    Yeah this is all just a crap shoot really anyways, since we don't know the exact type of Oak, alive or dead, etc...and the weight was just calculated averaging 20 splits too, so...stinkin big boy, no matter how you slice it!
    I know the weight on these big ones adds up quick! We had a big Maple log that had to be hauled off from a parking lot a few years back. 10.5' long and ~5.5' diameter...our 5k # rated forklift wouldn't pick it! Had to lift the dump bed of the trailer to kinda tip the log (it was standing up for carving...but was partially hollow so that didn't happen) into the trailer bed, lower it down, then push it the rest of the way into the trailer. We were guessing it to weigh 7-8k # then...
  20. jrider
    jrider
    Ok so here are the results: 121 splits. 20 random splits weighed 122 pounds so the best estimate I could come up with is 738 pounds. Glad I decided to noodle in half before using the log lift which says not to exceed 500 pounds.
    Eric VW, J1m, T.Jeff Veal and 6 others like this.
