Tree id
Discussion in 'The Wood Pile' started by Woodsnwoods, Jul 4, 2021.
  1. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Any idea what this is? Ash bark, elm leaves? A5A16C87-DA2E-4302-B6BE-369FFD747E3D.jpeg 1BBEB769-462A-4408-90C1-658ECDC31A86.jpeg 008C7F9F-8D37-405B-85D5-56ABB825BA89.jpeg 5A50708B-61A3-4A9B-B816-7E5064056331.jpeg 620E809B-2F3D-47DC-9DB7-C4A58E8FFDB4.jpeg
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  3. buZZsaw BRAD
  4. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
  5. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I'm in for slippery, aka, red elm.
  6. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Red elm…..guess I will let that one live muddy the maples.
  7. BuckeyeFootball
    BuckeyeFootball
    Elm, most likely slippery.
  8. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Never heard of slippery elm before!!
  9. Ralphie Boy
    Ralphie Boy
    It's used for all kinds of things from furniture from the lumber to medical usages from the inner bark. Also known as red elm.
  10. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Medium level firewood when it comes to BTU etc?
  11. buZZsaw BRAD
    Yes. I avoid it for the splitting issues. There is some sitting roadside right down the street from me and i havent touched it other than helping buzz-saw scrounge some.
  12. harrisonh817
    harrisonh817
    Salisbury
    Some old time pitchers used the sap to throw spit balls. My uncle tried it once and threw ball over the backstop.
  13. JimBear
    JimBear
    It out performs what the charts say, I have never had any issues splitting Red Elm. In my experience you can split it green & it still holds its heating value unlike American Elm which seems to total lose its heating value when split green.
    That looks to be a pretty good sized one, around here they generally die around 6” - 12” dia. range. Occasionally you will find one around 20”dia. but that is a rarity. It is a sought after wood around here.
  14. huskihl
    huskihl
    Let it stand until the bark falls off. It splits fine after that. When I was a kid it was a staple for our heat
  15. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I have burned elm, but it was a nightmare to
    Split. The tree is alive, so I will let it live till another day. :salute:
  16. JimBear
    JimBear
  17. Eckie
    Eckie
    I don't want to totally highjack the thread..... But can you please explain the above statement? I've never done much with elm and have never heard that....but it makes no sense to me...
  18. JimBear
    JimBear
    In my experience American Elm is a strange beast: If when cut while alive, then bucked it may or may not start to season & dry down, sometimes it just rots in bucked form. If cut while living, bucked & split it is terribly stringy, does dry but seems to burn very fast & leave a lot of ash. If found standing dead with no bark it may be solid as a rock or punk from top to bottom but if solid it burns great, produces a lot less ash & a lot more heat. You can split those dead rounds & they burn the same as dead rounds but the green cut Elm that were bucked & split you may as well be burning toilet paper.
    Slippery or Red Elm in my experience has none of the weird tendencies. Cut it green, buck, split it burns no different than a standing dead Red Elm. Red Elm also will stand/lay around for years & not rot unlike American Elm. Maybe Backwoods Savage can explain it better or add some insight.
    Backwoods Savage, Eckie and huskihl like this.
  19. huskihl
    huskihl
    I think you’re close. Standing dead white elm was always a little mealy. Not quite punky, still had good weight, but acted like it was on its way out. Doesn’t dry well if not split.
    Red elm gets a tiny bit stringy, kinda like splitting a nasty piece of ash. But I’ve never seen it go punky if it’s standing.
    Backwoods Savage and JimBear like this.
  20. Eckie
    Eckie
    Thanks JimBear. I have a hard time wrapping my head around that if the tree was living and turned into firewood it doesn't burn well, but dead first does better. I would really like to know the "why" behind it. I'm not good at id'ing the different elms. I have access to several big elms from the ice storm that I need to process. Hopefully they're the "good ones"!
