Things to look for in a wood stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by rdust, Dec 1, 2013.
  1. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Being a scrounger, I get wood of all lengths. It's nice to have a big, deep firebox that can hold 20-22 in splits easily. I can even put some 27 in splits in corner to corner and some big uglies.
    fox9988 and Trilifter7 like this.
  2. Waulie
    Waulie
    -Bigger than you think you need.
    -Surface to cook on.
    -Nice looking.
    -Well built.
    -Easy overnight burns.
    -Radiant design with no fans. Although this is pretty house specific. My radiant stove actually works much better than my previous convective stove with fan at keeping consistent temps in my wide open home with loft. Plus, I HATE the constant sound of the fan.
    -Good dealer and/or manufacturer support.
    -Offer a decent range of heat output for a given load of wood.
  3. Backwoods Savage
    But what if the stove provided it's own electricity? Would that interest you?
  4. mattjm1017
    mattjm1017
  5. Backwoods Savage
    For sure Matt. I like those stoves and remember them at the DC challenge. Don't forget that Woodstock is also playing around with making electricity with the stove. They had a small light working in DC.
    mattjm1017 likes this.
  6. mattjm1017
    mattjm1017
    I was fascinated with the camp stoves outside I talked to those two guys for quite a while.
  7. Backwoods Savage
    Yup, we did too Matt. I can see a good market for them and I hope they do just fine.
  8. Daryl
    Daryl
    The Gasifiers, including camp stoves, produce electricity. Check out youtube. The Kimberly also does the same. Not sure if you guys talked to the creator, I forget his name, but on the Unforgettable Fire website they either sell the packs or provide a link. Can't remember.
  9. Fyrebug
    Fyrebug
    If you are shopping for a wood stove here are the specs to disreguard... Sq. ft, BTU, burn times (almost useless specs). Because 1) These are not monitored by any testing lab and it is up to the 'creative' minds in MFG marketing dept to come up with some interesting results indeed. 2) what is the definition of burn times? Sq ft? (cubic air or actual real estate Sq ft- remember it's a zone heater.), BTU (burning what? bio bricks doused in naphthalene? seasoned hardwood on high fire?).
    However, these have been around for years and consumers demands it so the MFG's have to provide it. The more honest ones try to provide reasonable specs. Without naming names *cough, cough Vogelzang, USSC cough, cough* I have seen BTU ratings that are ridiculous for the size of the firebox. The only way you could achieve those BTU is by removing all the bricks, burn tubes, baffles then cram it full with the aforementioned bio bricks and watch the stove melt.
    Firebox cu ft size is the most reliable benchmark as it will provide you with a rule of thumb of how much wood you can put in there. Again, look for a reputable company. Most of those have not sold their soul to China.
  10. Machria
    Machria
    Long Island, NY
    How about:
    1. Would you like or need a cooktop? Some stoves can be cooked on, not all.
    2. How close to the stove will you normally be? Some stoves will blast you if your too close, some are softer heat when close.
    3. Size and SHAPE of stove matters. I don't mean firebox size, but physical size and shape of the outside of the stove. Is it long and thin, or fat and wide.... will it fit your space properly.
    4. Chimney size requirement: 6" or 8"? What do you have, what can you make it, and what does stove require.
    5. Astetics: Do you need a nice looking stove to match decore, or is it a black dragon heater in the basement.
    6. If the stove your interested in has a blower OR you want a blower (I don't know why you would want to hear a blower!), do you have POWER where the stove will be?
