Trimmers - discussion/pics
Discussion in 'Chainsaws and Power Equipment' started by RCBS, Apr 25, 2023.
  1. Ohio
    Not Ohio
    My neighbor is quite aloof and has multiple Russian olive trees that grow into the driveway. A few times a year I have to give this one a tuneup. I don’t own a hedger so echo SRM2620 for the win.
    Horkn, John D, eatonpcat and 3 others like this.
  2. Mrxlh
    Mrxlh
    Dat Boot
    A tad, but it doesn’t bog in smut grass or thick stuff. Wondering if porting them would help?
    Horkn, eatonpcat, Farmchuck and 2 others like this.
  3. Eggshooterist
    Eggshooterist
    Erff
    That sounds like me. Lol
  4. Farmchuck
    Farmchuck
    Nepa
    That’s what I was wondering. Although I don’t read much about anyone porting string trimmers of brush clearing saws. I thought when I posted the question maybe someone might have had experience with doing it.
  5. eatonpcat
    Thanks Steve, I will give it a shot!!
  6. Dok440
    Dok440
    NorCal
    I left these a little too late. A week ago the string was tearing these up. Now it's like slapping small trees.
    Horkn, eatonpcat, John D and 3 others like this.
  7. Eggshooterist
    Eggshooterist
    Erff
    Kevin ported a pole saw last year.
  8. JRHAWK9
    JRHAWK9
    Wisconsin
    I'd like to try clearing that with my 555 with the brush blade. I tried the brush blade once and it was WAY overkill for what I have to clear. Couldn't really go WOT with it, just not enough load there to keep the RPM's down. With the 14" brush blade there's a ton of momentum in that metal when it gets spinning. Then if you happen to hit a stump or something, yikes! :eek: String head works best for me in the brush I have to clear. When using the saw blade I am cutting small trees, so there is load there.
    Horkn, eatonpcat, morningwood and 2 others like this.
  9. Ohio
    Not Ohio
    That is at the size a tri blade would make quick work or that stuff. I go down to the lower drive with the string head and should have brought the blade/bike handle unit.
    Horkn, eatonpcat, Dok440 and 2 others like this.
  10. Ohio
    Not Ohio
    I had to pick up some fuel filters for the saws and strimmers at the stihlership. I broke this part yesterday, it’s what the harness hooks to on the bicycle handle FS110. IMG_1999.jpeg
    The guy at the parts counter said.
    “ In my history of working here I have never seen anybody break one of these. You are weedeating too much.”
    They had the part that came with a harness for $9, he said it had been sitting upstairs since 2017. I’ve owned the trimmer since 2016. I told the guy the next time I break one I’ll buy a new unit.
    Horkn, eatonpcat, Barcroftb and 4 others like this.
  11. Dok440
    Dok440
    NorCal
    I would love to hit it with a blade but we are in extreme fire danger for the next few days. 14" brush blade holy cow! I think the one that came with the 3020 is only 10".
    Horkn, Barcroftb, Ohio and 2 others like this.
  12. Dok440
    Dok440
    NorCal
    I'll try the blade if we get some humidity. :yes:
    Horkn, Ohio, John D and 1 other person like this.
  13. Dok440
    Dok440
    NorCal
    Ha ha ha! Glad they had it in stock! That IS a lot of weed eating.
    Horkn, eatonpcat, Ohio and 2 others like this.
  14. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  15. Ohio
    Not Ohio
  16. Dok440
    Dok440
    NorCal
    JD Guy, Horkn, eatonpcat and 3 others like this.
  17. Horkn
    I'm about to buy one of the toro flex force 60v string trimmers. That is unless someone can talk me out of it. It seems they have a really good selection of interchangeable tools. The pole saw and the blower look like about the only other tools I'd really need. Then again, they do have a chainsaw for that battery system too....
    eatonpcat and John D like this.
  18. 0rion
    0rion
    We're moving and in the process I stumbled across my old Stihl fs55r that I had problems with. Going to revisit that after the move. Lost spark while trimming so ordered a coil and never got it to run on the new coil....just a backfire here and there. Keyway was fine so think the Chinese coil is the issue. Going to try and find genuine Stihl coil and see what that does.
    Horkn, John D and Dok440 like this.
  19. Dok440
    Dok440
    NorCal
    I can't tell you whether Toro battery stuff is any good, but I support the decision to go with some kind of battery powered setup. When I'm using the power equipment frequently gas powered is fine. With the crappy gas we have, occasional use is a pain. First I need fresh fuel to mix or canned gas. Afterwards I have to dump the fuel and run the engine/carb dry. That is asking a lot if I only need to use something for a few minutes. A battery powered chainsaw and trimmer would be real nice, some day. I'd like to know if anyone has a battery powered trimmer and how they like it.
    brenndatomu, Horkn and John D like this.
  20. Dok440
    Dok440
    NorCal
    If the coil is like that stuff on Amazon I think you are right. Most of it is either dead on arrival or deal soon after installation. That trimmer is definitely worth getting going again.
    brenndatomu and Horkn like this.
