Tonight's full load
Discussion in 'Modern EPA Stoves and Fireplaces' started by bogydave, Nov 22, 2013.
  1. bogydave
    Might be tough on the glowing cat to get hit with room temperature air o_O
    jeff_t and clemsonfor like this.
  2. Machria
    Machria
    Long Island, NY
    Bypass, then open door, pic, shut door, wait minute, bypass again. ;) We just want to see what the fire and logs are doing....
    clemsonfor likes this.
  3. bogydave
    New load, not as tight as an overnight load.
    Start up pic, bypass closed but cat not engaged yet ,air on high: no flash
    15 Min later, tuned down to medium, flash , cat engaged & glowing bright orange.
    SolarandWood, Chvymn99 and papadave like this.
  4. Machria
    Machria
    Long Island, NY
    Thanks Dave. Please report back with pictures on the hour each hour for the next 5 days!
    :D
  5. bogydave
    + 1 hour
    Door Open, no flame yet, will light up if I leave it open very long. Stove real hot.
  6. bogydave
    Above is what it does unless I adjust for more heat.
    A little more air on will have some flames, more air more flames.
    Cat glows hot for long time.
    This load good till 10 or 11 tonight , at the 20° outside temps. House 71°
  7. clemsonfor
    So how many hours is that? U took one at 5pm and that's an hour into it and it will Las rill 11pm? So that's 7hrs?? This is a blaze king on low? I thought they lasted 18-24 hours like this!! Or am I wrong on times? My high valley stove on a low setting like that lasts 14 hours easy sometimes on a packed load on low with good wood and coals to relight I can get 22 hours.
  8. bogydave
    1:43 PM here
    Yea
    in SC,
    I cold get some long burn times too. :)
    milleo and concretegrazer like this.
  9. bogydave
    Outside 40° days, 30°s at night,: Shoulder season
    I average 24 hour burn times with my set up
    Was fairly warm last night 13°, 50 mph wind gust though, chill factor -12.
    12 to 14 hour burn times pretty good IMO.
    Chvymn99 likes this.
  10. clemsonfor
    Haha yea forgot about the time difference. And yea diff climate too. But if I turn my stove up to much I worry about flame impingement . I will suck the flames up into the cat if I push it to hard. But I guess 8 hrs is a "fast" burn for my 3.5cuft stove. But I have an uninsulated home and try to heat 2000sqft so a 20f night can really push my stove! Well stove room is insulated and I have r19 in ceiling!
  11. Chvymn99
    That's pretty impressive load.... Thanks for the pics, pretty cool.:thumbs:
  12. jeff_t
    jeff_t
    SE MI
    Put this one together about 1.5 hours ago. Unfortunately, I can't get a decent pic thru the glass, and it's at 600+, so I am not opening the door.
    The glass is actually pretty decent after I scraped some crud off, but the camera on this phone is more complicated than it needs to be. I'm sure there is a setting that will allow me to take a pic right thru the baked on creosote. Maybe even thermal imaging :confused:
    concretegrazer likes this.
  13. SolarandWood
    SolarandWood
    Syracuse NY
    Lasts 14 hours? I am on 24 hour burn cycles with the crap wood I am trying to get rid of. Best 24/7 heater on the market. Just wish they would make a bigger one.
  14. clemsonfor
    Jeff, is that pine?
  15. bogydave
    Haven't cleaned my glass since last year.
    Basement install , stove for just heat is nice.
    Glass smoked up a little , lower setting now 30° here. cleans up when I burn hotter.
    3 hrs burn time
    5 Minutes ago; 1600 Ak time, :
    Cat is cranking out
  16. jeff_t
    jeff_t
    SE MI
    97% ash. That little half round in the upper right is oak.
    My glass is yucky all the time. If I clean it and burn hot, it stays decent for a short while. It won't clean up with a hot burn. The crap in the corners will get flaky and wipe right off, but that's as good as it gets.
  17. clemsonfor
    High valley must have a pretty decent wash system cause my glass stays clean even in a slow burn. It even stays decent burning 35%mc oak not that I do much of that.
  18. SolarandWood
    SolarandWood
    Syracuse NY
    The BK burns way low...this is when I see it on the glass. Otherwise with dry stuff in the winter I only get a little in the corners.
  19. clemsonfor
    I can burn 24 hours but prolly not the heat u get. And I don't get crudy glass normally even low
  20. bogydave
    Yea
    A down side of the BK is the dirty glass.
    But I still got the glass door option, it's never totally blacked over.
    Better now with the 2 & 3 year seasoned birch.
    Birch bark is a black smoke, like burning coal,
    not sure if that's part of the dirty glass though.
