The factories dont port the saws because ...............
Discussion in 'Chainsaws and Power Equipment' started by pantelis, Nov 26, 2015.
  1. clemsonfor
    No idea?? But the factory has to make money and so does the dealer as MM said. $250 off in cash you dealer is just turning money over and not making anything. I'm sure thats the profit margin. At that point there just selling you a saw as a friend!!
  2. concretegrazer
    concretegrazer
    Southwest MO
    They also cost a lot more on that side of the pond. I'm sure that the dealers & manufacturers are making plenty.
    mdavlee, pantelis and Eric VW like this.
  3. pantelis
    pantelis
    Europe
    They give a bar and chain gift for buying the 170 , so 50 euros gift for a 200 euros saw , i dont know if the 170 cost only 50 euros to the factory ............ lets say:whistle::whistle:
    and the 661 ........ 200 again lets say:whistle::whistle: and maybe the ES bar 20'' about 25 ..........
    concretegrazer likes this.
  4. pantelis
    pantelis
    Europe
    I was the first that order the 661 in my country then the problem starts ( recalls or something ) the distributor offer 50% down.......... if i buy the 660.
    how much this distributor loves me he save me a ton of money:whistle::whistle::whistle::whistle:
  5. pantelis
    pantelis
    Europe
    And finally the recall was another trick between distributors and stihl , who understand understand
    clemsonfor likes this.
  6. MasterMech
    All small engine hp specs are complete and utter marketing BS.
    Kool-aid? Oh yeah! :rofl: :lol:
  7. bushpilot
    bushpilot
    Eastern Washington
  8. Horkn
    The biggest issue is the quality of gasoline. All 2 strokes are like this, whether it's in a saw, snowmobile, dirt bike, quad, outboard, etc.
  9. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    There are several good responses here. Pretty much everything we own with a combustion engine is restricted purposely. Emissions is becoming a major part of it, but warranty, brand rep, and the engineering likely combine to produce the restrictions.
    Almost every guy on here knows how to properly mix gas and oil, but many do not. The dealers/manufacturers need a cushion for the uninformed so they are not getting millions in warranty claims from improper operation. The restriction allows a large group of people to own these saws with a broad tolerance for operator error. The big guys could port these at a deminimous cost, but would open themselves up to added risk which the few dollar markup would not cover.
    Final example....my old king ranch with the 6.4 L diesel put out around 350 -400 hp and roughly600 ft lbs of torque at the wheels. One mod I could have done added 50 hp. What I ought added 200 plus horsepower and dyno tested at 1200 ft lbs of torque. Emissions.....it had many:dex: but the downside was there was so much compression the heads could lift. Ford knows guys hit the pedal, so to reduce risk and associated cost, tuned it down.
    Sorry to rant, just sitting in the tree stand seeing no deer. Luckily guys that are part of this forum are knowledgable enough to make the mods the manufacturers will not.
    Chvymn99, Eric VW, Horkn and 3 others like this.
  10. Firewood Bandit
    Firewood Bandit
    EPA regulations are ruining many things. Do you think the strato saws were designed for just something to do. That P/C is much more complex that casting a copy of a ported saw. Adding computers to saws for simplicity?
    Look at VW and the diesel scandal. Do you think VW defeated emission standards to get worse fuel economy and poorer performance.
    Chvymn99, HoneyFuzz, Eric VW and 3 others like this.
  11. MasterMech
    Tech like stratified scavenging and electronic carburetors/fuel injection are prime examples of the "right" way to go about lowering emissions. It would have been easy and a lot less R&D to just slap a catalytic muffler on everything and call it a day. But things like catalytic mufflers, and diesel particulate filters are pretty awful devices that raise engine temperatures and consume extra fuel increasing the cost to operate whatever machine they are attached to.
  12. Firewood Bandit
    Firewood Bandit
    I agree with you for the most part. However in the VW example operating in a manner to lower NoX emissions really hurts performance and mileage.
    Woodsnwoods likes this.
  13. clemsonfor
    Correct. Thats why they had a bypass mode for it to operate in unless it was in a testing mode. They wanted to maximize mpg and power. Once it was in full emissions mode power and mpg decreased.
  14. MasterMech
    All manufacturers tweak for emissions testing. Some do it mechanically, designed into the engine, VW just did it blatantly via the ECU software.
    I hate the philosophy that we don't care how much fuel an engine burns as long as it does it clean. How much would we reduce overall emissions just by an across the board reduction in the amount of fuel we burn to produce a given amount of power? Not to mention how much energy and pollution could be eliminated by not having to extract as much fuel in the first place? :sherlock:
    Woodsnwoods and HoneyFuzz like this.
  15. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Yep pretty much.
    Plus there is the risk of warranty - consider the average warranty situation: the owner leaves the fuel in too long. The owner doesn't mix the premix right. The owner doesn't follow the start sequence exactly. If you put modded worksaws into the hands of these individuals, you will get a lot of returns and reliability issues. They just don't want the risk, even if a well modded saw very robust.
    The other factor is emissions and noise. I don't believe they can do anything they want or else they would.
    clemsonfor, Woodsnwoods and pantelis like this.
  16. pantelis
    pantelis
    Europe
    Technically they can do what they want , they can make better performance saw just because can make something from the beggining ( new cases , cylinders , pistons , e.t.c ) but i believe that they leave the situation as it is , they have made the big name and the sales go perfect so no reason to wake up the beast
  17. pantelis
    pantelis
    Europe
    The bigest issue is the operator not the gasoline .
    Woodsnwoods and MasterMech like this.
  18. dgeesaman
    dgeesaman
    Elizabethtown, PA
    In America the gasoline is definitely a problem.
    In Canada and other parts of the world I think it's less of a problem.
  19. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Luckily the gas station near my house sells 93 octane that is ethanol free.
    clemsonfor and pantelis like this.
  20. pantelis
    pantelis
    Europe
    if you talk about ethanol its a world wide problem
    Horkn likes this.
