The scene at every last hd around
Discussion in 'The Pellet Bag' started by Charles Ingalls, Aug 22, 2015.
  1. ttdberg
    ttdberg Pellet Pig
    CT
    OK, I am on bag #6. Burning the stove in stove temp mode, heat setting 4. That puts the temp guage on the side of the stove at 400 degrees. At that setting, a bag will last ~12 hours. I do like these a lot. The ash (or lack of) is impressive. Burn pot stays clean for a long time. I agree with Sub, could go through a ton of these before emptying the ash pan. No clinkers or speed bump. These are from October, 2014. What is your experience like with them?
    bogieb, subsailor and slvrblkk like this.
  2. subsailor
    subsailor
    Winthrop, Maine
    That's pretty much what I'm seeing. I'm on heat setting 3 and the temp on the side of my stove is 360. If the stove was just cleaned I'd be close to 400. Heat setting 4 and I'm north of 400.
  3. IHATEPROPANE
    IHATEPROPANE
    Perhaps I got a bit of your luck and got a crap batch of them. Mine are from this Spring and I have had a clinker every time I clean the pot. I will take pics next time I clean the stove.
    Historically these have burned very well. These not so much.
    bogieb and ttdberg like this.
  4. ttdberg
    ttdberg Pellet Pig
    CT
    Yeah I certainly have a habit of getting stuck with bad batches, no question about that. Got lucky this time around! Besides the clinkers, are you getting good heat and low ash from them?
    IHATEPROPANE likes this.
  5. Pete Zahria
    Pete Zahria
    New Hampster
    which side? I have noticed that my right side is usually hotter than the left...
    bogieb and IHATEPROPANE like this.
  6. IHATEPROPANE
    IHATEPROPANE
    Yeah, ash is low. The heat thing is more difficult to determine. I have basically got the same temps from every pellet I have burned when comparing the rate in which they feed. Running on hi/lo also evens out those feed rates unless low is still too high, which is not the case for me this time of year for sure.
    There was one outlier and that has me questioning those results. They were Vermonts, luckily I have some in my stash and will retest them this year. I should be able to reach them in a month or so
