TSC Heat Treated Firewood
Discussion in 'The Wood Pile' started by Kimberly, Sep 27, 2016.
Tags:
  1. saskwoodburner
    saskwoodburner
    Have you dropped the rakers on your chain yet? It doesn't take much to make quite a difference.
    HDRock, Bert and NortheastAl like this.
  2. Kimberly
    Kimberly
    The Kangaroo State
    I don't know what this means.
  3. Eric VW
    milleo, HDRock, Bert and 2 others like this.
  4. saskwoodburner
    saskwoodburner
    Eric VW nailed it in his post. Even if the teeth are sharp, if the rakers are too high, you can't get a bite. And watch out if you get them too low! Pure excitement. I tend to drop mine a bit more than I should if I'm only felling big trees and bucking them on the drop spot. Then it matters way less than if you're clearing light brush or smaller diameter wood. It does literally pull the saw towards the wood hard, or flips small wood right at you.
    milleo, HDRock, Bert and 3 others like this.
  5. Eric VW
    I guess Kimberly is still reading the thread?
    milleo, HDRock, Ashwatcher and 3 others like this.
  6. yooperdave
    Yeah, thats it!
    milleo, NortheastAl, HDRock and 2 others like this.
  7. Kimberly
    Kimberly
    The Kangaroo State
    No, I went to visit with my sisters. I noticed the saw sort of chattering or whatever you call it, as I was cutting the locust. I will read the tutorial you linked.
    NortheastAl likes this.
  8. Kimberly
    Kimberly
    The Kangaroo State
    Explain this; "Always file from the inside of the chain out just like the tooth." what is considered the inside?
  9. yooperdave
  10. Kimberly
    Kimberly
    The Kangaroo State
    Your answer is blank.
  11. Eric VW
    Front the center of the saw out. Maybe think of from where the muffler is mounted as the 'inside' or in joinery terms, from the short point of the tooth.
    Clear as mud?
  12. HDRock
  13. brenndatomu
    His answer is in the quote...he highlighted it with bold print...
  14. Kimberly
    Kimberly
    The Kangaroo State
    That tells me nothing but hopefully I am doing it the correct way; I can always look it up on the net anyway.
  15. yooperdave
    It means file it from the same side as you do your tooth! :hair:
    (I think I'm beginning to understand now.....)
    milleo, Eric VW and Ashwatcher like this.
  16. Star Gazer
    Star Gazer
    Right behind you
    Here y'all go!
  17. Star Gazer
    Star Gazer
    Right behind you
    Another option:
    Take the chain in to someone who may work on chainsaws. Chances are either they sharpen the chains, or they can direct you to someone who does. They'll take care of the cutters as well as the rakers. It's a lot cheaper than buying a new chain!
  18. Kimberly
    Kimberly
    The Kangaroo State
    Why would I do that? Besides Jon said the chains were worn so I knew that from the beginning.
  19. Kimberly
    Kimberly
    The Kangaroo State
    You can't see anything in that video, the saw tooth is covered up LOL.
  20. Kimberly
    Kimberly
    The Kangaroo State
    Yes, I have been doing it correctly; pretty much common sense here you know.
