Trying to decide on what new stove to get
Discussion in 'Modern EPA Stoves and Fireplaces' started by Bret Hart, Oct 24, 2015.
  1. bushpilot
    bushpilot
    Eastern Washington
    I would talk with the folks at Englander about the 8 inch chimney, and do what they say. Logic says "bigger is better, so 8 inches is better than 6," but that is not correct when chimney sizing. They have to be "rightsized."
    Greg
  2. Machria
    Machria
    Long Island, NY
    Oh man, that is a REALLY BAD question to ask around here!! They will have you in bankruptcy court in no time! You'll need at least 2 new sheds just to house all the new tools you'll be buying!! ;)
    Good luck with the new stove!!!!
    Horkn, Brad38, Bret Hart and 3 others like this.
  3. brenndatomu
    How tall is your chimney? Unless it is really tall, 8" probably isn't gonna cut it.
    To answer your question though, the further you can go 6" the better.
    I have a stove that is meant for a 6" chimney running on a 8" chimney, it is not ideal for sure. Crappy draft unless is is pretty cold out, smokes out the door on reloads, low BTU output once the secondary burn is done. I am fully aware this is all from too big chimney. My plan is to drop a un-insulated 6" liner inside the insulated 8" liner, problem solved. Kind of a "superinsulated liner" :whistle:
    My suggestion is to do it right to begin with, save yourself the frustration of "problems with this new stove". Remember, the chimney is the engine that drives the stove...
  4. HDRock
    NC30 is a good choice.
    Definitely go 6 inches from the stove to the ceiling, that's how mine is set with my 8 inch chimney, I have a total of a 15 and a half feet straight up, draft is good, I don't have any problem with smoke coming out during reloads or anything .
    All the research I did before I installed the current stove said that's the way to go and will give you a better draft, there are people on the other form also that have 8 inch chimneys and all are set up with six inch stove pipe, theirs and mine all work good, if I remember right I think a couple of those people have NC 30's, maybe mike holton will chime in here and give his professional opinion.
    Whether you are using single wall or double wall, I suggest you get a telescoping stove pipe for easier install
  5. HDRock
    I assume that your chimney is already three feet above the highest point on your roof, is that right?
    Horkn and Bret Hart like this.
  6. raybonz
    raybonz Moderator
    Carver, Mass.
    Well said Bren!
    Horkn, Bret Hart and brenndatomu like this.
  7. SolarandWood
    SolarandWood
    Syracuse NY
    Fwiw your wife will rarely if ever touch anything other than maybe the tstat on a king unless you are gone for days at a time.
    jeff_t, Bret Hart and raybonz like this.
  8. Bret Hart
    Bret Hart
    Central NY
    Pretty sure the chimney is 13' and a few inches off the top of the stove. Been a few years since I installed it but I know its over 13'.
    Planned on the telescoping stove pipe.
    Chimney cap is right at 3' above ridge and more than 10' away.
    S&W - I was all set to get the BK but I'm taking one for the team. I got the GMC, Kubota, equipment trailer, and tons of tools and supplies for the shop this year. Mama gets a vacation and I get a big upgrade in a stove.
    Horkn, bushpilot and raybonz like this.
  9. raybonz
    raybonz Moderator
    Carver, Mass.
    Personally I think you should use a 6" liner for better draft and less creosote plus less smoke spillage when opening the door..
  10. Bret Hart
    Bret Hart
    Central NY
    Just reread my last post. Looks like she's been taking one for the team all along. That's my girl.
    Horkn and raybonz like this.
  11. Bret Hart
    Bret Hart
    Central NY
    So, slide 6" stove pipe inside the 8" class A???
  12. raybonz
    raybonz Moderator
    Carver, Mass.
    If it fits I suppose you could do that.. What do the experts think about this?
  13. chance04
    chance04
    Denton Md
    Not an expert, but it meets clearances and would be insulated by default. Run with it
  14. Bret Hart
    Bret Hart
    Central NY
    chance04 likes this.
  15. chance04
    chance04
    Denton Md
    Correct
  16. brenndatomu
    If it's 13', I'd lay some pretty good odds against that working as an 8", might be tight as a 6", 15' is usually considered a bare minimum height for modern stoves. But since it sounds like it is a straight up chimney, that helps, 90* bends in chimney pipe are hard on draft.
    I hadn't thought of your stove pipe inside of the chimney idea, but that sounds like a simple/easy solution since you have a straight up chimney. :thumbs: Might hafta get a clamp on chimney liner top plate to seal the gap and "hang" the pipe up top...
  17. raybonz
    raybonz Moderator
    Carver, Mass.
    Oversized flue pipe not a good idea..
    Horkn likes this.
  18. raybonz
    raybonz Moderator
    Carver, Mass.
    Oh OK sorry didn't realize was placing 6" inside of 8" yup great idea..
  19. chance04
    chance04
    Denton Md
    If he uses a 6 inch liner run down through the 8 inch class a it isn't oversized any longer
  20. chance04
    chance04
    Denton Md
    I shoulda read down farther lol
