The Blaze King thread, new combustor & good wood.
Discussion in 'Modern EPA Stoves and Fireplaces' started by bogydave, Dec 7, 2014.
  1. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Always fun to hear that Alaska is warmer than I am right now...
    milleo and papadave like this.
  2. Highbeam
    Highbeam
    No difference though my softwoods have more btu per CF than my hardwoods. If I can, and I can, get 24 hour burns with low btu wood then you know that I can't get 36 hour burns with wood that has 50% higher btu per CF. So the higher btu woods must make more heat during the cycle.
  3. Highbeam
    Highbeam
    This is what I do.
    When it is warm out I do full loads once per day in the evening and sometimes I have to rekindle a cold stove but the house temps are good. If house temps drop too much to allow that cycle then I go to 12 hour loads and they aren't full loads. Just enough to keep the cat active and allow hot reloads every 12 hours. If that is not enough, really cold out, then I do full loads every 12 hours and bump up the stat.
    I like it when it's really cold out and I run 12 hour cycles on higher settings. The stove glass and firebox stays cleaner.
    Anything other than 12 or 24 hour cycles is troublesome with my schedule. Even on full boogie to get 12 hour burntimes is awesome. My non-cat on full boogie gets reloaded every couple of hours.
    Beetle-Kill likes this.
  4. bogydave
    Hotter burns definitely keep the glass cleaner.
    Though this year , with much better wood, the glass is much cleaner than in the past
    with the low burns I'm doing now.
    Hasn't blacked all over, just the left & right edges.
    Slocum likes this.
  5. swags
    swags Moderator
    What settings and what stove top temps do you get with hardwood?
  6. bogydave
    Yea
    Same here.
    still have some hot coals mixed in the ash,
    but don't need a thermal suit to load LOL :)
    & it's nice to load at a reasonable pace when the flames aren't lapping at your hands & arms :)
    papadave likes this.
  7. Highbeam
    Highbeam
    Well in the PNW our hardwood is actually a lower btu per CF than softwood. This year I am burning douglas fir plus some sort of juniper. Most times when cruising the stove top temp (inferno surface meter right on top of the cat) is 400 and the flue (condar probe) is 400. My stat is set right between the N and O of "normal" which is right about 1.75. I can choose to run it hotter and have had STT up to 650 but prefer to leave the stat alone and boost room temps by running the fans temporarily.
  8. Highbeam
    Highbeam
    Rreloading on a pile of fuel I find smoke spillage to be an issue. If the stove has cooled then the smoke stays in the firebox better.
  9. bogydave
    Those conditions,
    I crack the door for a few minutes to heat the stove pipe & chimney before loading.
    Not a cure all but the stronger draft helps quit a bit.
    The birch bark ignites almost on contact of the hot coals, I have the wood ready to go in & load fast.
    That's another reason it's good to have a full burn cycle,
    regulating the burn cycle reduces the need to load a really hot stove :)
  10. swags
    swags Moderator
    How long of of burn are you getting with the stated temps/settings?
  11. Highbeam
    Highbeam
    An easy 24+ if loaded full. It cools some near the end of course but cat is well into the active range and no kindling is needed. I find that 24 hours at these low temps is really nice for even heating.
  12. swags
    swags Moderator
    Wow Im not getting that. Im getting similar results in the temps with similar settings but not 24 hours. Im on 12 hours with 3 yr oak, running about 400 stove top and set 1.75-2 range for the air setting.
  13. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Swags, reduce your air more. Resist the urge to check temps. for the next hour, then see what happens.
    Oh yeah, take the T-stat cover off, and adjust by sight. I haven't had my cover on for years, I adjust by visual on the flapper alone. Sooo much easier and consistent.
    swags likes this.
  14. bogydave
    The temp probe clean?
    The number on the stat setting don't mean much to anyone
    else, as each set up & stat is a bit different. 2 for mine is almost closed at low stove temps.
    1.8 is my low slow mode.
    But no doubt to me now,
    a new combustor will improve efficiency
  15. Todd
    Todd
    NW WIS
    If I remember correctly I use run a 12 hour schedule at about #2 with a 3/4 load of Oak. For a 24+ hour burn I set it at 1.5 or just a bit less and filled the box full. Also before turning it down I'd burn it kind a hot around 2-2.5 for 20-30 min to make sure that cat is lit.
    swags likes this.
  16. swags
    swags Moderator
    I don't remember if I asked you before but did that cat glow a lot for you? I know it did a decent but last year but this year It hasn't been. But also last year I didn't have the greatest wood to burn. So I could have contributed to its decrease with that.
  17. Highbeam
    Highbeam
    My chimney is double wall for about five feet and then 8 feet of class a. All vertical and only the last four feet is above the roof. No screen in my cap.
    Cat glows every burn but not the whole burn.
  18. swags
    swags Moderator
    Mine goes up a few feet then into the wall. Form there it's about 24' to the top with a cap. I should be getting plenty of draft for my setup.
  19. Sam
    Sam
    Southern Minnesota
    This entire thread makes me so jealous! What I wouldn't give for a 24 hour burn! I'm lucky to get 8 hours on low-glow with the Lopi.
  20. Todd
    Todd
    NW WIS
    Yes, the cat mostly glowed at the beginning of the burn then kind a faded after a couple hours or so. The cat probe stayed above active for all but the last 2 or 3 hours of a 24 hour burn.
