Truckload of old white oak if you want it.
Discussion in 'The Wood Pile' started by mikeward, Dec 24, 2019.
  1. Midwinter
    It looks sharp with that lid!
    Horkn, Winston and mikeward like this.
  2. mikeward
    mikeward
    Long Island, New York
    I moved a lot of wood by hand in spring to fill new woodshed 12 ft deep and 32 fT long. Added some 4ft led lights and elec outlets. The milk boxes are filled with cedar fence kindling cut into 10 inch strips to fit. This is 4 year old wood and some will be burnt next year. I will burn some cherry from here in front right of shed on skids
  3. Canadian border VT
    Great job Mike
  4. mikeward
    mikeward
    I like it a lot and it's strong. Had a branch fall on it an it saved me. Acorns hit it and I cringe in seat from near miss!
    Horkn and Midwinter like this.
  5. mikeward
    mikeward
    Now to wood split that needs to age. This is where I like the pallets. Second pic is 15 skids long, two rows on bottom and one on top of back row.
    Last pic is of pallets I like. All oak very tight spacing. The one on ground to right is sacrificial and put under pallets filled with oak
    brenndatomu, Horkn, Winston and 2 others like this.
  6. mikeward
    mikeward
    Found a new way to pick up log and hold it for cutting. I had a big 12' long branch fall on top of shed and this is how I lifted it off without climbing up with saw and killing myself. Drove it down the trail like that to dump it! This is a cedar log I've been saving just for pic.
  7. billb3
    Some people have much success using wood chips to improve their soil.
    Horkn, Winston, Midwinter and 2 others like this.
  8. mikeward
    mikeward
    We have very Sandy soil and this is a great addition. 4 foot deep Woodchips will make great soil just need to add some lime
  9. mikeward
    mikeward
    Wood for this year is in pic below. Wood is from hurricane Sandy 10/12 /2012. All red oak. Under metal roof since then. This roof is made of 8x8' hot tub skids covered with metal. 8 ft deep 26 ft long and around 7ft high. Red plastic are throwaway cart tops from BJs nearby. The covered red cart was from tractor supply. Plastic sides are from junked hot tub ,red metal roof Added to 3/4 square tube welded frame. Holds almost 1/2 cord. Will get towed up to house.
    brenndatomu, Horkn and Chud like this.
  10. mikeward
    mikeward
    Modified some plant carts being trashed. Loaded now outside back door with pine aged a year. Quick hot fire in morning or evening. Later I'll load with oak and move to load and back to house with tractor forks and roll into place. Stove is on wall opposite sliding glass doors.
  11. moresnow
    moresnow
    Split and stacked since '12? Should be seasoned! Nice setup.
  12. mikeward
    mikeward
    Thanks, a lot of work but very rewarding. Think next summer I'll tear down brick and block chimney and put in metal. I'll be 70 next month and cleanouts will be easier from bottom. I want to keep burning for as long as possible
    brenndatomu, Horkn, Chud and 2 others like this.
  13. mikeward
    mikeward
    I just want to give a shout out to Backwoods Savage .
    If I hadn't found these wood forums and his advice on the 3 year plan I don't know if I'd still be burning. I figure I'm on a six year plan now.
    I followed him and others to this forum from the other one. Great people here and lots of knowledge here!
    Eckie, brenndatomu, Horkn and 3 others like this.
  14. mikeward
    mikeward
    Almost forgot I am still working on the oak dumped buy the tree guys. Not taking any more till this is all done.
    All Oak except for one load of locust and one of sweetgum.
    brenndatomu, Horkn, MikeyB and 2 others like this.
  15. Backwoods Savage
    Thanks Mike.
  16. mikeward
    mikeward
    Backwoods Savage Actually a BIG thanks to you man.
    I used to come home from teaching in middle school and split3 or 4 oak logs for a night or two.
    Put them in my original Vermont castings Defiant and Always have to leave the side door open a crack. Always noticed the water bubbling out the ends but I was so dumb. Never clicked till I read about your three year plan for oak.
    Well you can see that thanks to you things have certainly changes here. I also supply my daughter, neighbor and in laws with old dry wood:salute:
    brenndatomu, Horkn, Winston and 4 others like this.
  17. Midwinter
    And this would keep me awake at night... F4DE7106-6D71-4A59-A665-53DEC3C4B537.jpeg
    Great pics and commentary on your process, thanks!
    brenndatomu, Horkn, MikeyB and 3 others like this.
  18. mikeward
    mikeward
    Don't forget all those rounds would have been taken to the dump and ground up into mulch.
    I've split half of what was delivered and I will keep plugging away at it!
    Its oak Ive got time!
    brenndatomu, Horkn, moresnow and 3 others like this.
  19. Canadian border VT
    I did that when when I put mine in.. I’m only 49 BUT done with roofs:yes:
    brenndatomu, Horkn and mikeward like this.
  20. Midwinter
    Years and years!
    brenndatomu and Horkn like this.
