The official Earthquake thread.
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Dec 4, 2013.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Well I might be keeping the earthquake saw as a main saw now.:( My super 034 just lost all compression I'm pretty sure and I don't really want to buy a new saw right now. Looks like it's getting opened up but not ported or anything risky because I don't have much experience with these things. pizzer....:(
    Chvymn99 and clemsonfor like this.
  2. clemsonfor
    Well I liked it but not that your saw grenades but because ur using the quake moded
    Chvymn99 and Pallet Pete like this.
  3. Pallet Pete
    Ovid
    Yup just did the thumb test the super is not so super anymore.
  4. clemsonfor
    What's piston look like? Start a new thread on it. Bet we get uou back togeather even if its with aftermarket stiff.
  5. Pallet Pete
    Ovid
    That's saw is so beat up and abused I am not sure it's worth the time. I will start a thread however and I am gonna tear it apart cuz I want to have some fun with it yet lol.
  6. clemsonfor
    Well for less than $100 u can have earthquake quality p/c
    Pallet Pete likes this.
  7. MasterMech
    You would be surprised how well an old 034 will run. Resurrect that puppy. Even if you have to go as far as dropping it in a box. ;)
    Chvymn99, H 2 H and clemsonfor like this.
  8. DexterDay
    DexterDay Administrator
    Northeast Oh
    A set of Cabers is less than $15 and will give it some life. As long as it's not seized?
    As for the shavings Clem, the muffler is open. Just use compressed air and/or water and wash/blow them out.
    B_Williams and Chvymn99 like this.
  9. Pallet Pete
    Ovid
    What would it run to rebuild it? I need a fuel tank too if I am going that far.
  10. Pallet Pete
    Ovid
    I am starting a new thread sorry for the derail!
    Chvymn99 likes this.
  11. DexterDay
    Northeast Oh
    I know I would happily work on it, as well as MasterMech. May only tale a set of rings ($15) ? Throw in a new fuel line and impulse ($20). For around $30, it will have another 20 yrs :)
  12. clemsonfor
    I think its free which is how he is able to feel no compression thru plug hole. Ring welded, y'all think, broke ring?
  13. DexterDay
    Northeast Oh
    I have a tank with a small crack in the handle?
    Is your tank leaking? Or just a cracked handle?
    But a new Tank through Hull is cheap. I have won 2 tanks in an auction for the 034/036/360 for less than $30.
  14. DexterDay
    Northeast Oh
    Just cause it turns over doesn't mean that it didn't seize and leave aluminum transfer.
    clemsonfor likes this.
  15. Pallet Pete
    Ovid
    It's got a cracked handle and tank although AC glued the pizz out of the tank with so e kind of really strong glue so it doesn't leak.
  16. DexterDay
    Northeast Oh
    Oops. Thread derailed. Just read you started a thread. Sorry..
  17. Pallet Pete
    Ovid
    It runs but as soon as you hit wood the chain just slows and stops no matter the feudal air settings. It's been acting up for a while now I think today was the final hour so to speak.
  18. MasterMech
    Sounds like she's due for a rebuild. Pull the cyl, if it's clean then it's prob worth going ahead on.
    Pallet Pete and DexterDay like this.
  19. raybonz
    raybonz Moderator
    Carver, Mass.
    You need a dozen to make things right!
    DexterDay likes this.
  20. clemsonfor
    Had some time to tinker yesterday. Finally got around to my first 4518 .
    Popped 2nd pull ran third pull.
    I figured out why it never had been in wood. The chain brake won't let the chain turn. And yes I have the brake off. I can get the brake assembly snug and tension chain and itwill spin free but when I tighten it down it like it binds it up. I am pretty sure the band has a place where it contacts the drum more than it should. I van with 2 screw drivers oil the chain around but its tough. It looks like one part may be bent inward contacting the drum???
    I pulled the cover off the brake assemblybut there seems to be no adjustment I can see? Thoughts before I buy a new band?? May try to re count our this one first.
