Timing Advance 362
Discussion in 'Chainsaws and Power Equipment' started by lukem, Dec 18, 2024.
  1. Creekin
    Creekin
    Manitoba
    Really tempted to try this on my saw, 362cm
    Now that some time has passed, have you noticed any difference ?
    Mtronic playing nice?
    I find mine kinda lacks the grunt with the 20" bar buried
    Was considering upgrading saws, but it's a toss between a saw and new glasses!
  2. lukem
    For a non-ported saw it's pretty spicy now. 10/10 would do it again.
  3. Creekin
    Creekin
    Manitoba
    Cool!! I might just give it a whirl!!
  4. Creekin
    Creekin
    Manitoba
    Well, I gave it a go
    Early feel is it definitely woke this thing up! Haven't buried it in big stuff yet, but throttle response feels snappier !!
    Super pumped!
  5. lukem
    Sounds like it did the same thing mine did. It should pick up quite a bit in the big wood. It can bury a 20" bar in the hard stuff and doesn't really care.
  6. Dennis Jay
    Dennis Jay
    New York
    Your approach seems on track. Calculating .21 inches on the flywheel for 6 degrees of advance aligns with your math, given the 4-inch diameter. Filing the key to rotate the flywheel so your new timing mark aligns is a common method for advancing timing. However, proceed with caution. Small engine modifications can lead to higher RPMs, affecting reliability and safety. Make sure any adjustments are precise to avoid engine damage. Also, consider testing incrementally, starting with 5 degrees to minimize risk. Keep an eye on engine performance and temperature, as improper timing can cause knock or overheating. Always ensure your modifications comply with local regulations regarding
    brenndatomu and Creekin like this.
