The "How Much Have You Burned So Far" Thread
Discussion in 'The Wood Pile' started by MightyWhitey, Dec 27, 2018.
  1. Chaz
    Chaz
    Southwestern NY
    Meh, "blind squirrels n nuts"
    If I throw enough darts even I hit a bullseye eventually.
    ;):yes:
  2. Rope
    Rope
    Alaska
    Must be between 14-15 cords maybe more.
  3. JCMC
    JCMC
    Just outside of Shushan, NY
    Just looked back almost two cord from late Oct till Dec. 27, 2018 here it is Jan 24, 2019 and I've burnt through a another cord those below zero nights really eat the wood.
    Slocum, Rope, Mitch Newton and 7 others like this.
  4. Gasifier
    Been flying through firewood this past month. I would guess we have been through 4.5-5 full cord now. Again, with burning Pine on the days I’m home, that really burns away fast.
    Slocum, Rope, Maina and 4 others like this.
  5. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I'm currently at about 1.3 cords of ash burnt.
    Maybe 5-6 stove.loads of oak and locust on top of that
    Slocum, Rope, Maina and 2 others like this.
  6. Dolphus Raymond
    Dolphus Raymond
    Deep South
    Just over a cord of oak with a little honey locust.
    Rope, Maina, bear 1998 and 1 other person like this.
  7. Sourwood
    Sourwood
    Popcorn, IN
    Sub zero temperature coming. I may have to get into a stack for next year, if I can't keep up the cutting for the boiler. I am thinking i am over three cord now.
    amateur cutter, Slocum, Rope and 5 others like this.
  8. Farmchuck
    Farmchuck
    Nepa
    What kind of boiler do you have?
    amateur cutter, Slocum, Rope and 3 others like this.
  9. Sourwood
    Sourwood
    Popcorn, IN
    A Central Boiler non EPA. Got it within a few months of the ban.
  10. papadave
    Just about 1.3 cord. Started last week of Sept with little kindling fires.
    The first 1/3 was Pine/Spruce, then mostly Ash. We hit a small vein of Oak a couple days ago. There's more of that behind the next stack of Ash.
    The furnace has been taking up the slack, and we're burning approx. the same amount of BTUs in nat. gas as we would normally burn wood, so same same.
    If the forecast is even close to correct, this below zero stuff should be going away in less than a month or so, then we can get back into smaller fires. I may just let the furnace run in the spring.
  11. Ou812
    Ou812
    Eastern ct
    My "s.w.a.g" is 1.5 so far, ash cherry and oak
  12. Farmchuck
    Farmchuck
    Nepa
    Which model?
    amateur cutter, bear 1998 and Rope like this.
  13. Suburban wood snob
    Suburban wood snob
    Milwaukee
  14. Sourwood
    Sourwood
    Popcorn, IN
    I think it’s a 6048.
    amateur cutter and bear 1998 like this.
  15. rdust
    rdust
    SE, Michigan
    Been burning through it at a silly pace, by spring I’ll be pulling off the stacks instead of the shed(shed holds just shy of 4 cords).
  16. Jim Barry
    Jim Barry
    Loch Katrine, Nova Scotia
    Started burning late October. 2 cords of maple in northeastern Nova Scotia, stove is a Harmon Oakwood. There's no snow on the ground at the moment.
  17. Farmchuck
    Farmchuck
    Nepa
    That’s what we have. Keeps everything warm & toasty but it sure is a hungry bugger!!!!!!!!!!!
  18. Spencer
    Spencer
    Indiana
    Im probably up to 3 cord. I think i will make it till the end of Feb before i run out. I really need better insulation in my house.
  19. bert the turtle
    bert the turtle
    I've been through a cord of pine for and about 1/3 cord of pine/gum/oak blend. Probably another 1/3 cord or so of bits, pieces, chunks, shorts, uglies, and sticks.
    bear 1998 and amateur cutter like this.
  20. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I just refilled my 1/2 cord bin on the porch yesterday. That's 1.5 cords of ash burned so far, and very little oak and locust as the weather has demanded it. Maybe 1/10 of a cord?
