Timber Tuff Customer Service Aaa+++!
Discussion in 'Chainsaws and Power Equipment' started by Pallet Pete, Sep 19, 2014.
  1. nate
    nate Banned
    Palmer, AK
    That's about what I pay for brand n
    ew ones!
    savemoney and HDRock like this.
  2. lukem
    A "good" circ saw blade is $80 minimum. Yes....they are worth it.
    savemoney, HDRock and Pallet Pete like this.
  3. clemsonfor
    I am sure theirs cut cleaner than the ones you and I are buying for $9
  4. Cut4fun
    Cut4fun
    OHIO Redneck
    Switch on my USG went out years ago. I got it to be always on and just unplug or use switch on the strip pad. Just to lazy to bother getting a new one.
    clemsonfor likes this.
  5. nate
    nate Banned
    Palmer, AK
    Probably when doing fine carpentry work. I use
    a saw for cutting framing, boards with nails, roofing, aluminum sheeting, stuff like that.
    HDRock likes this.
  6. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Where I work we use Forrest, Frued and Diablo 80 to 120 tooth blades for clean cuts. If we can order one for less than $160 we are doing good. When I did roofing we used $15 Harbor Freight titanium nitrate coated blades. So I suppose it depends on the industry for sure...
    HDRock and clemsonfor like this.
  7. nate
    nate Banned
    Palmer, AK
    Got the new unit from Amazon and it seems to be ok, though Amazon sent me a "parts" machine that I guess had been returned before or something. The box was smashed and had about 200 ft of clear tape holding it together. It got sent that way since it was put in an outer Amazon box which was not damaged.
    It was missing most of the packaging to hold the parts secure so it all got banged up. Looks like it may have been used. I was able to make one good one though and I'm sending them back whatever parts were left over.
    The degree plates on the back and top seem to match up on this one too. The old one would say 50* on one while the other would read 60*. I forget which was correct now but I had checked with an angle gauge and one of them was right.
    clemsonfor and HDRock like this.
  8. clemsonfor
    Yea they probably sent you a "used" one which usually is something g someone had opened most of the time is all. Others it could be something someone opened used and could not figure out in this items case so they returned it?
  9. Pallet Pete
    Ovid
    O I forgot the switch arrived thursday. Not fast but not slow shipping either... It took about 5 minutes to install the new one and away I went.
    DexterDay and Chvymn99 like this.
