Thinking of buying a new saw. Looking at the MS271 thoughts?
Discussion in 'Chainsaws and Power Equipment' started by CHeath, Jan 4, 2018.
  1. Fabz
    Fabz Banned
    Buffalo ny
    Imagine the engine as an air-pump ... more air/fuel in and out = more power ... if done correctly the saw will run COOLER than stock and last just as long ! It’s done to get more work done in a shorter time ... also if done correctly you are getting a saw with the cutting speed/power of the next class up or in some cases 2 classes up without the additional weight ... if you are cutting all day that makes a BIG difference ... done correctly you can expect between 20%~60% faster cutting depending on saw model and skills of porter ...
    Woodsnwoods and brockcolelee1994 like this.
  2. farmer rob
    farmer rob
    Dundalk Ontario Canada
    Thank you for that information I will assume a Stilh dealer is not the place to go for this Mod on my saw?
    brockcolelee1994 and Woodsnwoods like this.
  3. Fabz
    Fabz Banned
    Buffalo ny
    Correct
  4. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I agree with others. The 461 would be my recommendation. Mid range, not heavy, great power. If you get into big stuff, you will be happy. I cut a lot of trees in my greens with an 025. It did the job, but took 2-3 times longer. If you can hit a logging show this spring, you can save a hundred or two and get a solid saw.
    brockcolelee1994 likes this.
  5. Fabz
    Fabz Banned
    Buffalo ny
    I have a 461 that’s “under the knife” as we speak ... should be a ripper when done
  6. brockcolelee1994
    brockcolelee1994
    461 460 046 all my favorite saw, so versatile. Hopefully that saw gets out of surgery soon and into some wood. Just finished cleaning mine up as we speak.
    Woodsnwoods likes this.
  7. Fabz
    Fabz Banned
    Buffalo ny
  8. mike bayerl
    mike bayerl
    A whole lot of testosterone in this thread. It went from MS250 vs. MS271 to ported 046/460/461. Just sayin'.
  9. brockcolelee1994
    brockcolelee1994
    Nothin wrong with a little testosterone. But yeah did sway a little off topic. IMHO there's not much of a difference between a ms250 vs ms271 to justify not buying a bigger saw than both. I was taught it's better to have it and not need it than not have it and need it. Just my 2 penny's worth.
    tamarack and Woodsnwoods like this.
  10. mike bayerl
    mike bayerl
    I never said it was bad. Just fun to notice.
  11. Fabz
    Fabz Banned
    Buffalo ny
  12. Fabz
    Fabz Banned
    Buffalo ny
    Well for 549 you get a 241c but for 50 more you get a 261c but for 150 more you get a 362c but for 200 more you get a 441c but for 120 more you get a 461 etc etc ...
  13. brockcolelee1994
    brockcolelee1994
    Yeah that's what I was getting at, I'm not saying to buy a saw that you'll never use, but within your limits and of course budget. I went ahead and picked up a 261 after looking at exactly what the OP was looking to get because I just saw the potential for having a larger and lighter saw for use for just about anything.
    Woodsnwoods and Fabz like this.
  14. dougand3
    dougand3
    North Alabama
    While you're over there, you might find a great deal on a Wild Thang. They are local and all.
  15. Fabz
    Fabz Banned
    Buffalo ny
    Yeah ! I have a 261c with a 16” bar that’s modded and I like it ! It’s just that I like my ported 241c with a 16” a tad more ... I “Wood” be willing to part with the 261c for the right price ... it’s sporting a 16” picco 3/8 sqr/sqr chain ; muffler ported ; modded combustion chamber and large felling dogs with chain catcher ... comes with 2 xtra chains to sweeten the deal ... also throw in the 16” 3/8 .050 bar chain and rim ... it’s in MINT condition with about 20 tanks of fuel run thru it ...
  16. brockcolelee1994
    brockcolelee1994
    Lol yeah I do tend to lose track of the topic at hand, but once Pandora is out of its box it's hard to put it back. If you know what I'm say'n.
    KsKent, mike bayerl and Woodsnwoods like this.
  17. brockcolelee1994
    brockcolelee1994
    Now that's a deal I wouldn't have turned down if I hadn't purchased one myself. I am currently waiting for the 462 to be released in the U.S., so I'm trying to save all my cash as that thing will empty out my piggy bank. Im sure someone here will pick that up off ya.
    Also just curious as to what makes the 241 a more favorite for you?
  18. Fabz
    Fabz Banned
    Buffalo ny
    It’s lighter and faster ; it’s not just favored over the 261c ... I have several saws and the 241c in its present configuration is the go to in 14” smaller wood ... the 261c is not modded to the degree that the 241c but if it were and was a tad quicker I STIHL wood prefer the 241c !!!
  19. brockcolelee1994
    brockcolelee1994
    I see that makes sense. The 241 is about 2lbs lighter? for only a little less than 1hp difference?, which in your case since it is ported, probably the same hp and 2 lbs lighter. I'm probably off on my specs For the saws. For your given wood sizes i probably would take the 241 as well. Besides the fact that thing is probably really fun to use.
    I only use my 261 for the firewood I burn. I would love to port my 261, but it would defeat the purpose of saving fuel to heat the house. I do fire restoration and everything we cut for work is almost all bigger than 20". So that's where my bigger saws come in. All my saws are stock except for little muffler mods, and my poor man's port jobs of just cleaning the casting imperfections. Can't even really call it a port job, but I have seen improvements.
    I feel as if we have hijacked this thread and my apologies to the OP, I am new here and don't know where to start or end.
    Fabz and Woodsnwoods like this.
  20. Rope
    Rope
    Alaska
    I am right where what your talking about. I am using a ported 026 quite a bit, my 261 is in line to be ported now. I have a ported 461 that I am bucking with, not using the 441 as much, now that I have the 461.
