This is why you use marker sticks….
Discussion in 'The DIY Room' started by gaberelli, Dec 18, 2022.
  1. clemsonfor
    I guess what I was saying is with 3" of dirt on top of mine if it was days and days below zero and up to negative 30 my tank I know would be frozen solid.
  2. Canadian border VT
    gaberelli you are not a complete idiot until you do it 2 years in a row!
    my tank is 6 feet under ground BUT I know an idiot; that out a 24’ above ground pool on his D box:whistle:
    the next year built retaining wall around it
    Next year poured 25 foot circle 18” wide with rebar and 6 yards of pool sand in circle so legs would be level and concave sand so I did not have to deal with wrinkles
    Then build 12 foot deck 1/2 around it
    2 summers later tore all apart and replaced distribution box. It collapsed all sand filled lines it was a chit show
  3. gaberelli
    gaberelli
    Wisconsin
    Yup. Drain field clean out. There’s a couple of them but this is the one I tend to plow over…and the protective 4” pipe section surrounding the actual clean out pipe stands no chance against me. Shatter it into 10 pieces on my way to decimating what is guards.
    Horkn, T.Jeff Veal and brenndatomu like this.
  4. gaberelli
    gaberelli
    Wisconsin
    The brittle 4” or 5” PVC out outside is there for just that. To protect the clean out pipe inside of it.
  5. gaberelli
    gaberelli
    Wisconsin
    It’s a mound system. House plumbing is not lower than system (on slab) but drain field is. Pump in holding tank pumps it up to the drain field.
    Horkn, Biddleman, morningwood and 3 others like this.
