The Jonas Winter Storm Photos Thread
Discussion in 'Everything Else (off topic)' started by Kimberly, Jan 22, 2016.
  1. foragefarmer
    foragefarmer
    Central, Virginia
    Been playing in the snow.
    Cows pretending they are hungry. There is still hay out from yesterday.
  2. Bret Hart
    Bret Hart
    Central NY
    How do those forks do pushing snow? Guessing you've got a board or plate against the back?
  3. foragefarmer
    foragefarmer
    Central, Virginia
    Got a 3pt. blade on the back. Needed the forks before the snow, didn't need to switch over.
    Here is a short vid plowing a section of easier drift, The front tire helps too!
  4. HarvestMan
    HarvestMan
    Southeastern Michigan
    Here are a couple of pictures the BIL sent from Glengary, WV area. He claims 50 inches based on it being 6 inches above a 55 gallon barrel in his yard (what other kind of measurement do you expect from an ole hillbilly :)).
    Looking out his front door:
    Picture of his car and truck:
  5. Eric VW
    That's crazy, HM!
    They got slammed up there for sure!!!
  6. MikeSs
    MikeSs
    new have county, ct.
    A coworker who just moved from New Hampster would say
    'A smidge over a dusting'.
  7. Well Seasoned
    A stack I was pulling from until it gets buried. Now I will pull from the woodshed.
    Looking into the woods.
    This area got a lot of drifting
    Pushing snow by another rack I will pull maple and hickory from still.
  8. Kimberly
    Kimberly
    The Kangaroo State
    One needs to be thinking about the weight of the snow load. Of course the mass of the snow is going to be determined by the type of snow; if it is a dry snow, mostly ice crystals, then the load will be less than if it is a wet snow. The load will depend on the angle of the surface as well, a horizontal surface has the full normal force of the load; as the surface angle increases, the normal force decreases. Here is a pdf to peruse: http://pajk.arh.noaa.gov/Articles/articles/snowloads.pdf
  9. Kimberly
    Kimberly
    The Kangaroo State
    Is the top of the stack covered? I was wondering that as the stack warms up if you have to think about melting snow dripping down into the stack?
  10. Horkn
    OK, I finally got through all the posts in this thread. I fell asleep while wading through it last night.
    I'd rather be wading through posts than drifts, and I love snow.
    Some of you have epic amounts of the white stuff.
    Stay safe FHC'ers
  11. Well Seasoned
    Yes, anything I use that is outside this year gets top covered with epdm. Next year's stuff will continue to stay uncovered until early fall, when much goes into the woodshed.
  12. Kimberly
    Kimberly
    The Kangaroo State
    What is EPDM?
    NH mountain man and Eric VW like this.
  13. Eric VW
  14. JustWood
    JustWood Guest
    That's right up to snowbelt standards.
  15. Horkn
  16. Well Seasoned
    You need big equiptment for snows like that! :hair:
    Backwoods Savage and Horkn like this.
  17. will711
    will711
    Pocono Mts.
    The morning after
    IMG_1001_1.jpg IMG_0990_1.jpg IMG_0991_1.jpg IMG_0992_1.jpg IMG_0995_1.jpg IMG_0997_1.jpg IMG_0999_1.jpg IMG_1000_1.jpg
  18. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Well Seasoned Did you get to the OAK yet? I'm curious if it was snowed in.
  19. Well Seasoned
    fishingpol, yes, it was buried. What fell and the drifting had it covered. It's clear now so we should be back in business when I reload later.
    Below, there is almost a cave being formed from the drift. Really cool looking
  20. 343amc
    343amc
    Northeast Lower Michigan
    For those who may need to clear their roofs off, here is something for perspective. This was in February 2014 when most of MI got hammered with snow. The snow was about 3' on the level, maybe a bit more. This is in the NE lower peninsula, and the previous owner sent us this picture.
    It's hard to tell how much is on the roof until it's on the ground. I can only imagine how much weight that was. Lucky for me, I didn't have to do the shoveling.
