The OFFICIAL Firewood Hoarder's Club thread!!!
Discussion in 'The Wood Pile' started by Scotty Overkill, Oct 4, 2013.
  1. Eric VW
    Lotta pine burners on here, BCPLLC, so wait for it....:tree:
    My folks out in the Northern Neck get a little chillier weather, prolly the Bay causing that, but they use 2-3 cords in a fairly tight house.... 'Course it's about 2000 sq. ft. but the furnace never comes on in the winter.
    You should have access to high power Black Locust, Oaks of several varieties, cherry for sure, should be some Shagbark out there too.... Many excellent BTU species in yer vicinity. Plenty of shoulder season species as well- some of which will fall under one of the many pine types. Oh, don't forget about holly... You've got tons of it out there- and it grows to maddening sizes. Great BTU wood, and nice addition to a wreath come Christmas time. After all, you ain't after the leaves for the wood stove.
    BCPLLC and Shawn Curry like this.
  2. HDRock
    Pine is fine , as long as it's dry . No ,it won't burn your house down :whistle:
    Here's some learnin for ya :)
    Primer on Woodburning by Backwoods Savage 2014-07-24
    papadave, milleo, Chvymn99 and 3 others like this.
  3. Eric VW
    HDRock said BAM!!!
    Now LEARN, man!
    That's great stuff right thar.
    Chvymn99, BCPLLC and HDRock like this.
  4. HDRock
    Sure is good stuff , :yes:saves us from a lot of splainin :D
  5. clemsonfor
    I have put some of my windows in myself. The original 12-13 we paid to have installed when we moved in as I did not have the time to doit then with other home work. I watched them doit. It is as easy as it looked or you see on videos. Even easier if you can just slip in the replacement windows. But I had AL frame just k here before so we had to tear them out and just put the new ones in the holes. Its real easy. A few hours per window max. Less if you know what your doing.
    BCPLLC and Eric VW like this.
  6. BCPLLC
    BCPLLC
    Henrico, VA
    Got it and got it! Thank you for the reading!
    Let me clarify, I am by no means an anti-pinite. I like pines and many of my friends have pines. Heck, I live right next door to a man who has pines. Needles in my steep driveway that cause me to lose complete traction when wet? No problem, those needles were born that way, they cannot change. I'm a lover, I'm a giver, to all of the children of nature.
    My understanding came from my first class (I can't say enough about this guy, if you're in richmond I will refer) chimney guy told me not to burn pine. Maybe he thought I would burn it soaked in gasoline with the stove door open, not sure.
  7. clemsonfor
    I dont under stand those type people I wonder what they think they burn in the west or mountain regions...most of canada and places like alaska if pine will burn your house down and they can't burn pine or softwood.??
    HDRock likes this.
  8. HDRock
    Well now you can tell your chimney guy it's a myth
  9. Shawn Curry
    Shawn Curry
    Western NY
  10. chance04
    chance04
    Denton Md
    I dunno. You plan burning it?
    HDRock, Shawn Curry and papadave like this.
  11. BCPLLC
    BCPLLC
    Henrico, VA
  12. papadave
    Looks more like our new greenhouse.:thumbs:
    milleo, Shawn Curry and BCPLLC like this.
  13. Scotty Overkill
    Chvymn99, unclefess, BCPLLC and 6 others like this.
  14. cnice_37
    cnice_37
    Now for my least favorite part of the process...
    Chvymn99, unclefess, HDRock and 3 others like this.
  15. milleo
    milleo
    Maine
  16. BCPLLC
    BCPLLC
    Henrico, VA
    I am not sure this is the best place for this question, mods please move if necessary.
    So I read over the primer to which HDRock posted a reference, and have 2 questions.
    1.> The notion of wet wood not producing as much heat. Is this a measurement of perceived heat? Can someone explain the technical cause of this? A calorie is a calorie, and the caloric content of the solid matter of a piece of wood does not change when water is present, no? If water could deplete caloric content then wouldn't drinking excessive water with your meals be a weight loss miracle? I believe that the gained heating result is true, not doubting it, just trying to wrap my head around how this is possible. In fact I have been thinking about this for a few months now since Mr. Curry mentioned it a while back.
    2.> What is the reasoning behind leaving a layer of ashes in your stove? I have been cleaning them out completely every time I make a fire, for about 6 years now. But I'm a minimalist, ashes included.
    Any input is greatly appreciated!
    p.s. no more orange shirts in XL :(
  17. clemsonfor
    Wet wood requires heat to boil off the moisture. That is heat thats not warming your house or stove. It also creosotes up your chimney as the moist air condenses in chimney.
    Dont believe me burn wet wood in a modern stove then dry see which works better.
    BCPLLC likes this.
  18. BCPLLC
    BCPLLC
    Henrico, VA
    Hmmm.. Boiling off the water simply raises the temperature of the water until such time the water molecule becomes gaseous. So the water is still hot and in your stove. No heat should be lost there anymore than say the steam rising in a steam type boiler system, which of course is radiating into your house. In other words, if you use the heat from your stove to heat up a pot of water on top of the stove vs heat up the water in your wood, the heat loss to heat the water was the same. But this brings up a good point. We all know moist air is a better conductor of heat than dry air. Might it be that the moist steamy air coming off the burning log is going up the chimney thus carrying more heat with it than normal or dry air would?
    Again I have no doubt to the wet wood heat loss ideal, I just can't understand it from a scientific standpoint. Inquiring minds would like to know!
  19. Oldman47
    Oldman47
    Illinois
    No.
    The act of boiling water causes a state change that consumes much more energy than just heating water. At atmospheric pressure it eats up 970 BTU/pound to change state but only about 1 BTU per pound to move the temperature a degree. Going from 32ºF, but still liquid, water to 212ºF only takes 180 BTU/lb. Every BTU used to convert water to steam is completely lost into the outside atmosphere unless you get condensation in your flue stack, something you definitely do not want.
    If you boil water on top of the stove and it condenses on your windows you do recover some of that heat but again it is not a situation you would really want.
    If you really want to understand it, look up or Google "latent heat". Not even the engineers that work with it every day like to work with those numbers much, but they do know how. Latent heart of water varies a lot with pressure right up to a pressure/temperature called the "critical point" at about 3206 PSI above which there is no difference between steam and water. Try wrapping your head around that when it actually matters in a design.
    BCPLLC likes this.
  20. BCPLLC
    BCPLLC
    Henrico, VA
    I am thinking my way through this as we speak and have some follow up question/clarification. Before I do so, can you please clarify what you answered "No" to? Was it the question "Might it be that the moist steamy air coming off the burning log is going up the chimney thus carrying more heat with it than normal or dry air would?" or some other detail I mentioned? Thank you in advance!
