Tractor pictures
Discussion in 'Chainsaws and Power Equipment' started by concretegrazer, Aug 12, 2014.
  1. fuelrod
    fuelrod
    Western Maine
    Mike I remember when you got that tractor, makes you wonder how you ever made due without it right? :dex:
    Hammy, eatonpcat, Horkn and 3 others like this.
  2. Woodslave
    Woodslave
    Northern New York
    Hammy, eatonpcat, Horkn and 2 others like this.
  3. fuelrod
    fuelrod
    Western Maine
    For all you with an 'open station' tractor guy's that push your snow with it. I bought some electric motorcycle gear last year. Just a jacket & the controller to start with, iirc about $240. The guy there said to start with the jacket and that usually if you keep your core warm you'll be fine. I'm telling you he was right. They do have socks, gloves & pants but the 'core' deal and my carhart bibs keep the rest warm and cozy. Much cheaper than a cab door glass replacement :whistle:
    and not being a farmer, most of us are on & off the machine regularly so a cab can be sort of a hassle.
    Maina, Hammy, amateur cutter and 4 others like this.
  4. Woodslave
    Woodslave
    Northern New York
    Really nice grapple, I love my grapple, no more piling brush by hand
    Hammy, Horkn, concretegrazer and 2 others like this.
  5. Gasifier
    Thanks. I had my neighbor, who is a machinist by trade but also a good welder, make up the frame added to the top. It allows me to pull three pins and adjust it so I have a bigger opening. Usually it stays in the smaller opening position but is handy when I have bigger piles to put together and move to burn.
    Hammy, amateur cutter, Horkn and 3 others like this.
  6. JCMC
    JCMC
    Just outside of Shushan, NY
    Maybe you should put them on CL :rofl: :lol: free wood :santa:
    UncleJoe, Hammy, Gasifier and 6 others like this.
  7. concretegrazer
    concretegrazer
    Southwest MO
    Downhill is no issue . My grandpa had the front of a fwa 2950 (with just the bale spear on front) off the ground hauling a partial load of green hay/balege up a steap grade.
    Id try to have that excavator over the axles. Maybe put the boom up front?
    fuelrod, Gasifier and Well Seasoned like this.
  8. Horkn
    Well, the old Kohler kt17 engine on my ariens went South last night while mowing.
    I'll have to check the hour meter to see how long it lasted. It was a series I. Then it was replaced under warranty in 84 with a new engine. It's been the same since then.
    I'm looking at Honda gx630, Kohler command pro, and Briggs and Stratton vanguard repower kits. The Japanese made Briggs ( daihatsu makes the vanguard) and the Honda are my top choices. Both have repower kits so that the process is simple to swap engines.
  9. clemsonfor
    The Kohler command 15 engine I have on the rider at my farm is a good strong engine. 15hp single cyl. Good on fuel too. It uses about half the fuel of the Briggs V twin I have in the troy bilt at the house. I think it's 18.5 hp?
    They both have the same cut width and seem to work the same amount, meaning ground speed while cutting is similar, if anything I'd give the advantage to the Kohler powered mower.
  10. OhioStihl
    OhioStihl
    Southern Ohio
    That sucks. I can’t like that post. Good luck with the upgrade
    brenndatomu, Hammy, eatonpcat and 4 others like this.
  11. clemsonfor
    I'm thinking the family got their money out of it, that's 34 years on that motor! He would of just been a boy when his family or the original owner, whoever that is , got it.
  12. Horkn
    It's all good. 2k for the drop in Honda gx vtwin with all the engineering done from wiring harness to PTO shaft adapters to engine mount plate. They give unlimited assistance and will send any party you may need. The kits are made so that consumers can simply install in a couple hours. They say guys that have installed repower kits have gone from unboxing the crate to mowing the lawn in 3hrs.
    My dad bought the tractor new in 84. It's a series 2 kt17. The original series 1 was replaced the first summer. So it's got a lot of sentimental value since he's gone, in addition to the fact that I put most of the hours on the tractor as I was 9 when he got it.
    It's earned it's keep, and a repower.
    I'll start a thread on the repower when I get to it.
    brenndatomu, Will C, Hammy and 5 others like this.
  13. Backwoods Savage
    It's been a while since I've looked at this thread so thought I'd post this. Just finished working up some food plots and wow, the dust. So brought the tractor up and just sprayed the dust off.
    Maina, fuelrod, brenndatomu and 10 others like this.
  14. J. Dirt
    J. Dirt
    Looking good!! Hope you get a little rain to wash the seed in!
    Maina, brenndatomu, Hammy and 5 others like this.
  15. Stephiedoll
    Stephiedoll
    Omaha, NE.
    A little over a year ago I helped my dad move some of his tractors out of his old shop that he sold about 5 years ago, new owner was asking if he was ever going to so he could use the space. Maybe someday one of them will be mine.
  16. Stephiedoll
    Stephiedoll
    Omaha, NE.
    A couple more pictures and not all of his inventory. Always loved those old 2 cylinder JD's.
  17. Backwoods Savage
    Yes, but hopefully not enough rain to drive the seed out. That happened a few years ago when it had been dry but then we got moisture so I planted some clover seed. Bingo. We then got 4-5" of driving rain. All seed ended up on top and of course, in any low spot. Nothing grew. Replanted, but that gets expensive.
    All the food plots will get oats or wheat this fall. Oats will go in probably in about 2 weeks. Wheat will wait until late September. I'm hoping to plant some wheat and then seed that into clover next spring.
  18. Screwloose
    Screwloose
    What happened to the Kohler ?
    clemsonfor, Chaz, brenndatomu and 3 others like this.
  19. J. Dirt
    J. Dirt
    :binoculars:
  20. Horkn
    Not certain yet. It made nasty noises and was super low on power and was blowing smoke from the exhaust. It had a ton of hours on it. It still does turn over. But until it shut off, it was low on power when it went probably running on 1 cylinder. I've heard the connecting rods can go.
    It's a series 2 kt17, so at least it had pressurized oiling, unlike the series 1 it had when brand new. I'm leaning towards the Honda gx630 vtwin to repower it.
