Tire Life on a Hydro
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, Sep 11, 2024.
  1. buzz-saw
    buzz-saw
    Ct.
    Time for a new one. :makeitrain"
  2. brenndatomu
    Tubes are like $10...:whistle:
  3. MikeInMa
    Time for some new rubbers, Brad.
    :rofl: :lol::rofl: :lol:
  4. buZZsaw BRAD
    Went to move the splitter and it was totally flat. The cold air did it! Ill bring the compressor over today and blow it up. IMG_6580.JPG
  5. buzz-saw
    buzz-saw
    Ct.
    Time for a new one or a tube, Chances of it fixing itself are probably slim.
  6. brenndatomu
    Bring a little jack too...you'll probably have to get that tire completely off the ground to get it to even seal up enough to take air.
  7. Horkn
    Slime it.
  8. buZZsaw BRAD
    An improvised lever last time with a log, 2x4 and another log to prop it on. Did the same today.
    A little redneck physics goes a long way.
  9. brenndatomu
    Doesn't typically work too well on stuff that very rarely moves...unless the bad spot just happens to be parked down
    Screwloose, Horkn, eatonpcat and 2 others like this.
  10. buzz-saw
    buzz-saw
    Ct.
    Don't tow that in winter after it freezes inside the tire either.
    Then when you bring it to get replaced you make some friends when they break the bead, and that stuff is splattered everywhere. LOL = "not"
  11. MasterMech
    Oh I'm very aware of the cost for tires these days. Just wrapping up rebuilding our minivan which involves new wheels and tires. Fortunately, I found a set on closeout for a deal.
  12. Horkn
    I've had good experience with the slime, even in things like this.
    Never any problems with that either. I don't put a whole lit of slime in. Just enough and it ends up going to the leaky areas and stays. I'm my personal experience at least. As far as a mess when removing them with slime? Not an issue is you don't use a lot of it. Sure there's a slight amount but it is not like fix a flat. That stuff is not fun to clean up.
    Now I did have a gorilla cart tires that dry rotted and I used a tube that had a slow leak in it to fix that sidewall dry rotted tire. I put a little slime in that tube. Well let's say that an air compressor even a small pancake one, can get enough psi to have the tube blow out the rotted sidewall and sound like a gunshot. There was a very slight amount of slime on my shoes. Wife came running out asking if I was ok. Had a good laugh about it.
    I do need to add that this is only for off road and low speed tires. I never use it on road going machines. There's even a warning on the container about not using it on road stuff.
  13. buZZsaw BRAD
    The other tire is now losing air. Had to inflate it today. Does anyone know the recommended psi? I couldn't find it on the tire?
  14. brenndatomu
    It's on there somewhere...but you should be safe at 30psi...could be higher, depending on the exact tire...
  15. buZZsaw BRAD
    I did 35. I looked and looked going as far as wet wiping the tire where the writing was embossed. Used my 20volt Dewalt inflator for the first time. Blew it up quick with a 6amp battery in it as it was only at 5psi.
  16. brenndatomu
    Check both sides? I've seen tires with pressure listed on one side only
  17. Screwloose
    Screwloose
    China tire? Could be on the inside.....
  18. RCBS
    RCBS
    Over here
    I run around 20 in mine. I like them a little softer. Splitter never sees asphalt.
  19. buZZsaw BRAD
    I was on my hands and knees looking. No way I was seeing the other side of the tire.
    Wondering if it will hold air?
  20. MAF143
    MAF143
    North Central OH
    My splitter tires say 60 psi for full load but it's much lighter so I run about 35 in them.
