To buy or not to buy. That is my question?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Marshal, Mar 27, 2017.
  1. jtakeman
    I'd watch these old movies again and it would be like watching them for the first time............... :whistle:
    :emb:
    imacman, bogieb, BHags and 1 other person like this.
  2. heat seeker
    heat seeker
    Connecticut North Central
    I LBT mine with the ash trap doors off, and the main door open. The suction is more than ample to clear out the ash. I still never get a whole lot of ash out. I think my routine cleaning the stove with the combustion blower running gets most of the ash out of the stove.
    For $1000 I'd be all over that stove!
    Ditto on greasing the upper auger bearing. Mine was on the verge of seizing when I replaced the auger motor. The
    Versa Grate bushings (2) need lube also, which reduces the strain on that gearbox for longer life.
    jtakeman, will711, bogieb and 2 others like this.
  3. imacman
    imacman
    Denver, NC
    Maybe because you have everything open. Can't develop any real vacuum that way. You want to get the air flow from the intake through the exhaust, not from the room. Disconnect the pressure switch, and just crack the door......see what you get then.
  4. heat seeker
    heat seeker
    I don't get a whole lot of ash out because there isn't much in there. I get plenty of airflow. Vacuum, as you say, is not the key - airflow is, which is why I have the door open and the small doors off. I've checked out the passages with a mirror, and they are quite clear.
  5. imacman
    imacman
    Denver, NC
    In this situation, more vacuum = more airflow
    bogieb likes this.
