The OH 26 Thread
Discussion in 'Chainsaws and Power Equipment' started by Mastermind, Feb 28, 2015.
  1. Oldman47
    Oldman47
    Illinois
    Here I am looking at trying to put my 026 into service. I cut up maybe 3 or 4 trees when I first bought it ages ago because they were laying on my farm field and now am getting ready to start cutting fire wood so I need a saw again. I don't even have any chipped paint like I saw in one of those pictures. Mine does have the riveted name plate on the engine cover and the winter / summer air selector is a screw on piece that you remove, rotate and reinstall. It has probably been at least 20 years since I last started it and I was coming here to see what I should do before even trying to start it when I found this thread at the top of the forum section. As far as an unfiled chain, I have one of those but I also have an OEM spare chain for the saw so it may have run more than the one referred to above, or maybe not. Frankly it has been that long ago that I forget why I bought it. It may have just been my conservative nature to have a spare.
    My guess would be a carb kit and fuel and impulse tube replacement. I pulled the plug and it looks just fine for a used 2 stroke plug. (Yes I used to ride 2 stroke bikes so I know how they should look.) When I found it in its storage case the plastic hinge on the case failed when I tried to lift it by the handle. There is a puddle of B&C oil in that case, maybe an ounce. There is also maybe an ounce of premix in the fuel tank.
    So, is it time for me to charge out and get a carb kit and a couple of pieces of tubing or do I drag this to a dealer for service? No way am I going to expect it to just start for me. It was always cold blooded even before I stopped using it.
    $ooline, DexterDay and concretegrazer like this.
  2. Mastermind
    Mastermind
    Tennessee
    Fix it yourself. Lots of guys here that can help.
    $ooline, clemsonfor, mdavlee and 2 others like this.
  3. Oldman47
    Oldman47
    Illinois
    OK, where do I start? I am not afraid to do a carb rebuild. I have watched a couple of videos on the subject and it looks far easier than all that float drop stuff and complicated clearance templates I have done on car and bike carbs. Do I even bother trying to run it or just assume the ethanol has ruined anything plastic or rubber exposed to it? Exhaust side is a different matter. By the time fuel gets there it is nothing but CO2 and smoke. I can't imagine much damage on the piston/cylinder parts or even much wear on the clutch and drive components. The thing just does not have that kind of run time on it.
  4. 2manysaws
    2manysaws
    E. central Iowa
    I think you have figured it out pretty well, carb kit, filter, fuel line, impulse line and at least a careful look at boot between carb and cylinder. flush the fuel tank of course. If you really don't want to bother with it send it to me. I will even pay shipping, but don't expect to ever see it again.:rofl: :lol::rofl: :lol::picard:
    clemsonfor likes this.
  5. Air2bmc
    Air2bmc
    Kentucky
    Ethanol shouldn't be a problem if it's been 20 years since it ran. I would clean the fuel tank out and check all the fuel lines for cracks and leaks. Maybe throw a new spark plug in it and see if she'll start.
    angelo c likes this.
  6. MasterMech
    I would try it as is, with fresh fuel mix of course. 20 years ago there may not have been ethanol in your fuel. I've poured fuel in saws that are 40-50 years old and they have fired up and ran. They were not perfect, some needed a carb adjustment, some needed a cleaning, and a few needed more extensive work. But if you get it to run, you have an idea of where to start. A carb clean/rebuild and fuel line replacement on an 026/MS260 is a piece of cake.
    pantelis and concretegrazer like this.
  7. DexterDay
    DexterDay Administrator
    Northeast Oh
    X3 on what was said above. Going back to pre ethanol, I would try it as is.
    Then maybe just clean the carb. The fuel line and impulse are pretty straightforward replacement parts.
  8. 94BULLITT
    94BULLITT
    Frederick County, VA
    I have an old ugly 024 Super.
    $ooline, Deacon, DexterDay and 3 others like this.
  9. 2manysaws
    2manysaws
    E. central Iowa
    $ooline and DexterDay like this.
  10. 94BULLITT
    94BULLITT
    That is the second time somebody on here has made that offer:rofl: :lol: It does run.
  11. SquareFile
    SquareFile
    somewhere
    I gots me ah mint'e 024 Super/026 Hybrid. :smoke:
    IMG_20140801_105847_408.jpg IMG_20140801_105906_537.jpg IMG_20140801_105937_432.jpg IMG_20140730_103056_482.jpg
  12. Mastermind
    Mastermind
    Tennessee
    Now we're digging out the the cherry saws. :)
  13. CNE deer
    CNE deer
    ohio
    Is that a cheap way to increase compression?
    MasterMech, DexterDay and SquareFile like this.
  14. SquareFile
    SquareFile
    somewhere
    Yep, cost $.25 and super glue. ;)
    $ooline, clemsonfor, Hedgerow and 4 others like this.
  15. DexterDay
    Northeast Oh
    Do not take this advise es332..
    Hehehehe:cool:
    clemsonfor, CNE deer and SquareFile like this.
  16. SquareFile
    SquareFile
    somewhere
    Who are you? :eek:
    clemsonfor and DexterDay like this.
  17. DexterDay
    Northeast Oh
    I'm nobody .. :D
  18. Mastermind
    Mastermind
    Tennessee
    Your 461, are you gonna put a 460 coil on it Dex?
    mike bayerl likes this.
  19. redoakneck
    redoakneck
    ohio
    I used 5 nickels, they are fatter and taller for more BANG fer yer 1/4 buck
    $ooline, clemsonfor, cnice_37 and 3 others like this.
  20. DexterDay
    Northeast Oh
    Yes sir. :) I always heed your advice
    $ooline, clemsonfor and Mastermind like this.
